Old 09-10-2015, 11:53 AM   #1
Missouri Valley , Iowa
CB antenna for 2015 F 150
I went to my local CB shop today to find an antenna for my aluminum body F 150. He's been at the CB / ham radio thing for many years. But - he had nothing for this application!! What have others with 2015 F 150s done or used??
Dan
Farmer Dan is offline   Reply With Quote
Old 09-10-2015, 11:58 AM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Why is an aluminum body any different than any other, so far as a two way radio antenna is concerned ?
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-10-2015, 02:25 PM   #3
The magnet mount I have won't work. A hood / fender mount is not available apparently.
Dan
Old 09-10-2015, 02:37 PM   #4
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Maybe you can rig a CB antenna to a suction cub mount.
Kelvin
Old 09-10-2015, 02:43 PM   #5
Kelvin, that's a good idea. I asked my guru about adhering a small piece of thin steel to the roof for the mag mount to stick to. He said that interrupts the flow of electrons and won't work. I suspect a suction cup may be the same. But it's certainly a great question to ask him!! Thanks for the idea.
Dan
Old 09-10-2015, 03:04 PM   #6
jdalrymple's Avatar
Jay , Oklahoma
I must disagree with the "flow of electrons" theory. Aluminum is a conductor, just like most metals.
An Airstream trailer is proof of that.
Magnetic antennas are a compromise to wanting an antenna but not wanting holes.
Look at a Larsen MNO27B with an standard NMO angle bracket.
Best Regards,
JD
Jeff & Cindy
'91 350 LE MH
Old 09-10-2015, 09:03 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If you epoxy a steel plate under the roof, the magnet will stick.
I plan to permanently mount one when I am able to travel again..
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-11-2015, 12:21 PM   #8
bigfoot390's Avatar
1999 30' Excella 1000
Chatham , Virginia
Flow
He is full of bull. If you are concerned the do a window mount on the back no electrons that would matter to a CB radio need to flow through your truck body.
bigfoot390 is offline   Reply With Quote
Old 09-11-2015, 02:38 PM   #9
Classy Roscoe
Jekerrville's Avatar
1969 31' Sovereign
Kerrville , Texas
Simple solution. Suction cup base and center loaded active element 1/8 wave antenna. Place in center of roof. Take care to route the transmission cable to rear of roof to limit "slapping" when you are driving down the road and the wind is blowing. Be sure to use a Standing Wave Ratio meter to cut active element to proper SWR of less than 1:3 ratio and you are on the air!
Happy trails,
Jekerrville is offline   Reply With Quote
Old 09-17-2015, 06:17 AM   #10
2008 20' Safari SE
Longmont , Colorado
Do you have a cap over your bed? If it is fiberglass, install a marine CB antenna. They have a built in ground plane.
No cap? Install dual trucker antennas along the top of the bed behind the cab, one at each corner.
ridgewalker is offline   Reply With Quote
Old 09-20-2015, 12:24 PM   #11
Ridgewalker,
I will install an ARE fiberglass lid. I had not thought about a marine CB antenna. Thanks for that idea. Another idea is to install a steel plate on top of the lid using bolts through the lid. This would hold my mag mount antenna. Then run a ground wire inside the lid from the attaching bolts to the truck box, etc.
Dan
Old 09-21-2015, 04:35 AM   #12
2008 20' Safari SE
Longmont , Colorado
Farmer Dan, sounds like a good solution.
Old 09-21-2015, 07:00 AM   #13
I should have mentioned that cwf, Channing, explained how to complete the install on the lid so that the CB would work. Thanks, cwf.
Dan
Old 11-27-2015, 12:16 PM   #14
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Stake pocket mount from Breedlove Machine. A top load antenna like a 5' Wilson Silver Load or equivalent Everhardt.
2015 F-150 SuperCrew 3.5 EB towing 2012 International 27FB tot2learn Towing, Tow Vehicles & Hitches 27 01-28-2016 03:24 PM
2015 Ford F-150 Still Number 1 pappy19 Tow Vehicles 49 09-16-2015 07:31 PM
Tow Test-2015 F-150 2.7 Twin Turbo pappy19 Tow Vehicles 2 03-07-2015 07:09 PM
Airforums member reviews 2015 F-150... Bruce B Off Topic Forum 3 01-29-2015 07:50 AM
2013 F-150 & 2015 Flying Cloud 25' GLovedahl Tow Vehicles 14 01-14-2015 10:39 AM
