From what I hear, it is something that helps coming in. We are taking ours with us.
__________________ Laura Miss Rivette 2008 W8JUZ --......-- "Support Search and Rescue, GET LOST!!!!" Operation "SAVE RUDY" Strike Team (Charter Member)
Yes, we are planning on taking our Handheld, and around that area of Bozeman, it should be just fine!
One of my sons has a hand held CB in his truck. He has a connection where he can connect an external antenna for additional range and clarity. It works for him.
__________________ Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
We've used a Cobra brand portable for four years. Our family has used this brand since the CB craze of the late 70s.
Power and performance are good for caravanning, and professional OTR drivers still provide traffic reports when asked. The magnetic antenna easily goes on and off the top of the truck, coax cable thru the window, and the whole setup conceals easily under a seat when not in use.
Only problem we encountered was alternator whine - requiring either an aftermarket noise filter - or the easier solution: running the radio on internal batteries rather than the 12V plug.
The external antenna mentioned above is a huge improvement over the very inadequate antennas the hand helds come with. Look to Wilson for quality Mag mount models. The door gasket generally has enough flex to close on the antenna lead so no modifications are required.
__________________ Airstream25 KE5CKG on 2 meters Four Corners Airstream Unit AIR #10274
What kind of range should I expect with the handheld. So far I'm not impressed with it. I get a 5 mile range with a handheld nav/com aviation radio with the antenna which came with the unit. We have 2 cheap Cobra's walkie talkies that have a great range but this CB handheld right now is the pits. I was wanting to use it on the ground in Bozeman but now I have my doubts.
I only get about 100 yards range with my Radio Shack hand held CB using the little "rubber ducky" antenna that it came with.
CB radio waves are about 11 meters. Typical car roof top external antennas are 1/4 wave length or about 2.25 meters and extend the clear range to a few miles. Range to the rear that is obstructed while towing an Airstream will be a lot less.
FRS (Family Radio Service) and GMRS (General Mobile Radio Service) radios might be what you are referring to with your general comment about "Cobra's walkie talkies". They operate with about 0.7 meter wave length so adequate antennas are a lot shorter than what a CB requires.
FRS is limited to about 1/2 watt power but GMRS can go up to about 5 watts making them a much better choice.
In my opinion, a CB radio with an external antenna is the best choice (other than a ham radio ) while driving and a GMRS radio is the best choice when walking.
I've never put batteries in the radio, using the lighter plug instead, and never used the rubber ducky antenna. It's worked well for trips over the road.
We have an extended cab truck. We keep all kinds of stuff on the floor below and in front of the rear seat. The mag mount CB antenna stays there when not in use. So does the mag mount 2m/70cm ham antenna. We use mag mounts because the truck only clears the garage door by less than 3 inches.
