Old 12-25-2014, 01:18 AM   #379
de NO1PC
JimAspinwall's Avatar
2004 30' Classic
1988 29' Excella
Campbell , California
Gary,
You're probably 8-10 miles down 85 from me, if you'd like we can arrange a time and you can visit our 30ft 2004 Classic upon which I've mounted both a CB and dual-band antenna on either side of the broadcast 'duckie' top front. Cable run was relatively easy fishing/pushing the feed-line through the 3/4" NMO mount holes to the back of the front cabinet where the stereo is mounted. Under the stereo box is mounted the CB and UHF/VHF rig. Eventually I may install an EchoLink node on laptop so I can have my own local 'bubble' to connect back to friendly systems via WiFi connection.
I've also placed an elevated ball+spring mount on the roof behind the A/C unit to allow me to interchangeably try screwdriver, or random wire or whips with SGC tuner leveraging the significant counterpoise and ground effect coupling of the trailer. I have not run feedline to the interior, yet, as most of my operating time at camp is minimal and "field day like" under the awning, and I have to get atop the trailer to set the antenna of the day anyway.
However, as with another response, I do have the ability to run feed in above the fridge cabinet, where I also ran in the solar panel wires, but there are space/orientation challenges it would be good to know about in advance.
How do yo get the coax from inside to out? I don't fancy drilling holes through the shell...
73's Gary
KK6QWP
Enjoy the ride! Best 73!
de Jim, NO1PC
JimAspinwall is offline   Reply With Quote
Old 12-25-2014, 02:19 AM   #380
2007 22' International CCD
It's every bit as active as long ago, IMHO.
I dabble in emergency communications, and the ARRL put out some posters and stuff with 'when all else fails, amateur radio' as a theme.
I've found it to be very true. Got my license at a late age in Alabama. We had sufficient bad weather to really need to sprout antennas in emergencies. I still do...
AS is equipped with solar power
Old 12-25-2014, 02:24 AM   #381
And appropriate first aid and emergency water and rations. I now live in earthquake country, which can be as rough as the tornados in Alabama...
'Be prepared' is what I earned as a Boy Scout and adult leader.
(Sorry, split post by accident)
Old 12-25-2014, 11:08 AM   #382
Ag&Au's Avatar
Port Orchard , Washington
What's a pocket internet? I searched for it and all I found were devices that receive and play internet radio stations.
Ken
Old 12-25-2014, 11:16 AM   #383
2016 30' Classic
Erie , Colorado
Gary, I got my tech license about 15 years ago and used it extensively when flying gliders and hot air balloons. Put a radio back in the truck when I got the AS last year. A 2M/440 Yaesu FTM-450. On my fall trip back to Jackson Center I loaded up the memories with all of the repeaters along the route. In the entire 2200 mile trip I made only two contact on 2M. The band was dead. In the Denver area there was always chatter on the multiple mountain top repeaters but no longer. Very quiet.
So I got to thinking about going to HF. Took my General in October and bought an Yaesu FT-857d, Tarheel Antenna and a TurboTuner. Mounted them in the truck and the world exploded with contacts and literally around the world. Bought a power supply and LDG tuner for inside the house and a Buddipole system. Mounted the Buddipole on the back porch and got even more hooked. This combination is what I plan to use in the new year while camping the AS.
Worked and passed the Extra exam in mid November. Strung a couple of wire antennas, G5RV types and found a used Icom IC-7600. Joined a couple of Ham Nets (OMISS and YLSystem) and made lots of other contacts. Worked All States with OMISS in about 45 days.
Now I was really hooked. Current setup (Christmas is here) is a Flex Radio 6500. The Flex is a Software Defined Radio and you use your computer as the control. I am height restricted since I live next to an airport and installed a SteppIR BigIR vertical which is tunable from 10-80m. Couldn't be more pleased.
In my enthusiasm here you can tell I think it is a great hobby. Meeting lots of new folks on the air. Easy to make friends since I have traveled a lot over the years and sometimes know pretty close to where they live. My opinion is that 2M/440 has gotten quieter but HF is alive and well.
Lastly since I like to boondock in the mountains here in the west I know that I can always make some type of emergency contact with an HF radio. Cell phones and 2M/440 are good but HF simply opens up the world.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 12-25-2014, 11:52 AM   #384
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Also check out http://www.winlink.org/ for e-mail via ham radio. It is not suitable for large messages, e.g. pictures or video, but works great for text messages. With a WinLink account you can send e-mail to any e-mail address.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 12-25-2014, 11:15 PM   #385
Phodeaux's Avatar
1998 34' Excella 1000
2010 25' FB Flying Cloud
San Jose , 95136
Thanks Jim,
I live near 85/87 connection so am likely within easy driving distance. After the holidays I would like to get together to see your rig and chew the rag for a while.
I am currently lusting after a Yaesu FT-857D and wondering if I could mount the base unit in the Airstream and run the remote head into my TV for transport and then back to the AS when parked. Lots of options, some maybe too ambitious until I can be sure the ham bug sticks!
