Old 04-03-2016, 12:05 PM   #1
AlumaTurtle's Avatar
Olean , Missouri
HF antenna decisions
I have purchased a scorpion SA 6610 antenna. I would like to run a few things by you to get some Ideas.
Current plan is to mount the antenna behind the ford f150 cab on the pickup bed. with a fiberglass shell about 8 inches behind the antenna. My reason for selecting this is I want to be able to boondock, and move my location, realizing that where the trailer is parked, may not be the best operating position. but if I want to move inside to operate i can attach a 50' coax and use the mobile setup as a moveable antenna.
Is my logic sound? all answers pro and con welcome.
Dave
AA0AE
Dave
AA0AE
AlumaTurtle is offline   Reply With Quote
Old 04-03-2016, 12:10 PM   #2
2015 30' Classic
Pleasanton , California
And will you add a 50' control cable for the antenna and a second controller?
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 04-03-2016, 12:36 PM   #3
Olean , Missouri
yes I figured that that would go without saying. altho I wondered about voltage drop.
Dave
AA0AE
Dave
AA0AE
Old 04-03-2016, 01:23 PM   #4
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Have you been to Alan Applegates site?
It made my HF installation possible!
Alan is always there to answer questions you might have too...
73
AB1KC
http://www.k0bg.com/
Bruce B is offline   Reply With Quote
Old 04-03-2016, 02:26 PM   #5
2015 30' Classic
Adding 50' of additional RG-58 results in about 1.75 dB of loss @ 10 MHz. So if you plan on operating on 10 meters (28 MHz) you might want to consider something less lossy. Otherwise post back what your results were.
73s
Al, K6IV
Old 04-03-2016, 02:38 PM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I never had one, but the Scorpions look like terrific antennas.
Just curious, what is it about the trailer location that you think might not be suitable?
With only one antenna, I can see having it on the truck for use in motion. I have a Tarheel on the roadside at the bumper and I'm planning a High Sierra screwdriver antenna (which I replaced with the Tarheel when I erroneously thought it wasn't working as well as it should) with a HB lift and lay mount on the roof of the trailer. Jim, N5RTG has one and it seems to work really well. He also carries a G5RV dipole and a multi-section fiberglass mil-surplus mast when he wants a better antenna.
Incidentally, W4RP's loss tables show 1.4 dB for 100 feet of RG-58 (which is 1/4 of an S-unit) at 10 MHz and 2.5 dB at 30 MHz. By his tables, RG-58 would be 0.7 dB at 10 MHz and 1.25 dB at 30. I wouldn't sweat losses at this level.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-04-2016, 07:10 AM   #7
Olean , Missouri
Al[/QUOTE]
Not really worried about the location on the bed of the Pickup, but I have always been taught that anything that can react with the radiation pattern of the antenna is to be avoided. I would like equal radiation of the signal, like a ground mounted vertical, and not have any signal blocked by the cab of the pickup.
Not sure that it would change the radiation pattern or not, that is why i put this out for discussion. and since I am spending the money for the antenna, I want the best use of it.
Dave
AA0AE
Dave
AA0AE
Old 04-04-2016, 07:14 AM   #8
Olean , Missouri
73
AB1KC
Bruce
Yes that is the first place i went. a must read.
Dave
AA0AE
Dave
AA0AE
Old 04-04-2016, 07:20 AM   #9
Olean , Missouri
73s
I haven't considered the loss on 10 meters, My main idea's have to work lower bands in trailer, with my ten-tec omni 6+ with lp-pan, and higher bands mobile.
Dave
AA0AE
Dave
AA0AE
Summer Ventilation Decisions DKDarrow General Interior Topics 4 06-28-2009 01:52 AM
decisions... thehugguy Member Introductions 5 09-13-2007 09:01 PM
Truck Decisions wannastream Tow Vehicles 107 04-05-2007 08:50 PM
More Truck decisions... on the small side AirstreamGypsy Tow Vehicles 5 03-28-2007 01:08 PM
My new axle decisions fastrob Axles 2 05-01-2006 05:27 PM
