Old 05-30-2006, 11:26 AM   #1
1991 29' Excella
1970 27' Overlander
Crossett , Arkansas
Question 1991 Excella door problem
My 91 Excella door opens and locks just fine. The problem is that the door does not meet the frame at the bottom 25% of the leading edge (1/4 inch gap). This creates air entry at all times. The bottom door hinge pin stands out of the hinge hole by two inches (top one is fine). It can be taped back into place but will come out again. There is no visible reason for the problem. I plan on taking it to the dealer but have no idea what he may have to do or charge. Any information appreciated.
nursefnp is offline   Reply With Quote
Old 05-30-2006, 12:23 PM   #2
Condoluminum's Avatar
2016 25' Flying Cloud
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Rubber Weatherstrip?
Nurse-
There should be a black rubber hollow "quarter round" aircraft style weatherstrip glued to inside of door that makes contact with frame and provides seal against water and wind... Is that still there? Did prior owner possible replace with some other form of weatherstripping that doesn't seal completely? It is rarely sold in hardware or home supply stores...
One source is Aircraft Spruce and Specialty (http://www.aircraftspruce.com/menus/ap/doorseal.html ) which supplies parts for airplanes...
Hinge pins rising are not uncommon, and result from loosening after original installation including tap from bottom with punch to expand lower section and hold in place. Dealer could fix that relatively inexpensively as well, and will have ability to order weatherstripping from Airstream directly. Not sure wheterh more expensive from Aircraft places or Airstream, but it costs $$ per foot, not pennies...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Excella 1991 29' Fritz 1990 - 1993 Excella 7 06-20-2018 05:45 PM
Questions-31' 1981 Excella Sharon Lee 1981 - 1983 Excella 8 09-03-2011 06:56 PM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
78 Excella 500 davidz71 Our Community 2 10-17-2002 01:11 PM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 09:05 AM