XYL calling so I MUST go! More later...
"You're probably 8-10 miles down 85 from me, if you'd like we can arrange a time and you can visit our 30ft 2004 Classic upon which I've mounted both a CB and dual-band antenna on either side of the broadcast 'duckie' top front."
"It ain't what you don't know that gets you in trouble, it's what you know for sure that just ain't so." Mark Twain
Phodeaux is offline   Reply With Quote
Old 12-25-2014, 11:30 PM   #386
Pocket internet is a satirical reference to my apple smartphone that goes with me everywhere. It's the 'internet in my pocket...'
Old 12-25-2014, 11:53 PM   #387
Ag&Au's Avatar
Thanks, sometimes humor is wasted on me.
This will be my next cell phone:
http://xkcd.com/1465/
Ken W7TS
Old 12-26-2014, 01:37 AM   #388
One of my favorite cartoons and cartoonist😃
Old 12-28-2014, 12:49 PM   #389
Phodeaux's Avatar
San Jose , 95136
On ours we have a Yaesu FT857 with a control head remoted to the back desk. The main unit is mounted in a 14x14 Leviton modular wiring box screwed to the aft closet wall inside the closet. Power distribution inside the box with a West Mountain panel. Connections to the main unit are HF and VHF. They are capable of being jumpered to two feed-thrus that go from the closet interior into the fridge compartment by the upper door.
The permanent VHF antenna is fed through a spare packing grommet on our solar junction box on the roof that covers another hole into the closet from the roof. Antenna bracketed to a solar panel mounting foot.
For HF we open the fridge exterior door and hook the portable antenna up. One hole, but two antennas.
This works for our 22 foot international CCD
Hardest thing was fishing remote wiring under everything on the street side to the cabinet under the right side of the desk.
Thanks, Great information! I am considering either the FT-857D or maybe the FT-897D. Looking at them made me go ahead and get the General. I plan to work on the Extra when the holiday dust settles so I won't have to worry about band limits. I will use the VHF/UHF to contact club members on caravans and approaching rally's. I have noticed there isn't a lot of activity on local (SF Bay area) repeaters so HF should be an improvement!
Old 12-28-2014, 04:29 PM   #390
2014 23' FB Flying Cloud
Mill Valley , Left Coast
AD6WX, extra here, Northern California.
jbxx is offline   Reply With Quote
Old 12-28-2014, 05:18 PM   #391
2016 30' Classic
Erie , Colorado
Both of the FT's are nice. With the FT-857D you can mount in your TV easily and remove it and bring it into the trailer. Using the FT-897D mobile might be a challenge due to size.
Gary
2015 Classic
ProPride
NVPN
Old 12-28-2014, 11:32 PM   #392
de NO1PC
2004 30' Classic
1988 29' Excella
FT-857D, HF... et al
- I think the trick to remoting the FT-857 head is finding the reasonable limit of the cable length - it may be negligible in some/most extended installs, or finite. My FT-857 is at the end of it's provided cable in the 'TV' - which is all too embedded to consider as a field radio working out of the truck without some new considerations I may explore - which means more antenna connection options than anything else.
- Between the 857 and my IC-706 I think the 706 with DSP option is a better radio for receive quality/dynamic range. Something about the 857 RF Gain/AGC and audio effectiveness is lacking to my ear. But, that's why we have options.
- The real key to any mobile/portable operation is getting as close to optimal antenna arrangement as possible for the desired operation. Nothing changes Airtstream. mobile, field day or fixed station - vertical radiation pattern always favors DX and horizontal, more omni/broader pattern is more universal local/stateside. It's as impressive as heck working Europe from the patio table under the awning (with a vertical) as more reliable nets and familiar contact operation with a piece of wire tossed to a nearby tree.
I travel fully equipped to do either no matter which rig. It's always a pleasure, seldom disappointing, to pitch 50-60 feet of wire or so with a cross-bow and some string, and have at least the trailer if not the entire camp electrical and plumbing system as counterpoise. (Cool - someone already buried 5 acres of radial for me!!!)
Whether a 'random' short whip or the 31' LDG vertical or short-whip screwdriver I always turn up challenged for contacts that should be out there. Again - nice to have options.
I'm trying to cover this and appropriate power schemes as a modern-day follow-on to the work of Don Johnson (sk) who's basic sound approach to all of this has helped me more than any money spent at HRO/AES, etc.
Nothing beats a trip in an Airstream, replicating your own mini-Field Day, just having a blast on HF without really trying too hard.
de Jim, NO1PC
tow vehicle isolated from A/S batteries?? BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 13 02-05-2004 01:50 PM
19' Bambi cork floor need sq. feet of A/S JimBrownUT Floor Finishes 4 01-07-2004 06:26 PM
Ham radio question: installation of 2m/70cm antenna in Classic 28' Dave Jenkins Our Community 4 08-17-2003 07:58 PM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 07:28 PM
