ok i put a new radio in my airstream and it has a loud buzzing noise thorugh the spearkers.i thank it is from the charging univolt maybe ..any ideals .thanks CW.V
What kind of radio? Is this a replacement? Any similar problems with previous radio? Does it buzz when both the trailer is hooked up to 110 and only running on 12v? Is your 110 polarity correct? What happens with only one speaker hooked up? Did you check your speakers are not hooked up out of phase (+ an - mismatch) Are you sure you have a good ground? Can you contact the manufacturer for a troubleshooting list?
Pay no attention to the man behind the curtain- WoZ
The older Uni-volt converters are notorious for causing noise in the radio. The filter capacitors go bad and that is what causes the AC noise in the radio. The best thing to do IMHO is replace the converter with a new better quality, and better filtered converter.
