Old 05-03-2015, 04:54 PM   #1
TCTradewind's Avatar
1968 24' Tradewind
Traverse City , Michigan
'68 Bargman L-100 Barrel Lock
1968 Tradewind. Door handle was always a little dicey. I had a system though, you lined up the handle, pressed in, had to "feel" the barrel line up and voila, the lock worked fine. No problems for two years.
1) Lesson one, don't let others borrow your airstream.
Handle was all jacked up and hinged on rotating and user said he "had a hell of a time" trying to unlock it. Well, now it no longer locks.
When I finally get the barrel and key lined up (much more difficult then previously) when I do turn the key it just pops open the unlocked door. I can no longer get the handle to the locked position.
I took everything apart and was checking the interior of the handle and lock. No clue what I'm looking for. Tightened and put back, handle now turns fine and functions in terms of open and close.... with the exception of locking.
A) Can I buy just the barrel and are these an easy enough fix?
B) Please tell me I can keep the original handle hardware and just replace the barrel. Unless there is something else I should take apart and look at before buying replacements.
Marek
ID:	237671   Click image for larger version
TCTradewind is offline   Reply With Quote
Old 05-03-2015, 06:00 PM   #2
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
Hi, this is Rick. I sell and rebuild these locks. Call me and I will see if I can help you.
864-380-7523
montanablue is offline   Reply With Quote
Old 08-01-2019, 10:35 AM   #3
FW , Texas
Hi Marek,
Any update to your luck with lock? I have a 1968 tradewind with EXACTLY the same story of Bargman being touchy but usable until a thoughtless guest used it... I have taken mine apart and think the culprit is the square on the inside/back of doorknob being worn out. This square piece lines up with the 'barrel' you mention but appears to slip..
I would replace with another lock but appears my backset is ~3.25" maybe (it has the bargman extender) and looking for an idea to rig/replace while I figure how to refurbish my old one.
John
ID:	348215   Click image for larger version
airfarm is offline   Reply With Quote
Old 08-01-2019, 10:53 AM   #4
1966 22' Safari
Fredericksburg , Texas
Originally Posted by airfarm View Post
Hi Marek,
John
Speak with, or PM Rick (Montanablue). He’ll have the answer. Good luck
Bubba L is offline   Reply With Quote
Old 08-02-2019, 07:02 AM   #5
1997 25' Safari
1973 25' Tradewind
I will be glad to assist you. Sent you a private message Airfarm.
Bargman L-100 Pics - need parts JoePfznik Doors & Locks 42 02-12-2018 07:57 AM
Bargman L-100 67 Overlander lock Leshelley Airstream Classifieds 0 09-30-2014 09:21 PM
'62 globetrotter - bargman L-100 doesn't fit - help? jrsygrl Doors & Locks 4 02-26-2011 03:25 PM
