Old 11-03-2010, 08:10 PM   #1
rayandre's Avatar
1970 27' Overlander
Shaker Heights , Ohio
'65 overlander warped door
I'm considering buying a 65 overlander that had the door swing open while towing and unfortunatley got seriously "wrenched" and is now warped on the top and bottom edges of the door. Can anyone tell me if this is able to be repaired, how difficult or would it always be a problem? Do you ever replace them? I just wouldn't want to buy it if it's a serious issue. I'm trying to find out if the owner has checked for leaks-if not I'll take a hose to it!
rayandre is offline   Reply With Quote
Old 11-03-2010, 08:20 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I'd say yes it is serious if it is warped badly. It may be hard to fix and finding a replacement could be difficult and expensive if not impossible.
It is going to have some leaks, count on it even if the PO says there are none. Most leaks aren't too big of a problem to fix if you can find them.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-04-2010, 04:05 AM   #3
rayandre's Avatar
1970 27' Overlander
Thanks a lot. I had a feeling this would likely be the case-although there was a thread about bending doors back into chape on pre-69 models where the door was not cast but formed-
'68 Overlander door knob LI Pets Exterior Storage Compartments & Access Doors 5 04-07-2014 02:52 PM
Need Door for 1961 Overlander BentMetal 1960 - 1964 Overlander 9 07-28-2011 04:36 PM
Need Refrigerator Compartment Door for 1972 Overlander jazz1945 Exterior Storage Compartments & Access Doors 1 05-30-2011 02:50 PM
Moho generater door Smartstream Classic Motorhomes 23 05-16-2011 06:02 PM
Where can I get a tambour door for my '72 overlander? JackP Cabinets, Counter Tops & Furnishings 4 04-13-2011 11:42 AM
