Old 12-15-2007, 07:51 AM   #1
irishairst's Avatar
Northern KY , Kentucky
'03 Bambi 19' door wouldn't lock
winterized and parked unit in tempoarystorage. stopped yesterday to find some camping equiptment inside unit. no sign of forced entry. door unlocked okay as did the dead bolt.
went to secure door and it would not shut tight or lock. appeared to have a bow to center of door. checked weather stripping etc and door still would not shut tight to secure the locks. again pondered someone broke in but no signs of any prying. leaned against door and tried to force shut. still no luck.
called airstream survice. mentioned to move trailer and ascertain setting level or close to it. talked about adjustment and weather sealing.
well returned to unit, pulled ahead and leveled again.
loosened the stub bolt in door jamb. shut door and to my amazment the jaws to the lock set grabbed the bolt just fine. the dead bolt also locked fine.
re-tightened the stub bolt but not real tight. it self adjusted and locked door just fine.
saved a trip for service and the thought of door replacement. phew!!!
RH MH
irishairst is offline   Reply With Quote
Old 12-15-2007, 08:23 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Did you have the stabilizers down when you stored the trailer? If you did, the trailer may have settled on the axles a little bit putting too much weight on them and flexed the frame enough to cause the problem.
Glad to hear that everything is working great now!
Richard
Old 12-15-2007, 08:29 AM   #3
westernviews's Avatar
2013 27' Flying Cloud
Livingston , Texas
I have trouble closing and locking my door when the trailer is not level side to side.
Westernviews.us
westernviews is offline   Reply With Quote
GOING ALL THE WAY? why wouldn't it be safe? purman Tow Vehicles 6 06-26-2012 07:00 PM
... 'they' said it wouldn't work. FreshAir Audio, Video & TV 6 06-14-2009 10:56 AM
Would you or wouldn't you? yukionna Off Topic Forum 14 07-02-2008 08:06 AM
Newbie, and I said I wouldn't buy sight unseen. Wexus Member Introductions 27 03-10-2006 01:11 PM
Wouldn't this make a cool tow vehicle... InsideOut Tow Vehicles 6 08-09-2003 08:59 PM
