Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Phone, CB & Ham Radio
Old 11-23-2007, 08:12 PM   #1
N2XBW's Avatar
Profile:  Norfolk, In The Beautiful Saint Lawrence Valley of Far-Northern , New York
Exclamation Magmount Antennas on an Aluminum Airstream?
On our recent trip from TX to NY I wanted to mount my computer's magnetic cell phone antenna and a magnetic Sirius Radio antenna to the roof of my '84 Excella 270 MH.
Now, we ALL know a magnet will not be attracted to the aluminum of our rigs, so what to do?
A quick trip to the hardware store and a 30 cent investment yeilded 2 large FENDER WASHERS. I simply asked for the largest they had and received two that were about 2 inches across.
I affixed DOUBLE SIDED FOAM TAPE to one entire side of each washer, then mounted them on the roof of the Excella. The mild steel in the washers provided enough attraction to keep the antennas in place for the entire trip.
The small wires I ran into the upper corner of the sliding passenger window and was able to close the window after gingerly allowing the wires for both antennas to get used to their bent condition.
The fenderwashers and their tape are invisible from the ground. All you notice are the the two neatly mounted antennas with small wires to the window corner.
It was CHEAP [like me], and it WORKS [not like me]!
Happy Trails!
John Wolfe
N2XBW
N2XBW is offline   Reply With Quote
Old 11-23-2007, 08:47 PM   #2
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Sounds like someone with ham radio experience to me.
Good solution
Garry
Old 11-23-2007, 09:07 PM   #3
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Airstream Registry
Hi, N2XBW. You answered your own question; I was going to say the same thing except for cutting a piece of sheet metal [steel] to the size and shape you need and use double sided tape. I'm still looking for an Aluminum Magnet.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 11-24-2007, 07:29 AM   #4
moosetags's Avatar
Santa Rosa Beach , Florida
Airstream Registry
I like that idea, thanx.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 11-24-2007, 10:55 AM   #5
Motoman's Avatar
Profile:  2005 25' International CCD
1960 18' "Footer"
Riverside , California
A good solution for cellular and satellite radio. That method worked well for receiving and for the cell phone which is relatively high frequency and the washers provided the ground plane. However it may not work for amateur radio transmitting at lower frequencies since at 2 meters or 146-148 mhz the antenna works best if centered on a metal surface that is at least 38 inches wide that is connected to the braid side of the coax. The double stick tape might insulate the base of the mag mount from the roof. Making sure that the radio is well grounded to the body of the Airstream at some point with a short piece of wire braid would eliminate any problem.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 11-24-2007, 03:09 PM   #6
N2XBW's Avatar
I've hit upon a possibly simple solution for 2m ham antenna mounting.
I plan to use an electrical junction box cover plate for the ferrous metal base. These are about 83 cents each at Home Depot. To the plate I will solder a short [1/8 wave=25cm] bronze brazing rod radial into a hole drilled at each corner to furnish an acceptable ground plane. I may give the whole business a coat of metal primer and then flat black to prevent future rust streaks and give it a finished look.
Then the assembly will be foam taped to the Excella's roof, then set the magnetic antenna on it. It should work.
Another option would be to omit the radials and internally run a ground wire from the antenna braid directly to the airstream's body as suggested above.
It's pretty cold here right now [+8F last night] so I'll wait till we get a warmer spell to test any of this.
So Long, And Thanks For All The Fish
Old 11-24-2007, 06:03 PM   #7
jdalrymple's Avatar
Profile:  1981 31' International
Siloam Springs , Arkansas
I may be missing something here, but if the DC voltage is coming from the TT, won't the radio "see" the aluminum as a ground plane via the coax shield?
Jeff & Cindy
Remi & Hunter
'81 International 31'CB
WBCCI #7026 Air #17054
"Fus-A-Lodge"
Old 11-24-2007, 07:43 PM   #8
Profile:  1991 34' Excella
Brandon , Mississippi
Originally Posted by Motoman
... The double stick tape might insulate the base of the mag mount from the roof...
Put a countersink screw through the washer into the roof. Big-O-ground plane
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy
Digital TV Antennas Pop Rivet Audio, Video & TV 19 02-23-2007 09:12 PM
TV antennas ckeysor Audio, Video & TV 0 09-06-2006 07:44 PM
CB Antennas noiva General Motorhome Topics 7 06-30-2006 07:04 PM
Funky Antennas! robandzoe Electronics & Connectivity 7 05-05-2006 11:25 AM
TV antennas ketchumwt Our Community 2 10-02-2003 10:41 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
