Old 01-06-2007, 09:17 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
'70s door lock cylinder replacement
My cylinders on my 71 and 73 are getting balky. Before I really get myself locked out what is involved in just replacing the cylinder/ tumbler part and not the whole lock? Are these parts still available? Are the an item a locksmith is likely to have or a specialized Airstream parts dealer item?
Old 01-07-2007, 12:19 AM   #2
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I was able to order the lock cylindar from Oasis RV in AZ. I think it was about $25.
-Tim
theVAP - Airstream Podcast
Old 01-07-2007, 12:46 AM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Just had mine replaced, $2.85 for a cylinder.
Any locksmith supply
'77 Sovereign Intl 31' CB
Old 01-07-2007, 07:39 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I did my own, and I knew nothing about locks, just took it apart and replaced the broken part.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-07-2007, 08:17 AM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Is replacement, then fairly, striaghtforward?
Old 01-08-2007, 06:43 PM   #6
Different locks use different cylinders.
The KT lock used from 1970 to 1977 uses a special KT lock cylinder or tumbler.
Those are no longer available from Airstream.
We purchased another type and had them machined to fit those locks.
Airstream does have a cylinder for the current KT lock that has a modified tumbler opening.
The current KT lock base will not accept an older tumbler, and Airstream's new tumbler will not fit the old lock base.
Old 01-08-2007, 07:54 PM   #7
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Thanks for the clarification Andy.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-08-2007, 08:10 PM   #8
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
Yes, unscrew the whole handle/latch assembly from the inside and remove it through the front as one piece. It's been a while since I had mine out but I seem to remember that the cylinder has a clip on the back, then it's a simple matter of pulling the cylinder out for replacement.
Best wishes,
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Old 01-08-2007, 08:47 PM   #9
Best wishes,
Steve
Steve,
Your doing it the hard way, which takes time away from the cool one.
The simple way to remove the old tumbler, is to take a 1 inch # 8 sheet metal screw and run it into the tumbler about half way.
Then take a small thin board and place it next to the old tumbler.
Take a "claw hammer", grab the head of the screw and pull. Bingo, out comes the tumbler.
The back of the old tumbler breaks off and falls down into the door. So, who cares.
Then simply squeeze the "C" clip on the new tumbler and insert it into the hole.
Next. Have a beer. Job well done.
Old 01-08-2007, 09:16 PM   #10
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Here's the lock diagram if it helps.
-Tim
Old 01-09-2007, 04:20 AM   #11
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
NICE Diagram!
I gave up, my lock assembly is in good shape, just lost faith it would stay locked/closed while traveling. Installed a dead bolt
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 01-18-2007, 09:09 PM   #12
1989 29' Excella
afton , Virginia
We are looking to purchase front door/ lock kit. Would the back fiberglass/plastic tail light assembly with lights still be around? We are also looking to find the base trim around the exterior bottom. Thanks! Trying to restore the 74 Argosy we just purchased.
alumibum is offline   Reply With Quote
Old 01-19-2007, 07:01 AM   #13
Lumatic's Avatar
1993 34' Excella
Images: 16
I might have the taillight. Email me and I will look in my "parts".
Old 01-19-2007, 09:22 AM   #14
That tail light bezel has not been available for many years.
The bottom molding, called rub rail, is available, as well as the inserts.
The door lock must be a "motorhome" type lock.
Keeler Cylinder Lock & Keys - "78 Excella rushingg149 Windows, Doors, Locks & Vents 1 08-15-2013 10:59 PM
Classic trunk lock cylinder - Problem? Ag&Au Doors & Locks 4 08-23-2009 06:11 PM
Lock Cylinder source for '71 Globetrotter? boltos Doors & Locks 4 07-13-2009 12:07 PM
Lock Cylinder niftypkg Doors & Locks 2 12-28-2008 11:13 AM
Refer Handle Lock Cylinder, Same As Ford 58BUBBLE Doors & Locks 4 03-18-2005 09:21 PM
