Old 01-13-2003, 07:13 PM   #1
Question 1976 door problem
I have a 1976 Tradewind. The door has been damaged from coming open while traveling. We are having wood floors put in and I am afraid of water damage!! What suggestions do you have for rebending the door to fit? Can we fix this problem or is there someone who specializes in body work? Can you get a new replacement door? What can we do to stop the door from coming open while traveling? PLEASE HELP!
Rennegarbe1 is offline   Reply With Quote
Old 01-13-2003, 07:53 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
1976 door problem
This is a problem that many Vintage trailer owners experience. Since there is some risk of either fracturing the inner skeleton of the door or the hinges, I would suggest seeking expert assistance. I know that I did, and am quite happy that I did. The door on my '64 Overlander now fits very well and is water tight. I have had two shops work on the door with very good results. P & S Trailer Service of Helena, OH performed the most taxing repair following having the door blown open and the door knob forced through the sidewall - - the door was as near perfect as one could expect for a coach of '64 vintage. Less than a month later, while on the road to have a new handset and deadbolt installed the door blew open again in transit and again had to be repaired. This time, Ace Fogdall RV in Cedar Falls, Iowa handled the repair (they are Iowa's Airstream dealer). I have been a customer of Ace Fogdall's for more than eight years and am totally satisfied with their service.
Good luck in solving your door dilemma.
Kevin
Kevin D. Allen
AIR #827
Old 01-14-2003, 08:48 AM   #3
There are several reasons why the door may fly open in transit.
1. Balance the tires, wheels, hub and drums as an assembly. The door area can and does flex.
2. The striker bolt is worn.
3. The striker pocket is worn.
4. The door is not proper fitting within the door jamb.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Old 01-15-2003, 02:49 PM   #4
Thank you so much for your input. I phones P&S Trailer Service today and they are going to have a look. THANKS AGAIN
1976 31' Sovereign-Bicentennial Edition dragonfly 1974 - 1979 Sovereign 2 02-04-2006 09:21 AM
1976 Argosy tire replacement chasgould Electrical - Systems, Generators, Batteries & Solar 8 03-07-2004 07:55 PM
1976 Overlander davidz71 Our Community 2 09-24-2002 07:48 PM
