Old 01-01-2013, 04:57 PM   #1
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
'66 Ambassador door fix
I did a little work on the door of a friends 66 Ambassador. The PO did a number on this poor thing. I've seen some real hack jobs but man this was bad.
I've included some before and after shots.I must have forgot the after shot of the inside.I had a piece of an Airstream aluminum panel that I used as a patch,matches fairly well I think.
I had a partially complete L100 lockset that I installed. It's just missing a couple of parts. I need part number 12 which is the cam tube ring and part number 14 which is the inside cam. If anyone has these parts please let me know if you'd like to part with them. I'll buy or horse trade whatever you want.
ID:	175726   Click image for larger version
ID:	175728   Click image for larger version
ID:	175731   Click image for larger version
desertair27 is offline   Reply With Quote
Old 01-01-2013, 07:10 PM   #2
A lock kit is available, that replaces the L-100 lock, including the extended striker bolt.
Old 01-02-2013, 07:27 PM   #3
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks Andy
I looked up that specific lock you're talking about, very nice!
I'm trying to help someone out that can't spend much money on his trailer. I'll have to keep searching for those little parts.
Mike
