Old 04-04-2011, 11:47 PM   #281
Jim & Amy Emett
jsemett's Avatar
2005 28' Classic
Monrovia , California
Send a message via Skype™ to jsemett
Got one here, K6OSO
Jim Emett
jsemett is offline   Reply With Quote
Old 04-04-2011, 11:52 PM   #282
Jim & Amy Emett
jsemett's Avatar
2005 28' Classic
Jim (K6OSO) here, anyone found any simple, inexpensive ways of mounting antennas on an AS, I am thinking of going via the battery box, and doing something off of the hitch. I just cannot get myself to do anything to the "Classic" itself.
73
Old 04-06-2011, 04:32 AM   #283
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
73
Jim,
What bands / antennas types are you considering using?
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-06-2011, 08:47 AM   #284
Jim & Amy Emett
jsemett's Avatar
2005 28' Classic
2m-440, possibly a tarheel for a IC 7000
Old 04-06-2011, 08:57 AM   #285
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
I have 2 short 6 inch pipes with set screws mounted to the back bumper in which I can place 2 longer pipes.. One has a High Sierra screwdriver on it permanently,I just remove the whip when travelling. I can put a Hustler 5 BTV on the other. My 2 meter 440 stuff is on NMO mounts on the trailer roof. Of course I have no hesitancy to punch holes.
I also have a pipe with set screw clamped to the tongue jack which can be used for a mast etc and is a no holes arrangement.
Will try to get some pictures in the next few days to make it a little clearer.
Built all the mounts myself so it was all low cost
13 Ram 2500 TD
Old 04-06-2011, 11:43 AM   #286
1975 31' Excella 500
GRAY COURT , South Carolina
antenna mounts
73
#112
K4KEP-SPENCE
Profile: 1975 31' Excella 500
Originally Posted by K4KEP-SPENCE
DR JOE ASK ME TO POST THIS.
THE AES RADIO (MILWAUKEE) BIGFOOT ANTENNA BASE
YOU PUT IT DOWN ON THE GROUND AND PARK WITH YOUR TIRE SITTING ON IT. STICK THE MAST IN IT AND ZIP YOUR ANTENNA IS UP.
2ND CELL TOWER ANTENNA CLAMPS ON EBAY LIKE PICS. CLAMP ON JACKSTAND ABOVE FRAME AND THEN CLAMP IN YOUR MAST. CAPACITY 1/2" TO ABOUT 6" PIPE.
73
SPENCE
UPLOAD DID NOT WORK
1010506.JPG:
The Dimension limits for this filetype are 1024 x 1024. We were unable to resize your file so you will need to do so manually and upload it again. Your file is currently 1280 x 960.
P1010507.JPG:
GO TO MY WEB SITE FOR THESE TWO PICTURES
http://www.backroads.net/~K4KEP/HIDDEN/P1010506.JPG
http://www.backroads.net/~K4KEP/HIDDEN/P1010507.JPG
HOPE THESE WILL HELP. THEY ARE SOMTIMES USED BY CELL TOWER CONSTRUCTION AND BY OTHER SHORTWAVE VHF UHV INSTALLATIONS. WATCH EBAY. QUITE EXPENSIVE IF BOUGHT NEW.
SPENCE
AIR # 19410
K4KEP-SPENCE is online now Report Post
Jim hope this will help. they work g r e a t!!!!!!!!!!!!!!!!!!!!!!!!
SPENCE
AIR # 19410
K4KEP-SPENCE is offline   Reply With Quote
Old 04-07-2011, 12:41 AM   #287
Jim & Amy Emett
jsemett's Avatar
2005 28' Classic
Thanks everyone
The hints on the mounts are perfect, I have to get an adaptor for a Powercaster welded to the tongue later this week, i'll take the opportunity to also weld two receiver tubes to the tongue as well. Rick, unfortunately my bumper covering is plastic, sO I'll steer clear of that for the.time being.
73
Old 04-07-2011, 06:45 AM   #288
1972 23' Safari
Tallassee , Alabama
I have a bug catcher mounted on the rear bumper of my Airstream using their fold over mount (unfortunately I think these are no longer being made). For the front I made a bracket that mounts near the hitch using a pair of U-bolts. The bracket accepts either a rotator assembly or I can stick a 4BTV antenna on it.
