Old 11-20-2002, 04:49 PM   #1
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Question Ham Radio in A/S
Okay,
how many A/S owner do we have out there who are Ham Radio operators?
K4NEH
53flyingcloud is offline   Reply With Quote
Old 11-20-2002, 04:51 PM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Wow, I was just thinking about this today, wierd. I am WA8ZYT.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 11-20-2002, 06:05 PM   #3
Dr Joe
winner's Avatar
Central , South Carolina
I am a Ham - my callsign is KD8VD. I became a member of ARC
The WBCCI Amateur Radio Club expecting to see quite a bit of interest in Ham Radio in Airstreams, but todate the activity if Zero.
I probably will not renew my membership unless there is some activity in the club.
Dr Joe & Winn
Emeritus Airstreamers
KD8VD
winner is offline   Reply With Quote
Old 11-20-2002, 06:39 PM   #4
Gordon Watt's Avatar
VE4 IF in Winnipeg. Haven't been active for a few years but I have just bought a Yaesu 817 and am trying to figure out how make it work. In the summer I'm in Thompson, Manitoba where I live in my Airstream.
Echolink # 57034
Gordon Watt is offline   Reply With Quote
Old 11-20-2002, 07:44 PM   #5
buckmaster's Avatar
1965 20' Globetrotter
1970 31' Sovereign
1972 25' Tradewind
Newport , Oregon
KC7NTT here on the Oregon coast
buckmaster is offline   Reply With Quote
Old 11-21-2002, 12:18 AM   #6
1984 29' Sovereign
Savannah , Missouri
Thumbs up kewl~!
This is most interesting~!! Greeting~
I have a ftdx-757 that, I'm looking forward to using once other projects are completed.
Like to hear abt any ant, etc ideas that have proven to work..
Okay, since we've started that..."Another question.."How many of you have heard of ECHOLINK??
ciao
BTW, Maybe we can talk ANDY into giving us our own little spot under Airstream Community Forums?? Anyone interested in that?
Old 11-21-2002, 07:03 AM   #7
Dr Joe
winner's Avatar
Please enlighten us regarding "Echolink"
Dr Joe & Winn
KD8VD
Old 11-21-2002, 07:57 AM   #8
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
hello
wb4eze in alabama .. the wbcci has a ham club i dont think it is very active..
wb13798 is offline   Reply With Quote
Old 11-21-2002, 10:52 AM   #9
1984 29' Sovereign
Savannah , Missouri
Thumbs up Echolink
Dr Joe and all,
Echolink is a small program that is useable only by a licensed ham radio operator. It allows you to cross-link or in some cases link directly to the vhf or hf band via the internet. Thus the reason why you must be a licensed ham.
I've tried it and, it works very nicely~!
http://www.echolink.org/el/register_data.asp
All you need to do is registered first and,then download the program.
The registeration is for the purpose of validation of your ham license..BEST OF ALL, IT'S FREE~!
73
K4NEH
Old 11-21-2002, 11:20 AM   #10
Dr Joe
winner's Avatar
OK Thanks a lot - I have downloaded Echolink and all is well. Will try and use it soon.
Dr Joe & Winn
KD8VD
Old 11-22-2002, 03:24 PM   #11
1984 29' Sovereign
Savannah , Missouri
Lightbulb Node
Greetings..
If anyone would like to try out ECHOLINK..
Look for my NODE number which is 45216
Each one that register is assigned a Node number..Look for it on the far right hand side of the contact menu.
73
Vern, K4NEH
Old 11-23-2002, 09:39 AM   #12
Dr Joe
winner's Avatar
Echolink
To All:
Thanks to Vern, I am now on Echolink, as KD8VD, Node Number 56762, and the system is working beautifully - Have talked with stations in Australia, Germany and over US with No problems.
Dr Joe & Winn
KD8VD
Old 11-23-2002, 11:48 AM   #13
1984 29' Sovereign
Savannah , Missouri
Lightbulb Look out
Dr Joe,
Under the top menu you'll see a "Bell" icon..I've listed you on my alarm online list there..Just to help increase our chances of connecting..
Really sounds like you're having a Blast with it~!
ciao
Old 11-23-2002, 12:19 PM   #14
igor's Avatar
1972 25' Tradewind
Redmond , Oregon
KC7WOU here in Central Oregon.
igor is offline   Reply With Quote
Old 11-23-2002, 12:35 PM   #15
Dr Joe
winner's Avatar
Echolink
Hi Vern and Igor
Great - I understand that a station will only show up on the station list if ON the air - But listing on the Alarms is great and we will connect! I agree. this would be great to unit a fraternity of A/S Hams on this program. Since I have been the Airstream ARC(Amateur RadioClub) I have seen no activity - this would be a great activator for interest - I had actually decided that being a member of the A/S ARC was pointless if there was little or no activity on the net. This program is so convenient and easy to use-beats the static and problems with radio and amp for sure.
Dr Joe & Winn
KD8VD
Old 11-26-2002, 02:16 PM   #16
K5CAD (since 1954) La Marque, Texas
Ebert Steele
k5cad is offline   Reply With Quote
Old 11-26-2002, 04:35 PM   #17
wb13798's Avatar
2004 28' Classic
not having much sucess connecting. im registered wb4eze node 58002 . need some one to talk me thru this one. think im doing somethign wrong ????
thnx al
Old 11-26-2002, 04:51 PM   #18
wb13798's Avatar
2004 28' Classic
think i might have found my problem i have a fire wall and a router . it seems i will not be able to use the system with a firewall or a router . that is my interpitation of the blurb on firewalls and routers . if that is the case im not going to drop my firewall or router. had too many hits some one trying to get into my system in the past . if im incorrect let me know..
thnx al
Old 11-27-2002, 01:31 PM   #19
1984 29' Sovereign
Savannah , Missouri
Unhappy Ref:Firewall
Yep
That's the problem. If you research it, I know that you can find the fix, which will allow you to keep it up and, still be able to use it. If you like, I can help try to find it for you. (the info) Let me know.
ciao
Old 11-27-2002, 05:12 PM   #20
K4GLC
Lee in NC
Howdy!
LeeC is offline   Reply With Quote
tow vehicle isolated from A/S batteries?? BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 13 02-05-2004 12:50 PM
19' Bambi cork floor need sq. feet of A/S JimBrownUT Floor Finishes 4 01-07-2004 05:26 PM
Ham radio question: installation of 2m/70cm antenna in Classic 28' Dave Jenkins Our Community 4 08-17-2003 06:58 PM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
