Old 01-14-2010, 02:52 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Remove Antenna Crank
I am in the process of replacing my floor and taking the lower skins off.(65 Amb)
Is there a set screw on the antenna crank to remove it ,or is it done from the outside? Can't seem to find it.There is a hole on the bottom of the handle but a screwdriver or allen wrench won't catch anything.
I've never seen so many rivets! Thanks,Steve
bwaysteve is offline   Reply With Quote
Old 01-14-2010, 03:23 PM   #2
VIKING's Avatar
Boulder Creek , California
Hi Steve,
I think there was a set screw on mine, in the hole you are refering to. I can check it tonight if you don't have a good reply by then. There were mostly straight screws in my Safari. Very few phillips, and no allen screws. Can you get an eyeball and a flashlight in the same place at the same time? It's not easy with these things that are right up against a wall.
Good luck,
Rich the Viking
VIKING is offline   Reply With Quote
Old 01-14-2010, 05:58 PM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Rich,I will try to get a look tonight.Got the elec.refer out(po cut 6 in.off bottom of shroud!) and the Magic Chef oven.
Lots of surprises such as rotin back of counter from former leaks,and more flat head screws I don't care to mention(will need an easy out for a few.)Got a few panels off and the insulation looks good(no critters) ,but the antennna crank is holding me up.
Thanks for the response.Steve
Old 01-15-2010, 04:21 PM   #4
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Found it.There is a flat blade set screw very hard to see and takes a very small screw driver.Thanks
Help me remove this darn antenna!!! NicheVintage Electronics & Connectivity 6 10-06-2009 06:54 PM
TV Antenna - Would you replace or remove it? vhord Audio, Video & TV 35 05-18-2009 11:20 PM
Want to remove antenna from 1974 Sovereign imeynstein 1974 - 1979 Sovereign 9 01-03-2009 07:59 PM
345 will not crank cajuncruiser Classic Motorhomes 6 04-13-2008 09:06 PM
Want to remove antenna. Happycampers Audio, Video & TV 7 04-20-2004 08:00 PM
