Old 08-23-2008, 08:14 PM   #1
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
'66 Overlander deadbolt
anyone know the source for the deadbolt lock? latch itself and strike plate still in place, but both exterior and interior lock cylinder are missing. Thanks!
goransons is offline   Reply With Quote
Old 08-23-2008, 10:32 PM   #2
Scott.
Post a couple of detailed photo's, so that I can see if someone installed a 67 dead bolt or something else.
A good photo of the dead bolt striker pocket area will also help.
Old 08-23-2008, 10:35 PM   #3
goransons's Avatar
1963 22' Safari
I'll do that tomorrow when we have daylight again. It is definately a stock striker (its cast into the door jam, and the striker is nylon). thanks
Old 08-24-2008, 09:42 AM   #4
goransons's Avatar
1963 22' Safari
lock photos
here's a couple pictures of what remains of the deadbolt. The one is somewhat blurry, couldn't get a better shot, but the lock bolt says "weiser"
thanks
Name:	IMG_3032 (Small).JPG
ID:	66132   Click image for larger version
Name:	IMG_3033 (Small).JPG
Name:	IMG_3035 (Small).JPG
Old 08-24-2008, 09:46 AM   #5
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Andy probably has them! He has everything...
If not you can also look here
http://www.vintagetrailersupply.com/Door_s/10.htm
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-24-2008, 09:51 AM   #6
thanks
Scott.
That deadbolt was first used in 1967, but some owners adapted it to the 66's.
That deadbolt has been history for way over 30 years.
I will see what I can come up with that could work correctly.
Also, from your photo's you need 2 of the nylon striker pockets. We have the original mold for them, as well as many in stock.
Old 08-24-2008, 10:00 AM   #7
goransons's Avatar
1963 22' Safari
Thanks Andy, yes striker plates will be on my order, along with weatherstripping for all the windows and doors. Whoever did the mod did a great job, impossible to tell the difference between the stock striker hole and the second (from the back of the jamb).
Please let me know of the lock if you come up with anything. The door itself is going to come off in the next couple weeks and have a great machine shop here fix two cracks in the door itself where the hinge attaches. It appears someon tried to get in with a screwdriver and broke the door frame just above and below the hinge mount. So the deadbolt and lock did it's job at some point. Have to replace the skin below the windows just forward of the door because of all the different dents etc from screw drivers, crow bars etc. Holding the door shut carefully with the cracks closed, the door does not appear to be warped, has even lines up both sides, and proper clearance for the weatherstrip.
Old 08-25-2008, 05:01 PM   #8
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Let me jump on this thread,instead of trying to figure out how to do a new one,there is a door for sale on ebay #180281818760 owner vdoes not know year,can one of you super smart people tell me if it will fit a 77 Overlander? I like the ider of it having a window,and I`ll be going right by there in a couple of weeks.Any help would be appreciated. Thanks,Dave
easyride is offline   Reply With Quote
Old 08-25-2008, 05:01 PM   #9
Scott.
This is the best that I can do. This came off of a customers coach strickly for the photo.
Old 08-25-2008, 05:09 PM   #10
No it will not fit your trailer, without extensive work.
The radius corners at the top of the ebay door are much different than yours.
You would have to do some sheet metal work, both in making the door fit, as well as changing the contour of the door. You would also have to install a new door jamb, requiring more sheet metal work.
That door is off of a trailer thats probably 25 years or more, newer than your trailer.
Old 08-25-2008, 05:14 PM   #11
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by Inland RV Center, In View Post
Scott.
Andy,
What year did that lock come off of? I need a new dead bolt for my Liner. The original dead bolt is a Yale.
Bill
Just my personal opinion
Old 08-25-2008, 05:15 PM   #12
easyride's Avatar
1977 27' Overlander
Naples , Florida
Thanks Andy I was hoping for your insight. Dave
Old 08-25-2008, 05:27 PM   #13
Originally Posted by wkerfoot View Post
Andy,
Bill
That dead bolt was used in 67 and maybe in 68. Some owners had it installed in 66's, but you had to take the sheet metal off.
I think in Scotts case, the entrance door was replaced, as were several thousands of them, because the cast door frame broke rather easily.
That dead bolt was common to Airstream, since it took a household lock, and modified it with that round shaft, to make it a dead bolt.
That dead bolt "IS NOT A TRAVEL LOCK".
You can open and close the dead bolt from the inside of the trailer, but you can only open the dead bolt from the outside.
Old 08-25-2008, 05:28 PM   #14
goransons's Avatar
1963 22' Safari
Thanks Andy, any idea on a source? (gather that person doesn't want to sell the lock?) I haven't had time to go do some hardware store looking, heard that perhaps I could use a mobile home lock if the throw was the same, that evidentially some of the older hometown mom'n pop hardware stores around here have some that are vintage, and made for a thinner door.
I'll check around and report back what I find.
deadbolt lock John Greenlee Windows & Screens 2 07-10-2004 09:33 AM
Deadbolt...... aviontt Doors & Locks 1 11-24-2003 08:46 PM
Deadbolt placement? Gunnyusmc All Argosy Trailers 0 09-12-2003 06:10 AM
Deadbolt Gunnyusmc Doors & Locks 2 09-12-2003 06:02 AM
deadbolt with inside twist style lock cindy Doors & Locks 4 10-16-2002 08:58 PM
