Old 09-10-2018, 09:57 AM   #1
ACMEMOPARS's Avatar
1968 28' Ambassador
Denison , Texas
68 Ambassador door mechanism broken + won't open from outside.
The outside door handle on my 68 Ambassador is extremely loose and will not open the door. I've tried pushing in and pulling while twisting the knob, etc... and after about 15 minutes and about to give up, it finally worked its way loose and I was able to open it.
I unscrewed the door handle mechanism (took it apart) and found that the internal mechanism is just wore out and needs replaced. The actual handles themselves are OK and can be reused.
What are the best options for replacement of the internal mechanism, maybe a complete replacement kit, etc and what is a recommended source ?
Thanks in advance.
Mike Nelson
Denison, Tx
ACMEMOPARS is offline   Reply With Quote
Old 09-10-2018, 10:00 AM   #2
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
Contact me at r_whiten@hotmail.com and I will help you. I sell and rebuild these locks all the time. Maybe I can help.
Rick (Montanablue)
montanablue is offline   Reply With Quote
Main door lock broken..can't get open Becky B. Doors & Locks 17 10-28-2018 11:26 AM
Broken step mechanism JBBeaubeaux General Repair Forum 2 06-09-2016 10:18 PM
Slide out locking mechanism won't unlock. Nokomis Joe General Repair Forum 2 10-15-2015 04:52 PM
Water heater only lights with outside door open davidkingham LP Gas, Piping, Tanks & Regulators 6 06-06-2015 08:14 AM
Outside fresh water door lock won't open willbrackman Exterior Storage Compartments & Access Doors 12 11-02-2011 01:27 AM
