Old 02-15-2007, 06:13 PM   #15
1972 27' Overlander
cass , Texas
Did you ever get the problem fixed? If so, could you share your experience? Thanks
krazeekalvin is offline   Reply With Quote
Old 02-15-2007, 06:33 PM   #16
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Steve,
Your doing it the hard way, which takes time away from the cool one.
The simple way to remove the old tumbler, is to take a 1 inch # 8 sheet metal screw and run it into the tumbler about half way.
Then take a small thin board and place it next to the old tumbler.
Take a "claw hammer", grab the head of the screw and pull. Bingo, out comes the tumbler.
The back of the old tumbler breaks off and falls down into the door. So, who cares.
Then simply squeeze the "C" clip on the new tumbler and insert it into the hole.
Next. Have a beer. Job well done.
If all else fails, would this technique also get you into a lockout?
Old 02-15-2007, 06:57 PM   #17
Lumatic's Avatar
1993 34' Excella
Images: 16
Not sure if this was directed to me. But yes and no. A little WD 40 got the cylinders working again, temporarily I'm sure. Shhhhhhh, the key for my 71 opens my 73 easier than the original key. I'm guessing the worn out key works like a master key on the worn out tumblers.
Old 02-15-2007, 07:44 PM   #18
1989 29' Excella
afton , Virginia
I took the door lock apart....cleaned everything and found that I needed the tumbler....took it to a locksmith...replaced...new keys...works like a charm...$30.00. I think I'll place a deadbolt on as well...just don't trust the door as we're traveling down the road. The taillight problem was put to the side...working on projects indoors during the cold weather... will tackle that later.
alumibum is offline   Reply With Quote
Old 02-15-2007, 08:32 PM   #19
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
Question bolt
Originally Posted by balrgn
NICE Diagram!
I gave up, my lock assembly is in good shape, just lost faith it would stay locked/closed while traveling. Installed a dead bolt
A.
How'd you do that without trimming the bolt? I'm curious how large the hole in your door is? Did you do anything to beef it up? I never did, but I am very careful about slamming the door.
Best wishes,
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Old 02-16-2007, 03:43 AM   #20
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by sfixx
A.
Best wishes,
Steve
Formerly a machinist
Fabriated a bracket for the door to reinforce what I removed.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 02-16-2007, 06:24 AM   #21
sfixx's Avatar
1973 Argosy 20
Images: 12
Thumbs up strike plate
Thanks for the lesson on how to finish the job well
Did you also machine the base mount for the exterior? It looks like your cylinder housing is not cut.
Old 02-16-2007, 08:06 AM   #22
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Did not machine the lock assembly. I used a de-buring tool to fine tune the fit. It is an exact fit to the innner channel. This is the hole I started with, I'll look to see if I have a completed slot pic.
www.balrgn.com
Old 02-16-2007, 08:23 AM   #23
pbrown1963's Avatar
1972 31' Sovereign
roanoke , Texas
How difficult is it to install a deadbolt in an AS. Do you have those on the shelf also?
pb
If you think you don't have anything to do today...go look at your airstream!!
pbrown1963 is offline   Reply With Quote
Old 02-16-2007, 05:53 PM   #24
sfixx's Avatar
1973 Argosy 20
Images: 12
Originally Posted by pbrown1963
How difficult is it to install a deadbolt in an AS....
PB: You will find a number of threads on adding a deadbolt by doing a simple search. I show the process in my blog also (March '05 listing). Also a good thread: here
A: Here's the other part I was talking about that looks machined. The ring around the base. Was that a part of the set?
Thanks for the door lock cylinder replacement info. I doubt that I'll be yanking it out with a claw hammer. I have more time than money and I would hate to risk breaking something
Steve
Old 02-16-2007, 05:59 PM   #25
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Steve
Good eye Steve! That is a spacer, D shaped. I needed make it to get above the seam.
www.balrgn.com
Keeler Cylinder Lock & Keys - "78 Excella rushingg149 Windows, Doors, Locks & Vents 1 08-15-2013 10:59 PM
Classic trunk lock cylinder - Problem? Ag&Au Doors & Locks 4 08-23-2009 06:11 PM
Lock Cylinder source for '71 Globetrotter? boltos Doors & Locks 4 07-13-2009 12:07 PM
Lock Cylinder niftypkg Doors & Locks 2 12-28-2008 11:13 AM
Refer Handle Lock Cylinder, Same As Ford 58BUBBLE Doors & Locks 4 03-18-2005 09:21 PM
