Old 08-25-2008, 06:32 PM   #15
Originally Posted by goransons View Post
Thanks Andy, any idea on a source? (gather that person doesn't want to sell the lock?) I haven't had time to go do some hardware store looking, heard that perhaps I could use a mobile home lock if the throw was the same, that evidentially some of the older hometown mom'n pop hardware stores around here have some that are vintage, and made for a thinner door.
I'll check around and report back what I find.
Save your time, as you won't find it.
Airstream took a household lock and modified it to work, and installed a small pin so as not to weaken the cast frame any more than they had to.
There are far better locks that that one, and again, it is not a travel lock.
Andy.
Old 08-25-2008, 06:32 PM   #16
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by Inland RV Center, In View Post
That dead bolt was used in 67 and maybe in 68. Some owners had it installed in 66's, but you had to take the sheet metal off.
I think in Scotts case, the entrance door was replaced, as were several thousands of them, because the cast door frame broke rather easily.
That dead bolt was common to Airstream, since it took a household lock, and modified it with that round shaft, to make it a dead bolt.
That dead bolt "IS NOT A TRAVEL LOCK".
You can open and close the dead bolt from the inside of the trailer, but you can only open the dead bolt from the outside.
Andy,
What is the difference between a dead bolt and a travel lock?
I will post a picture of the one remaining Yale dead bolt on my Liner tonight.
Bill
Just my personal opinion
Old 08-25-2008, 06:35 PM   #17
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Andy, if I'm doing some work on the door anyway, should I just patch that small hole and go without it? Don't want to leave a big hole, but have to do some tasteful repair in that area already.
goransons is offline   Reply With Quote
Old 08-25-2008, 07:39 PM   #18
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Andy,
Here are two pictures of my existing deadbolt. Any idea where I can locate a replacement?
Bill
ID:	66232   Click image for larger version
Old 08-26-2008, 09:34 AM   #19
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
This is what the PO did for a dead bolt on mine... Drill out the door and put it on the body... It isn't to bad of a job and it works... Not going to take it off thats for sure... And I use it..
ID:	66283   Click image for larger version
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-26-2008, 09:56 AM   #20
The previous owner did not do you any favors.
What he did has severely weakened the door jamb, and door frame.
That cast material breaks rather easily.
Old 08-26-2008, 10:06 AM   #21
purman's Avatar
1968 28' Ambassador
Yeah, I know... I have a crack at the bottom corner of the door frame. maybe even from this being pushed on once or twice...
But its there and I don't want to have to patch the exterior..
Got enough projects to do...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
deadbolt lock John Greenlee Windows & Screens 2 07-10-2004 10:33 AM
Deadbolt...... aviontt Doors & Locks 1 11-24-2003 09:46 PM
Deadbolt placement? Gunnyusmc All Argosy Trailers 0 09-12-2003 07:10 AM
Deadbolt Gunnyusmc Doors & Locks 2 09-12-2003 07:02 AM
deadbolt with inside twist style lock cindy Doors & Locks 4 10-16-2002 09:58 PM
