Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Phone, CB & Ham Radio
Old 07-27-2007, 02:49 PM   #15
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Send a message via AIM to jcanavera
Originally Posted by rickandsandi
Any one of these in particular? The blade one they show isn't like the suction cup one above. Note that this one at amazon plugs into an external Wifi adapter card.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 07-27-2007, 04:04 PM   #16
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
If you're looking for something very directional, check these out. You will need a Wi-Fi card with an external antenna connection.
WiFi Antennas-Super Cantenna Wireless Booster Antenna
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WBCCI# 4582
WDCU
SilverRanger is offline   Reply With Quote
Old 07-27-2007, 04:07 PM   #17
Profile:  2002 19' Bambi
Lafayette , California
I just posted on another thread the story of our passive external cell-phone antenna
For improved WiFi reception, we just installed Radiolabs WaveRV external antenna by mounting it on the support for the batwing TV antenna. Put up the TV antenna and the WiFi antenna is also well elevated. The present model is 802.11 b/g and works for the Mac OS as well as Windows. Software installation on our Mac was a little clunky, but worked well. We have not yet tested it on the road, but it picks up our home network perfectly as well as some of the neighbors' networks. The built-in antennas in our laptop and our desktop computers do not see the neighbors' systems. We will be testing the Radiolabs antenna thoroughly on a trip in September and I will post results when we are back home.
Tim A. is offline   Reply With Quote
Old 07-27-2007, 04:11 PM   #18
1968 24' Tradewind
Milton , Delaware
Great idea to mount it on the batwing. How did you route the wire? Got pictures?
2005 Bambi
1968 Trade Wind
WBCCI# 4582
WDCU
Old 07-27-2007, 09:24 PM   #19
Here they are. The USB cable from the antenna I took through the side of the skylight/vent. This is a nice way because you do not need to put any holes in the roof. Inside, I ran the wire down under the plastic strip covering the edges of the fuzzy wallcovering which our Bambi has. The hole in the vent is grommeted and sealed with 3M marine sealant (urethane) and another blob of the same stuff holds the cable to the roof. These antennas previously came with a USB socket at their base, but the one I bought just has the cable coming out.
When I report after September, I will also let people know if my mounting brackets and method worked. I hope so!
Name:	WiFi Antenna.jpg
Old 07-28-2007, 06:11 PM   #20
1968 24' Tradewind
Milton , Delaware
Thumbs up Thanks!
Tim,
That appears to be an excellent solution, and I really appreciate the pictures. They definitely changed my approach, which had something to do with actually drilling a hole in the trailer. I may even consider attempting to mount a Cantenna on the mast because , if it works out, I would be able to point it. If not, a good omni-directional antenna should be fine. Can't wait for your results.
2005 Bambi
1968 Trade Wind
WBCCI# 4582
WDCU
Old 07-28-2007, 06:46 PM   #21
tinsltootsie's Avatar
Profile:
Images: 27
Okay, all this info is very interesting, but a little confusing. I have a verizon chocolate phone in cape may, nj, and connect to the internet using it, national access, broadband. I know that cape may point (a few miles away) has avery good internet connection with verizon. (not sure of differences). So what do all of you suggest for this situation, since I am not concerned about wifi, since my campgrounds does not have it. It sounds like a repeater would do the trick, if the price difference is not too great between the amplifier and repeater. Right now I just walk outside, or put my phone near the windows. That seems to help.
So am i correct in thinking that i will need either repeater of amplifier??? And since hte one website did not show prices, and idea what price range???? any suggested brand names???
I will look into if further and will probablly wait until next year. As it is, internet is pretty decent, and night time illumination while biking is a bigger concern.
It's the rivets!!!!!
tinsltootsie is offline   Reply With Quote
Old 07-28-2007, 08:43 PM   #22
Profile:
Images: 27
high cost of repeater and amplifier
Just did a search on ebay, and both amplifier and repeater were hundreds of dollars. Now I like my tech stuff as much as the next guy, but I think that is a little steep. Gets me thinking my reception isn't that bad, and the internet spped not too muc h slower than my cable at home. is there a cheaper alternative?
