Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Phone, CB & Ham Radio
Old 05-28-2002, 04:12 PM   #1
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Old CB ball mount
one of the previous owners installed a CB ball mount that has since lost 1/2 of the ball and the black 3 screw mount is starting to deteriorate, leaving black streaks down the side of my trailer. It is mounted on the street side and the cable is accessible from one of the rear wardrobe cabinets. I want to eliminate this eyesore but would like suggestions on a clean repair. I have extra alum. sheeting left over from my tire blowout fiasco coming back from AZ. Would a round patch riveted into the 3 screw holes and vulcum to seal it work out?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-28-2002, 04:20 PM   #2
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
A patch would work, but I would add about 3 more Olympic rivets just to be on the safe side. I think the aluminum patch would be less noticeable than the following solution...
I know they make patch plates for these. I have not seen them lately, but they used to be listed in Ham Radio and Radio Shack catalogs. Some Hams just can't seem to cut enough holes in their vehicles. I know I bought one from Radio Shack back in the late '70's. I had one of those big old whip antennaes on a Custom van I owned and had to remove it for resale.
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 05-28-2002, 06:54 PM   #3
davidz71
davidz71's Avatar
Bobby,
I remember those patch plates myself but in looking on the internet for CB supplies I did not see any listed. I will probably go with the patch idea because it will blend in better. With 6 olympic rivets I think is will look first class, I hope!
Craig
AIR #0078
3.73 rear end
Stainless Steel Antenna Mount on AS Body gklott Electrical - Systems, Generators, Batteries & Solar 2 11-17-2003 11:00 PM
silly ball height question. AV8 Hitches 7 11-09-2003 05:32 PM
Help-Hitch Ball problem Chitown AirStreamers Hitches 4 07-22-2003 12:35 AM
Multi- ball Set Up niftypkg Hitches 3 04-10-2003 09:02 PM
Ball Size on '70 Caravel? MattyBoy Hitches 3 01-06-2003 08:03 PM
