Originally Posted by garyk1970
great! let me send you some $ for at least shipping..... how do i give you "good karma"? pm sent.
Hi Gary,
It’s on its way. PM also sent. I even located the original Bargman key. When you get it, you will find some silver goop in the screw holes. This is Permatex Anti-Seize. If there had been some on the screws, that problem would never have existed. I can’t believe that I didn’t put some on back in the early ’90s when I changed the lock the first time. I put either Loctite or Anti-Seize on every fastener that I tighten. It’s absolutely essential when you put a steel thread into aluminum, think sparkplug in a head. I even make it a point to take all my lug nuts off and coat the studs with it. Makes removal a lot easier.
Oh, and the Karma, there is a line below my avatar.