Here is a link for a picture of the front mount: Amateur Radio Photos
Tom
WB8COX
Tom Bray is offline   Reply With Quote
Old 05-01-2011, 09:48 AM   #289
dick&claire's Avatar
2011 30' Flying Cloud
North Falmouth , Massachusetts
Icom 700 for 2M and HF
I've mounted an Icom 700 and LDG IT100 tuner in my Flying Cloud 30. I use HRD + DM780 with rig control on my MacMini computer. Power is from the front DC bus with fused cable going to a RigRunner. The only holes in the Airsteam (one inside and one outside) are for the coax cables coming from a Hustler coil for HF and a Buddipole for 2M. The buddipole mounts on the flag pole holder bolted to the electric jack. The Hustler coil is mounted on a bracket from Radioshack that is bolted to 9 foot Sched 40 PVC mast (1" diameter strengthened by a 3/4" tube inside the 1" tube...not easy but can be done with some lithium grease and a mallet). The antenna has a copper braid ground strap going to a 4' copper rod in the ground. I've been able to tune both the Huster 20S and 40S coils to an SWR of 1.5 to 2.0 without the LDG tuner. The antennas are stowed for travel but go up easily when camped.
ID:	128792   Click image for larger version
ID:	128794   Click image for larger version
Dick and Claire Wiklund
North Falmouth, Massachusetts
"Judgement is based on experience and experience is based on poor judgement"
dick&claire is offline   Reply With Quote
Old 06-04-2011, 08:42 AM   #290
benjisgal's Avatar
2010 23' FB Flying Cloud
Fayetteville , Georgia
Images: 16
I'm just a CB radio operator (newbie). Got it since I am leaving in 4 days for the Canadian Rockies and Canada. I plan to get my license when I get back and become a HAM operator.
Benjisgal
WBCCI #1122
Top of Georgia Unit #52
I dont want to get to the end of my life and find that I lived just the length of it; I want to have lived the width of it as well.
---Diane Ackerman (Author, poet, essayist, naturalist)
benjisgal is offline   Reply With Quote
Old 08-16-2011, 07:00 PM   #291
RMB
RMB's Avatar
2010 23' International
Saturna , British Columbia
VE*MB here in BC Canada
"I carry what I can, and leave the rest behind" Epicurus
"All that is mine, I carry with me." Cicero
RMB is offline   Reply With Quote
Old 08-16-2011, 08:42 PM   #292
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Welcome,
Cool "fill in the blank" callsign.
I would guess it's a 7, but since * is upper case 8 I'm not sure??
73,
Ken W7TS
Old 08-16-2011, 10:58 PM   #293
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
I am KI6MVT. Got my license primarily to use in sailboat races while working on race committee. It is also part of my earthquake emergency kit and my CERT call-out kit.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 10-17-2011, 12:20 PM   #294
Cypress , Texas
Not an Airstream, but a relative, an Avion silver.
I mounted a Little Tarheel II on the roof wih a custom mount that I built so that I can tilt the antenna down for travel. It is grounded drom the 3/8"-24 base to the base mont and them to the trailer frame and skin with 1/2" copper braid.
The radio is a Kenwood TS480X with a Jet Stream 45 amp switching power supply. In the hosue on the same power supply, the radio is very quiet, low noise.
The noise is horrible in the trailer. I will be starting by powering the power supply from from an extension cord from outside the trailer with the trailer totally powered down. Then plug in the trialer and turn on one circuit at a time to see if the source makes itself appear.
Next I will power the radio and power supply from a clean source in the trailer and try different circuits to find the problem.
I am trying to avoid running a long run of 12vdc power cable from the batteries or the main 12vdc bus. Remember, this radio requires a 41 amp power supply to operate.
I will also try as a last resort, using a battery from the auto and work my way through the circuits until I find the culprit(s).
Hopefully I will find the source and can approach it with the use choke and filters to get it cleaned up.
If anyone has any suggestions or how you handled the problems in your Airstream.
73,
Ken
KE54DFR
2008 Cameo 35SB3, 2012 Ford F350 Crewcab DRW. Travel companions..1 Wife, 1 miniature schnauzer, 1 standard schnauzer and one parrot.
TXiceman is offline   Reply With Quote
tow vehicle isolated from A/S batteries?? BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 13 02-05-2004 12:50 PM
19' Bambi cork floor need sq. feet of A/S JimBrownUT Floor Finishes 4 01-07-2004 05:26 PM
Ham radio question: installation of 2m/70cm antenna in Classic 28' Dave Jenkins Our Community 4 08-17-2003 06:58 PM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
