Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 10-09-2013, 04:18 PM   #1
1968 26' Overlander
Lopez Island , Washington
'68 Overlander Rear Access Door
I just acquired a '68 Overlander Double. The rear access door is in good shape and has a locking T-handle. It has been held in place by two pieces of duct tape placed diagonally over the top corners of the door. On page 107 of the owner's manual they call it the 'One-Stop Service Center'. The photo shows the door completely removed as if it just comes off rather than being attached by a hinge. So my question is, What holds it in place? On the inside of the door panel, there are four screw holes and it looks like the T handle also operated two pieces of aluminum that fit into rectangular holes in the door frame. That would hold the bottom in place, but what about the top? Mystery to me.
Pomerenk is offline   Reply With Quote
Old 10-09-2013, 04:25 PM   #2
altnbndr's Avatar
1967 17' Caravel
1968 22' Safari
Sacramento , California
Images: 11
68 back access door
The top frame of the door pushes into a channel along the top of the opening. (It hooks into top and latches into three points along the bottom)
altnbndr is offline   Reply With Quote
Old 10-09-2013, 04:54 PM   #3
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
There were two latch configurations 1 t handle had a tab which held at the bottom the other has two rods that lock the door in on the lower bottom sides.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 10-09-2013, 06:30 PM   #4
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
The doors are easily lost while traveling. The tape at the top is useless since the door must be removed from the bottom first,since the top slides into a slot like member altnbnrd stated. So its better to tape the bottom of the door to prevent loss.
You can also place small safety chains attached to the door from the inside, then should the door come loose the chains will prevent the door from being lost.
kevinb is offline   Reply With Quote
Old 10-09-2013, 06:56 PM   #5
asbury park , New Jersey
ah! safety chains! a brilliant idea!
NJtoNC is offline   Reply With Quote
Old 10-10-2013, 04:44 AM   #6
1966 17' Caravel
My luck I would make the chains too long and some trooper would pull me for littering
Screen door stuck in closed position ESCAPE POD Doors & Locks 5 06-11-2022 05:43 AM
Rear End Sag on 2005 28' CCD tyggeln Repairing/Replacing Floor &/or Frame 7 10-28-2014 05:17 PM
'68 Overlander door knob LI Pets Exterior Storage Compartments & Access Doors 5 04-07-2014 02:52 PM
Access door leaks Captain Hank Doors & Locks 0 11-04-2011 10:38 AM
Bathroom sliding door polarlyse General Interior Topics 2 05-21-2011 07:54 PM
