Old 06-22-2015, 08:38 PM   #1
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
'67 Entry Door Hinge Pin
How do I fix a worn pin on the Hinge of the entry door? Or is the Hinge itself worn?
I can lift the door about 1/16 - 1/8 inch. the play is in the Hinge. The Hinge itself is solidly attached to the trailer body.
It does not affect the opening and closing of the door, but I would still like to fix this.
It reminds me of an old car I had that had a door that had to be lifted when closing it.
The trailer door does not have to be lifted to open or close it however.
If anyone else has had this problem I would love to hear how you went about curing it.
Thank you!
Dingo Girl is online now   Reply With Quote
Old 09-01-2015, 05:33 PM   #2
JLGT5107's Avatar
1965 20' Globetrotter
Fairfield , Connecticut
I have the same problem. I bought some nylon spacers with .25 id from home depot, cut them to 1/8" long then cut a slice vertical so I could push it onto pin. My pin is frozen. I think I will have to wrap it with a couple of winds of small gauge wire to keep it in place over time. It is part of my door rebuild I am just finishing up.
JLGT5107 is offline   Reply With Quote
Old 09-01-2015, 05:42 PM   #3
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I wondered if C clips could be used, not sure how I'd wedge it in there though.
Old 09-01-2015, 06:58 PM   #4
JLGT5107's Avatar
That sounds good. Maybe clip the c clips with some snips, then drive them with a screwdriver blade. thats what i did with nylon.Also, It might work better after some thai stuffed sweet potatoes.
Old 09-01-2015, 07:03 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My 66 single hinge is also worn and sloppy. I think I have more play than you described.
Here is an article on Vintage Airstream about removing and replacing the hinge pin.
Removing a Single Hinge Door - Vintage Airstream
IIRC, I read where Aerowood essentially "line bored" his hinge and installed a larger pin to make it like new. Maybe if I purchased a long reamer about .03 larger in diameter and then the corresponding drill rod for the new hinge pin.
I plan on rebuilding my hinge this winter, I just don't know how yet.
David
Old 09-24-2015, 09:44 AM   #6
AudioMike's Avatar
1966 22' Safari
Englewood , Colorado
I have a '66 also and the door sags. Looks like there is play in the hinge pin. I am not sure that would feel comfortable in boring this out myself without making a mess of it. Any suggestions on who could do this, if that is the right way to fix this issue.
Audiomike
1966 Safari
2001 Silverado 2500HD
AudioMike is offline   Reply With Quote
Old 09-24-2015, 10:16 AM   #7
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
David
I only line bored the worn half. I then installed bronze bushing and installed a .250 stainless steel hinge pin which is the stock diameter.
Any competent machine shop should be able to do this.
Old 09-24-2015, 10:31 AM   #8
Replacement hinge pins are available for less than $ 20.00.
Old 09-25-2015, 04:05 PM   #9
AudioMike's Avatar
1966 22' Safari
Andy. I am planning on buying one from you. In your experience does just replacing the pin usually solve the issue?
Old 09-25-2015, 04:49 PM   #10
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Aerowood
What size did you bore it out to?
Old 09-25-2015, 05:38 PM   #11
Usually, replacing the hinge pin takes acre of the loose hinge issue.
If not completely, it still does a good job.
Further adjustments can be made with the hinge itself. We can provide, if you wish, instructions as to how to do that.
Old 09-25-2015, 07:27 PM   #12
Aerowood's Avatar
Arvada , Colorado
.310, I then shrank fit .3125 (5/16) bushing. I used liquid nitrogen to shrink the bushing for installation
Old 09-26-2015, 11:18 AM   #13
The original hinge pin is .250 inches (1/4 inch).
It should be replaced with the same size.
Enlarging the hole in the hinge, is a difficult task, in that to start with, you would need a drill bit that's at a minimum of 15 inches long.
Then holding the 2 halves of the hinge in the proper relationship with each other, becomes another task.
Removing the original shaft , that has worn, and replacing it with the same size shaft, makes the task as simple as you can.
Old 09-26-2015, 02:35 PM   #14
Aerowood's Avatar
Arvada , Colorado
The hinge pin is made of stainless steel going through a cast aluminum hinge half, as the stainless pin is harder then the aluminum hinge half then the wear is on the pivoting hinge half causing elongation of the hinge half holes. As the hinge halves are no longer available, the only option for repair is to ream the elongated .250 holes and bush back to .250. This is not a complicated process and any good machine shop can preform this task. I am not a machinist and was able to do it in a couple of hours with a standard Bridgeport mill.
Door Hinge Pin Comes out 64Vette Doors & Locks 26 09-27-2007 04:34 PM
Door hinge pin? 65 overlander Doors & Locks 3 09-10-2005 01:04 AM
Top door hinge pin works out during travel? Kistler Our Community 4 06-20-2005 07:04 PM
door hinge worn not the pin silver 67 Doors & Locks 5 08-11-2004 08:30 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
