Old 03-10-2008, 04:38 PM   #1
1962 24' Tradewind
Bowling Green , Missouri
'62 door knob not catching
We replaced the doorknob/lock on our '62 Trade Wind with a correct reproduction unit. The old had round knobs on both sides where the new one has a lever on the inside. Many times, the lever on the inside turns clear around instead of stopping, and some times unless you push in on it, it won't catch to open the door. I've been told there is wood inside the door near the lock, and that it has deteriorated, allowing the door to squeeze there a bit, causing the problem. However, when you take the door latch apart, it appears as though the square shaft inside is not fully engaging the square hole in the other side, as there are scuff marks on what appears to be a small brass guide. In other words, it looks like the shaft is not long enough. Also, you have to push in on the outside knob to get it to engage.
Any help?
retrocats is offline   Reply With Quote
Old 03-10-2008, 05:26 PM   #2
AirstreamGypsy's Avatar
1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
Any help?
Hi Retro,
Most likely this is the problem. However, since the inside knob(lever) spins around there appears to be more of a problem. Did all the correct pieces get installed.
A few years ago I installed a new door knob. My original would no longer lock. You could just push a little and turn firmly. Not the safest way to travel.
Ever since then I also have had to push on my door to get the lock to firmly latch. Either my door has shrunk (not an impossibility), changed it's shape (very likely) and, or the striker is not long enough.
Try starting over taking extra care to make sure the whole assembly is as far toward the appropriate side as possible. There is usually at least 1/8" play, sometimes more.
Good luck, hope this helped a little.
AirstreamGypsy
___________
Charter Member FCU WBCCI 1818 CP(Courtesy Parking) Wi-Fi
My Earthship
AirstreamGypsy is offline   Reply With Quote
Door knob not working on 1962 Bambi female.nomad Doors & Locks 4 11-11-2011 05:00 PM
New thing on youtube thats catching on fast AIR-Quarius Fun & Games 2 03-25-2011 09:23 AM
Catching up on pictures kingfisher24 On The Road... 2 03-13-2011 02:20 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
need door knob/lockset '61 Overlander 61Overlander Doors & Locks 1 12-01-2003 11:59 AM
