Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Phone, CB & Ham Radio
Old 02-16-2007, 08:54 AM   #1
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Question Radio Antenna
Original OEM antenna broke off at rubber block. Motorola Radio w/8 track. Thinking of keeping OEM radio but might add casette/CD below in storage area. Is there a replacement antenna or repair kit for original. What is good system for cassette/CD install? 1971 Overlander Int.
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 02-16-2007, 08:58 AM   #2
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Good morning- I would probably replace the Original OEM antenna with the newer one used on todays AS. If you want to stick with the original post on the wanted to buy section of the classifieds. Do they still make cassette players? Check out www.crutchfield.com they are one of the best suppliers when it comes to audi/video. Even if you don't buy from them, great source for research!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-16-2007, 06:48 PM   #3
niftypkg's Avatar
Cornville , Arizona
Thanks again Rick. Thought I could replace the antenna without routing in another one.
Old 02-16-2007, 11:00 PM   #4
Profile:  1972 27' Overlander
cass , Texas
I have a digital synthesized am/fm stereo cassette player with dolby nr system. Custom manufactured for radio shack. Realistic cat. #12-1903 with digital clock display. Just in case you want to upgrade from your 8 track? I even have the owners manual. I have XM in my truck. I am thinking about wiring it up to my trailer radio. Switch the unit from the truck to the trailer, when needed.
krazeekalvin is offline   Reply With Quote
Old 02-17-2007, 04:09 PM   #5
niftypkg's Avatar
Cornville , Arizona
Smart move. I have to work on this project.
Old 02-17-2007, 04:20 PM   #6
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
I got a generic replacement @ Napa
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
amateur radio antenna for motorhome white1949 Our Community 0 01-01-2003 11:17 AM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 07:28 PM
Antenna Wiring niftypkg Electrical - Systems, Generators, Batteries & Solar 1 09-22-2002 02:04 PM
Where do you suppose they put the antenna jack -73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 12:34 PM
