Old 03-27-2013, 11:59 AM   #337
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by Tom Bray View Post
That sure looks like vintage Collins to me. The rig I lusted for in my teens.
All Collins S Line. Vintage Station, I have a small Collins collection. My brother swears by the FT101 his favorite rig.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 03-28-2013, 10:46 AM   #338
mefly2's Avatar
2015 25' FB Eddie Bauer
Same from here, too ...
Old 03-31-2013, 09:21 AM   #339
1988 29' Excella
Campbell , California
Ramblings...
I've heard of the flagpole stand idea for a vertical antenna, and am considering trying this as I just acquired an LDG 31' telescoping vertical, and use my SGC-230 at the base. As with any vertical the most important element is the missing one - the counterpoise - without it a vertical is almost useless. The other aspect is that a vertical has a low take-off angle and we'll lose a 45-90 degree swath of coverage in the direction of the nearby trailer, and anything else. You also risk projecting a lot more RF to nearby folks at that low elevation.
My second idea is to mount a plate to hold a 3/8-24 ball mount (I have one of the old heavy duty ones) stood-off atop the trailer, and mount an SGC-230 auto-tuner next to it. Excellent 'native' counter-poise, omni-pattern... and... with a 10' CB whip I get vertical. Pull the tip over and I have NVIS. Remove the whip, attach a wire and toss the other end into a tree...
As soon as I get the right stand-off channel to mount probably a 19" rack panel to hold the ball mount and tuner, I'll get some pics. The stand-off channel would be secured to the internal roof frame rails.
If all else fails, the old wire in tree to tuner grounded to A/S frame or water pipe may have to do.
K9GVF is offline   Reply With Quote
Old 04-06-2013, 04:18 PM   #340
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
When Cell towers go down and land lines (i.e earthquakes) etc. It's the Ham operator that is still able to communicate and get the message out.
this is what makes the Ham Operator network so important and reliable.
Originally Posted by Fyrzowt View Post
I'm not a ham operator, so here is a rookie question or two.
How often if ever do ham operators get involved in assisting with comm during disasters? Ham was mentioned in a recent class as a possible resource for us in the fire service if our communications was severed for whatever reason.
If this occurs, how difficult is it?
Logistically - how would you provide this service?
Is it on a voluntary basis?
Thanks for your input,
Dave
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 04-06-2013, 04:29 PM   #341
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Just checking into this thread - WD9EMC
Old 04-06-2013, 04:42 PM   #342
Jim Clark's Avatar
The link below has a lot of good information.
Amateur Radio Emergency Communication
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 06-30-2013, 04:28 PM   #343
themartaman1's Avatar
1972 23' Safari
Stockbridge , Georgia
N4KNQ Stockbridge, GA.
themartaman1 is offline   Reply With Quote
Old 06-30-2013, 04:52 PM   #344
2010 22' Interstate
Vincennes , Indiana
I worked all 3077 counties in the US and over fifty countries mobile using a bumper mount vertical grounded to the frame. I used 80 watts with no tuner but I did tune the antenna. Even a mag mount to the top will work well but you will need to remove it when traveling.
de Phil, AA9Z
QUOTE=K9GVF;1280039]Ramblings...
If all else fails, the old wire in tree to tuner grounded to A/S frame or water pipe may have to do.[/QUOTE]
aa9zz is offline   Reply With Quote
Old 08-14-2013, 02:56 PM   #345
2007 22' International CCD
Talking Radio Setup
KE4GNK here...
Our A/S has a Yaesu FT-857 control head and external speaker carefully mounted on the desk in the rear, with the main unit in a steel enclosure in the front closet. Has power distribution, low voltage cut-off and fans for cooling (WestMountain parts)The radio main unit has both RF outputs run into the upper refrigerator door are so it's easy to connect to external antennas. Have a permanent mount 2-meter antenna on the roof for easy use.
Also working on a remote control self-raising mount for an HF ATAS-120B screwdriver antenna on the roof for easy setup. Seen a few ideas in stainless steel from the Tarheel folks, but want to make it out of aluminum to match the roof contour and make it a little more low-profile. The solar panel on the roof has to be worked around to make this fit easily. More to come when I get it working.
Old 08-14-2013, 04:01 PM   #346
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Would love to see pics as I am in the early stages of a remodel and would welcome any ideas!
KB1JFZ
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 08-14-2013, 04:17 PM   #347
KB1JFZ
Unfortunately the trailer is parked 90 miles away right now, but here are more details.
The steel box is a Leviton 14" by 14" white steel box designed for home networks (Home Depot) with a screw-on cover mounted on the rear wall of the closet in front of the A/S with short screws (lots of them) into the plywood wall. For ventilation, we punched out ALL the holes in the top and bottom of the box, and have a small computer fan mounted in there to move air. Switch is on the side of the box.
Future plans include a screwdriver vertical with a self-raising mount on the roof as well--more cables to run!
The mobile mount for the 957 is screwed into the same wall, through the steel box. It's mounted high enough to clear the cover over the hot water heater in the bottom of the closet and be easy to reach. We ran a heavy power cable to the underside of the FB and connected it to the house batteries through a pair of 30-amp automotive-style fuse holders at the ground junction and the house side of the relay. The other end has PowerPole connectors to plug into the rig runner mounted inside the box. The rig runner has a low voltage alarm to remind us to disconnect from battery when this is not in use. A low-voltage cutoff would be a better idea--that's next.
The remote cables for the microphone, control head and the speaker were painstakingly run under the kitchen, under the shower, and into the desk at the rear. My son and I exhausted most of our vocabulary getting that to happen...fishing under there is an exercise in patience.
The remote speaker is mounted on the desktop, as is the control head. A smallish table-top grommet from Home Depot provides wire access from the stack of drawers on the right of the desk. Microphone clip is mounted to the side of the Lav wall to provide a space for the microphone.
Two short RG-8 jumpers carry the main unit's RF connectors out of the box. An extension cable carries the UHF output to a ceiling hole that is inside our solar panel connection on the roof and it exits through a packing gland on the rear of that junction box. From there it goes to a 2-meter antenna bracketed to the side at the solar panel mount. There are two so-239 extenders about 6 inches long that go through the back of the closet close to the interior skin into the refrigerator upper vent door area (side mounted) to allow easy connections to any portable antennas.
Future plans include a self-raising screwdriver antenna mounted on the roof.
Old 09-07-2013, 01:49 PM   #348
AlumaTurtle's Avatar
Olean , Missouri
aa0ae
just new to AS forums not new to AS
am i right that there is no activity here since 2002
AlumaTurtle is offline   Reply With Quote
Old 09-07-2013, 02:33 PM   #349
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Nope. The thread started in 2002 and there were posts just a couple of weeks ago.
Old 09-07-2013, 02:40 PM   #350
Olean , Missouri
just saw that after i posted new to AS forums didn't realize new post were on p 25
tow vehicle isolated from A/S batteries?? BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 13 02-05-2004 12:50 PM
19' Bambi cork floor need sq. feet of A/S JimBrownUT Floor Finishes 4 01-07-2004 05:26 PM
Ham radio question: installation of 2m/70cm antenna in Classic 28' Dave Jenkins Our Community 4 08-17-2003 06:58 PM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
