Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Phone, CB & Ham Radio
Old 02-07-2007, 08:33 PM   #1
Profile:  1964 24' Tradewind
Peoria , Arizona
CB Antenna - convert to AM/FM?
I admit that I know nothing about radios or frequency. I'm doing a full restoration of a '64 Tradwind and have been midly assuming that I could just us the existing antenna to pick up AM/FM with a modern car stereo unit. Is this possible or do I need a different type of antenna? I like the way the factory antenna looks on the airstream and really want to find a way to use it if I can - any thoughts?
nbk3ad2 is offline   Reply With Quote
Old 02-07-2007, 08:34 PM   #2
Liberator
klattu's Avatar
Profile:  Heart of Dixie , Alabama
Images: 841
Yes...use original
klattu is offline   Reply With Quote
Old 02-07-2007, 08:52 PM   #3
Peoria , Arizona
Thanks for the quick reply klattu - I just want to be sure and i realized that I left out some important info: The factory antenna I'm referring to is the really long (about 10 ft) antenna on the front. a friend of mine thought that this was a CB antenna and suggested that I couldn't use a CB antenna for AM/FM because it was a different frequency range. Is that tru?
Old 02-07-2007, 09:04 PM   #4
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
CB antenna will screw in (BNC connector) while a radio antenna plugs in.
Your antenna if orignal is for a radio.
Garry
Old 02-07-2007, 09:20 PM   #5
Peoria , Arizona
Thanks garry - when I checked again I noticed that the stub sticking through my interior skin was NOT from the radio antenna, but from what looks like a old tv antenna.... I'll have to check it out further...
What I found was a hole where the radio antenna is supposed to come through with just a couple wires pushed back into it. Tomorrow I'll check to see what is really there.
The journey may suck, but all's well that ends well.
Old 02-07-2007, 09:36 PM   #6
Liberator
klattu's Avatar
Images: 841
FM ideal is 11" mast
AM can be just about anything not grounded...
Coil of wire, extended CB, almost anything.
My old 36 Terraplane has its AM under the running board, looks like a wire fence panel...and works great.
Now CB has a lenght...is long and do not remember.
Around 10 feet.
It can be coiled up too, but has to be exact.
'Tuning the whip' is triming the end until it matches the 'wave'
Old 02-07-2007, 10:09 PM   #7
robandzoe's Avatar
Profile:  1958 30' Sovereign of the Road
Plymouth , New York
Images: 26
102" whip
I just bought two of these today for Colin up at GSM. It is for CB. Although it will probably pick up stations, most likely not optimum setup. You are talking about the stainless ball mount type antenna, right?
Rob
Rob, Zoe', Stanton, Bryce and Braedon Baker
Past President WDCU
Do you Listen to the www.theVAP.com
Plymouth, NY 13832 WBCCI #2820
Courtesy parking
robandzoe is offline   Reply With Quote
Old 02-07-2007, 10:51 PM   #8
Peoria , Arizona
Rob
UHM... Maybe. I haven't measured it, but it seems to be about 9 or 10 feet long and has a spring at the mount and is clipped in two spots temporarily to the body of the AS for travelling. That's all I know for now...
Old 02-07-2007, 11:00 PM   #9
robandzoe's Avatar
Plymouth , New York
Images: 26
Cool No expert but
Supposedly, as I've been told, 102" is half the wave length of the CB wave form. Not sure wave length of the FM side. Good luck. For FM, Airstreams in the 50s and early 60s used what I have on my blog post here:
Sweet Sovereign of the Road: January 2006
What you have is on my March 27th post:
Sweet Sovereign of the Road: March 2006
Hope this helps,
Rob
Vintage Trailer Supply from my site, carries those antennas. Let Steve know I sent you!
Past President WDCU
Courtesy parking
Old 02-07-2007, 11:23 PM   #10
Peoria , Arizona
Hey Rob - THAT'S the one - Blog #2!
While i now have a reference, what the heck is that? Is it CB or AM/FM? Does it matter... I'm getting confused?
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 11:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 02:30 PM
Antenna Wiring niftypkg Electrical - Systems, Generators, Batteries & Solar 1 09-22-2002 02:04 PM
Where do you suppose they put the antenna jack -73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 12:34 PM
