Old 06-13-2007, 01:01 PM   #29
2005 30' Classic
Images: 12
Originally Posted by waynemorgan
any body use GMRS my wife and me use them at wal-mart and the swap meet ( so i can hide from her) ...they work great at hunting camp and rv camp grounds
Exclusively.
If they have a designated CB channel, then maybe a FRS/GMRS designated channel is in order!
FRS/GMRS units are a lot cheaper, and I would think, owned by more members.
GetOutDoors is offline   Reply With Quote
Old 06-13-2007, 01:34 PM   #30
wanderer1's Avatar
1986 Argosy
ocala , Florida
Images: 24
Originally Posted by tjstew
Jerry,
Any channel is fine with me. I was thinking about getting a the RadioShack handheld model... any recommendations or other suggestions on hardware?
Yes you guys,they still make cb radios.Mr.TJ,do not get a hand held unless you also buy a external antenna.Steel roofs on t/v will reduce the range.I'am a trucker and my suggestion for best/least cost is to buy a "Cobra 25",buy a 'Wilson" magnet mount antenna (magnet makes your roof a ground plane)And a good co-ax cable.Get 'em on sale at larger truck stops.All you need to talk will run 'bout $100. for radio,$65. antenna,& $10. co-ax.That'll get ya going!Also to extend range and get "swr" set,find a cb shop (near truck stop) and have radio peaked/tuned if you want.You can go upwards of $700. on a strong radio w/channels you'll never use + ham license.I myself run a "Galaxy 48 t" ($550) w/Wilson t2000 antenna's.Need more info,give me a shout....Brian
wanderer1 is offline   Reply With Quote
Old 06-13-2007, 01:53 PM   #31
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Brian,
I have always had a question about that ground plane concept. I can see why it would improve reception with a drilled hole mount with metal to metal contact, but the magnet not making direct contact through the paint layer makes me wonder.
This from someone who knows almost nothing about it, just wondering why/how it works.
Dave
Fyrzowt is offline   Reply With Quote
Old 06-13-2007, 02:17 PM   #32
wanderer1's Avatar
1986 Argosy
ocala , Florida
Images: 24
Hello Fyrzowt,Just what I've learned around radio shops,something to do with placeing the antenna in the center of the roof makes the roof raydeate (spelling) the signal much better.And the magnet being a larger stronger contact area than a clamp-on type.Radio shop guys told me a mag mount will make the whole roof act like a much larger antenna.If ya really want get out,they say a full size van w/magnet in the center can not be beat!
Old 06-13-2007, 03:13 PM   #33
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Originally Posted by 85EXCELLA32
"13" is good it's kind of a first number for the teen years anyhow and we all remember 13.
Not me, I remember 15 as that when thing really started happening!!
Pop Rivet is offline   Reply With Quote
Old 06-13-2007, 07:01 PM   #34
waynemorgan's Avatar
1976 23' Safari
geary , Oklahoma
Originally Posted by Spiffy Gem
Exclusively.
so we can just use ch # 20 for calling and go from there ?
AIR # 20946
waynemorgan is offline   Reply With Quote
Old 06-13-2007, 07:35 PM   #35
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 21
Send a message via Skype™ to Airstream25
CB Channel to use while on the road
Based on the info below, it would seem the best channel to monitor would be 14. Once you make contact, then if you wish, you can move your conversation to any other channel.
Originally Posted by Airstream25
The the 49th International Rally in Salem, Oregon
has posted the following information.
If folks are used to using Ch 14 at International then perhaps it makes sense to just use that channel everywhere. If a common channel is adopted, it would be possible to "give a call" to those we pass on the highways.
11. C B “CITIZEN BAND RADIO”
This can be very important. Its use at the International Rally
keeps you informed daily of changing rally news and weather. The
“CB” Rally Base Station is known as “Wally Byam Control”
(Channel 14) and is open for your inquiries or emergency calls.
They, as well as the Amateur Radio Club, assist caravans and
others approaching the rally grounds. For suggestions in purchasing
and installing a CB, ask a unit member. Many have one,
sometimes two, one in the car and one in the RV. When traveling
with others a CB becomes invaluable.
12. AMATEUR RADIO
This is another valuable group who assists in numerous ways
at the rally. If you are a “Ham Operator”, let this group know of your
interest.
Airstream25
KE5CKG on 2 meters
AIR #10274
Airstream25 is offline   Reply With Quote
Old 06-13-2007, 07:39 PM   #36
1995 25' Excella
1982 34' Limited
Images: 21
Ground plane
DC current does need direct contact of conductors for the electricity to flow however at radio frequencies, the electrical energy can move through the thin air from the transmitter to the receiver. This distance can be miles. By comparison, 5 or 10 thousands of an inch of paint is no problem.