Old 07-28-2007, 10:55 PM   #23
My pictures might help with the cell-phone question. I posted this information on another thread, but will repeat it here. If you look at the picture of the WiFi antenna, you will see a black antenna behind the label "cable entry through skylight/vent" and the red line coming from that label.
That black antenna is a passive (non-amplified) cell-phone antenna with a wire going into the trailer. The wire plugs into the cell phone. We have Verizon and have used National Access with the passive antenna and have been very happy with the results -- good, strong reception with the cell phone in areas where the phone alone (no connection to the external antenna) has lousy reception in the trailer. We bought the cell phone antenna from Larsen and it was much less expensive that a repeater setup. Because the wire from the cell phone antenna comes out of the bottom, we mounted it on a thick piece of aluminum raised up from the roof on closed-cell foam. The aluminum sheet is grounded to the roof of the trailer so the roof acts as a proper groundplane for the antenna.
Just as with the WiFi antenna, the cell-phone antenna wire goes into the trailer through a hole in the skylight/vent.
Old 07-28-2007, 11:06 PM   #24
1968 24' Tradewind
Milton , Delaware
Hi, neighbor.
I live just across the bay from you just west of Lewes, DE where the cell reception is kind of dismal in some places, and a broadband signal is non-existant for the time being. I bought my signal booster mainly for travel, and it has worked out very well for that. If I understand you correctly, you are primarily interested in improving reception primarily from a fixed location? If so, I believe the repeater system just may work for you because it doesn't require your phone to be tethered to a cable. If your trailer is anything like mine, the signal strength is far better outside than inside. The only cheaper alternative I can think of would be to just get an external antenna with an adapter for your phone, which will cost about $35-$40.
Adapter for your phone:
359919-LG AX4750,L1100, L1150, L1200, L1400, C1300, C1500, C2000, G4015, G4020, VX4650, VX4700 Cell Phone Adapter Cable for external antenna
Antenna:
External Magnet Mount Antenna for Cell Phone - Magnet mount external antenna to extend coverage- Better Cellular Reception - Cellular Solutions
I have included links to the company where I bought several signal boosters for my staff, and because they worked so well, I bought one for personal use. As you can see, the wireless model costs about $90 more than the direct connect model, but is probably worth it if you like to be untethered to a cord. I use mine equally as much in the cab of my tow vehicle as I do in the camper, so I don't mind the wires. Both units are made in the U.S. by Wilson Electronics, are very portable, and can fit in a container the size of a small lunch box.
Better Cell Phone Reception in your Vehicle with a Cell Phone Signal Booster-Cellular Solutions
Signal Booster - Dual Band Signal Booster - Best Cellular Reception - Cellular Solutions
On another note, I bike on a daily basis and agree that night time illumination is definitely a priority.
2005 Bambi
1968 Trade Wind
WBCCI# 4582
WDCU
Old 09-26-2007, 12:32 PM   #25
Tim,
I promised to report about the Radiolabs WaveRV external antenna after September. Well, we are still underway, but I am very happy to report that the antenna works wonderfully and the mounting method has shown no problems.
For those questions about a cellphone antenna, I would like to mention again that our passive external cellphone antenna, which has a connecting wire to the cellphone inside the trailer, was cheap and gives us good cellphone reception inside while people in $600,000 motorhomes around us are standing outside in order to get their cellphones to work.
Old 09-26-2007, 01:38 PM   #26
Cyclist
henw's Avatar
Profile:  2007 28' International CCD
Windermere , Florida
I have a Wilson hard wire repeater. I hook this on one end to the cell phone, the other to a directional Yag antenna mounted on top of a 20' extendable flap pole. There is a number you can dial on your cell phone ( brand specific) that will show cell signal strength. Allows me to point at the nearest cell tower. If I can't get cell service with that set-up, it isn't obtainable.
Tom
henw is offline   Reply With Quote
need a new cell phone rate family plan codybear Off Topic Forum 22 09-07-2006 06:20 AM
Solar Charging Panel and Cell Phone Antenna noiva Generators & Solar Power 15 01-16-2006 06:06 PM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
Wireless Web Reception niftypkg General Interior Topics 1 11-08-2002 09:03 PM
Phone cord Joan D'Andrea Cabinets, Counter Tops & Furnishings 0 11-02-2002 11:38 AM
