Old 12-20-2007, 09:34 PM   #141
KeithC's Avatar
1994 34' Excella
1978 31' Sovereign
Mansfield , Georgia
KF4IF0 is in Metro Atlanta and ownes a 1968 Airstream Tradewind
KeithC is offline   Reply With Quote
Old 12-20-2007, 10:11 PM   #142
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Hey KA8 LMQ here!
I have been thinking of mounting my low band mobile antenna on the toungue some how and running coax thru the battery box and coming out under the front goucho.(only temp setup) I have been inactive for a while but that sound like something intresting to do. I have all the mobile coils.
May hear some of U this next summer.
73's
Roger
Mikethefixit is offline   Reply With Quote
Old 12-21-2007, 12:25 AM   #143
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
I'm N0YQR in Austin Tx... Inactive for a while but need to get my setup back in the truck for backup as I've traveled with no cell signal....
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 12-21-2007, 07:49 AM   #144
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
I'm W9CDC and my wife is K9CDC. We operate VHF/UHF mobile and HT's (great for help backing the trailer). I usually operate HF with field expedient antennas either dipoles or, more commonly, the BuddiPole with an Icom-7000 and LDG AT-7000 tuner.
Royce, do you have a 32' push up fiberglass antenna mast from DK9SQ (Walter Spieth)? I used to have one and liked it a lot.
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 12-22-2007, 10:49 AM   #145
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
DPeakMD
I bought and plan to use a kite pole made by Jackite:
Jackite Inc
Bought on Ebay for about $20. The top two sections will be too light but the balance should work just fine. I am building a J pole for attachemt to the top.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 12-22-2007, 04:12 PM   #146
DPeakMD's Avatar
1975 23' Safari
Franklin , Indiana
Royce---I've seen those before at rallies. They're usually flying a windsock or fake bird. You're going to be the first flying and antenna! Sounds like a good idea. Let me know how it works out.
Mikethefixit---I used to have an antenna mounted on the jack post. It was a High Sierra screwdriver. I ran my coax and control wire back along the gas lines to the fridge and came up through the perforated mesh of the bottom vent. Just an idea. The battery boxes are sealed up pretty tight on the inside.
I have flags now and that interferes with putting a similar antenna on the jack post....
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
Old 12-22-2007, 06:47 PM   #147
1977 27' Overlander
Trotwood , Ohio
Dallas
Thanks I hadn't though of that. Ill be under there in the spring puttin in new axles I will probably make a permanent install of a mount and coax.
Roger
KA8LMQ
Old 12-22-2007, 08:00 PM   #148
Miss Rivette
airedale's Avatar
1965 17' Caravel
Hell , Michigan
Send a message via AIM to airedale Send a message via MSN to airedale Send a message via Yahoo to airedale
W8JUZ checking in here!
Laura Miss Rivette 2008
W8JUZ --......--
"Support Search and Rescue, GET LOST!!!!"
Operation "SAVE RUDY" Strike Team (Charter Member)
Check Out My New Airstream Blog
airedale is offline   Reply With Quote
Old 12-22-2007, 08:30 PM   #149
igor's Avatar
1972 25' Tradewind
Redmond , Oregon
I was just looking at this, 11 pages ago I had my old call. K7KIT now, still in central Oregon.
W8JUZ, you put a smile on my face. While in the Marines I worked and crewed on helo's - thus in Navy terms an 'airedale'. And, to make it even more funny, I met my wife after my active duty while we were both in CAP, me being a search pilot and ground team leader (not shure how that one happened). She a LCol, a group commander and an observer. The only time I got to boss her around was when she was in my airplane
73 de K7KIT
igor is offline   Reply With Quote
Old 12-23-2007, 04:55 PM   #150
MrAgent007's Avatar
2006 22' International CCD
Hershey , Pennsylvania
Images: 21
Antenna Mast Pictures
Hello, can anyone post pictures of their antenna mast mounting? I am looking for ideas to mount the supports for a vertical somewhere on the "A" frame area. Thank you!
Alex
MrAgent007 is offline   Reply With Quote
Old 12-23-2007, 05:54 PM   #151
Miss Rivette
airedale's Avatar
1965 17' Caravel
Hell , Michigan
hmm. I need to get a HF rig in my Jeep, and then Ill be set, have everything eles in there.
I got my airedale name from the dog, nothing more than that, but yea, I know all about CAP, but that is a story that im not going to even get into!
W8JUZ --......--
Old 12-23-2007, 10:03 PM   #152
Miss Rivette
airedale's Avatar
1965 17' Caravel
Hell , Michigan
W8JUZ --......--
Old 12-24-2007, 07:06 AM   #153
DPeakMD's Avatar
1975 23' Safari
Franklin , Indiana
Alex--I used to have my High Sierra U-bolted on the jack post. Some things I discovered...
1. Make sure the front window and rock guard will still open.
2. The electric jack power head can be flipped out of the way if needed.
3. The jack head may still stick out a little and you may need to offset for it.
I used my antenna from the inside or outside the trailer as well as from the tow vehicle while mobile. That worked out pretty well. If you don't want flags, this is probably near the best place to put a vertical antenna. Your SWR may change when tow vehicle is attached to trailer.
Good luck!
Laura--great picture! What is "Save Rudy" about???
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
Old 12-24-2007, 05:03 PM   #154
MrAgent007's Avatar
Images: 21
Thanks for the information!
Alex
tow vehicle isolated from A/S batteries?? BOBHASTINGS Electrical - Systems, Generators, Batteries & Solar 13 02-05-2004 12:50 PM
19' Bambi cork floor need sq. feet of A/S JimBrownUT Floor Finishes 4 01-07-2004 05:26 PM
Ham radio question: installation of 2m/70cm antenna in Classic 28' Dave Jenkins Our Community 4 08-17-2003 06:58 PM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
