Old 08-28-2018, 09:31 AM   #1
1973 Argosy 20
1968 24' Tradewind
Kingsville , Ontario
68 Tradewind Door Hinge
So i want to replace a side panel on my Tradewind, which I'm comfortable tackling – however, I'm not sure if removing the door/hinge assembly is a good idea. Right now the door opens and closes fine. I can't find any info on these hinges but they bolt part in the back appears to be cast as part of the hinge itself. Closer inspection on the inside revealed that the bottom bolt snapped off at some point, so I'm a bit concerned about creating a much larger problem here. Any suggestions?
Thanks, ROO
ID:	321057   Click image for larger version
roostream is offline   Reply With Quote
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
Pre-war Door Hinge (Door-in-door) ekstarr Doors & Locks 0 06-26-2018 02:37 PM
"Door in a door" hinge goshawks00 Doors & Locks 1 12-06-2016 04:00 PM
Looking for a door hinge for my 1950 Liner. Possibly a whole door. Thanks ! Gocamp2 Doors & Locks 0 05-31-2016 04:42 AM
door hinge on '75 Tradewind loose imbighoe 1970-79 Tradewind 7 09-02-2014 02:03 PM
