Old 12-22-2015, 10:33 AM   #1
2014 22' FB Sport
Los Osos , California
Where to run cell booster cable into coach
I have searched without success for some ideas on this. We have a cellular booster antenna to install on the roof of our 2015 25ft FB flying cloud.
My main question is where is the best spot to run the cable into the coach? Is there a roof vent that you can snake a cable through or do we have to run a cable down the outside through a window etc?
I'd appreciate any help on this.
Jeff
Schipperke is offline   Reply With Quote
Old 12-22-2015, 11:02 AM   #2
2014 22' FB Sport
York , Pennsylvania
I have a Wilson Sleek. I put some sticky backed magnets on the roof for the antenna and then I open the escape window(red latches) and then run the cable through that window. It closes and latches just fine. Not a permanent mount but it works great.
wozzy53 is offline   Reply With Quote
Old 12-22-2015, 11:11 AM   #3
Images: 59
I mounted a steel plate on top of the air conditioner shroud, then ran the cable through the shroud, down the air conditioner roof opening and out the corner of the ADB (air distribution box) and into the nearby pantry where I mounted the Wilson box.
Old 12-22-2015, 11:32 AM   #4
2011 27 FB International
Vancouver , British Columbia
In our 27fb, ran the cable through the fridge vent and into the compartment above the fridge, which is where I locate all my communications equipment. I plug directly into a hotspot rather than using the internal antenna.
mixedpuppy is offline   Reply With Quote
Old 12-22-2015, 02:15 PM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Run it through the fridge vent.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 12-23-2015, 10:14 AM   #6
fth
2003 39' Land Yacht XL 330 hp w/2slides
Fairlawn , Virginia
I mounted the antenna on the flagpole and ran the cable through the battery box door on a 2005 Classic 30. But I'm thinking of mounting it on the TV antenna and running the cable through the roof next to the radio antenna which is in front of the bulkhead and then I would snake the wire down to the front locker where the radio is, pick up 12V there and have the equipment in that locker with the radio. A lot of people don't like making holes in the shell but if done properly it's not any worse than any of the other holes in it.
fth is offline   Reply With Quote
Old 12-23-2015, 11:31 AM   #7
Nomadic , USA
I tried this but it didn't work out for me. But that's a great idea. You can also buy water proof cable grommets that clamp around the cable.
Old 12-23-2015, 04:47 PM   #8
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I've had great success running antenna wires through the gray tank vent. This vent pipe is in the corner of the closet and I just drilled a hole through it and snaked the wire through. I've also got wires coming through the fridge vent (solar, Winegard sat. TV). I have yet to drill ANY holes in my roof.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 12-23-2015, 05:42 PM   #9
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Most installations I know of run the wire down the fridge vent. In our case, the booster itself is in the small cabinet above the fridge so the fridge vent was perfect.
Bob Martel
WBCCI# 5766
Old 12-23-2015, 06:15 PM   #10
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Shouldn't the cable be run to a place very close to where you expect to use your cell phone? My impression of boosters is they offer boosted signals only within a foot or so of the booster.
kscherzi is offline   Reply With Quote
Old 12-23-2015, 07:50 PM   #11
Nomadic , USA
Depends on the booster you are using. Some are cradle only. But most of the ones that you mount have an external and internal antenna with some distance between both.
I use my own antenna's and cables, so mine comes down the vent, is mounted behind the TV and the antenna is over the dinette.
Old 12-23-2015, 08:08 PM   #12
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
I haven't seen the OP respond back on this, but I do not think the 25 Flying Cloud has a fridge vent on the roof. They use a side panel with a fan, which is in many cases very noisy. At least mine was. The gray tank vent is a good idea. Following thread as I too am looking to do same and will probably use the fridge vent on my 28FC. Appreciate the discussion by all.
Chuck
silverlabs is offline   Reply With Quote
Old 12-23-2015, 09:33 PM   #13
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Chuck
This is true for the 25RB not sure about the 25FB. I had a pro cut a hole above the dinette and feed cables in for me...
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 03-07-2016, 07:42 PM   #14
2015 23' Flying Cloud
Livermore , California
Does anyone have experience routing a cable into a Flying Cloud 23D and booster placement?
cactusjk is offline   Reply With Quote
Cell Phone Booster - Verizon pdozanne On The Road... 5 11-29-2012 07:37 PM
Cell Booster? gaylejoe Phone, CB & Ham Radio 5 05-14-2011 10:10 PM
Cell Phone Booster gaylejoe Phone, CB & Ham Radio 10 11-15-2007 12:19 PM
cell phone booster norbert Off Topic Forum 10 11-19-2005 07:41 PM