Originally Posted by Fyrzowt
Brian,
Dave
Airstream25
KE5CKG on 2 meters
AIR #10274
Old 05-27-2008, 11:03 PM   #37
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Purchased a Radio Shack handheld CB a couple of days ago. Looking for a Wilson antenna now. For me, the handheld unit is more flexable than a unit mounted in the vehicle.
gaylejoe is offline   Reply With Quote
Old 06-08-2008, 10:03 PM   #38
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
When traveling alone, I'll have the mobile CB installed set to channel 19 as I drive 18 wheelers. I'll have my hand held plugged into the lighter outlet & monitor channel 14 for other RV'ers who might call out.
3 Dog Nite is offline   Reply With Quote
Old 06-09-2008, 01:30 AM   #39
bci
Computer Consultant
bci's Avatar
2007 30' Classic S/O
Chino Hills , California
Send a message via Skype™ to bci
I have a handheld CB wired to an antenna in my roof. I normally have the system scan channels: 9, 14, 19. It stops if a signal gets past the squelch setting. I normally will move the call off to Single Side Band (SSB) in the 30-40 channel range if possible.
The best reason for the center of the roof install is to shield the passengers from RF energy the antenna is putting out. Warning, believe it or not, some people run more then 5-10 watts out their CB radios...
If you are a ham, I also monitor the Wins System repeaters and simplex on 147.54. Call: N6ROQ
Jennifer & Kent Behrends
Artemis' Chariot - 2007 Classic 30so
Blue Ox - 2004 F350 6.0l Diesel, Manual, 4x4
WBCCI #7192
N6ROQ
bci is offline   Reply With Quote
Old 06-11-2008, 07:39 AM   #40
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
For those that do not understand; radio waves do not travel in a straight line as most would think, radio waves bounce like a ball, thus they need something to bounce off from the ground, and the atmospheric cealing, anything in the way thus stops the signal or bounces it in another direction. This is why you hear about line of site because things in the way of a radio signal has a tendacy to stop or redirect the signal, this is also why it is hard to talk to someone over a distance that you can not see them, not that it can not be done, but it is restricted. The centering of an antenna in the roof creates an area for which the signal to bounce off from commonly called a ground plane.
Why a mounted antenna is better than the magnet; everything that puts out/receives electricity (radio waves are basically electricity) needs a ground. The mounting of an antenna grounds this to the system, the same ground that your battery and all electrical stuff in your vehicle is grounded to.
On Channels, Ch 1 is commonly known as the Harley channel and used by Harley riders, 21 is known as the Honda channel used by honda riders, 32-40 is commenly used by people shooting skip (long distance transmissions), 9 emergency channel monitored by some police, 19 is the truckers channel and comunication on this channel do not expect more than 1/4 to 1/2 because of the amount of people on this channel.
Ham Radio & SSB- you should not use these unless you are licensed to do so, fines can be quite high, cost to get a license is very little but offers you a much longer range of comunications through repeaters, and much clearer.
SARGE/AF is offline   Reply With Quote
Old 06-11-2008, 07:47 AM   #41
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Welcome to the AirForums, Sarge! Thanks for that info on the MC channels for Harley and Honda riders. I wasn't aware of that! Very interesting.
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-13-2008, 04:11 AM   #42
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
CB dedicated channel
Your welcome, and thank you, I thought I would chime in on this because I belong to many different organizations and it is nice to be able to communicate with others when passing them or near them. Unfortunately CB radios do not have very good distance (1/2 to 1 mi) unless you want to go illegal. This is why I got my ham radio license, much further distance (few miles to several hundred) and you have clear channels, no listening to cusing, hollering, and weird sounds, like on CB 19 and other channels. To get a Ham license is very inexpensive and the equipment is not much more than what you would pay for a good CB. I personally have 1 mobile unit and 3 handhelds and use my handhelds 98% of the time. I would really like to see the A/S community go over to the Ham radio and thus allow us to communicate better.
Sarge
Fuzzy Schlegle Channel Darel Windows & Screens 2 07-29-2008 04:11 AM
History Channel Repeat !!!!! flamingo-kid1 Off Topic Forum 1 10-25-2003 12:37 PM
Wheel Estate - History Channel 7/16 9pm ViewRVs Our Community 25 07-21-2003 12:29 PM
Calling ChicagoLand Airstreamers Chitown AirStreamers General Repair Forum 5 05-19-2003 03:13 PM
"RV Today" on OLN channel BobbyW Our Community 3 09-26-2002 10:55 AM
