Old 03-19-2007, 08:02 PM   #21
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Anttenna
I got some things from Hawkings Technology and I can say that they are a very good company.Everything I got from them works really well.
They do have antennas for things like picking up wifi.Some are made really strong and some not so strong.It just depends on what you want and need to use.
I plan on getting some new video cameras from them as they are made to work with the internet and that is very usefull for when we are on trips.With what we have right now around the house these are top notch as you can look at the house anytime you want to online.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 03-19-2007, 08:32 PM   #22
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by brijbldr
Has anyone used this system, and have comments (good or bad) about it?
There are a lot of campgrounds out there that have WiFi access, but most places I have been, it's necessary to go outside the rig and sometimes walk a distance to get reception. If this works as advertised, it would be a big help.
http://www.anwdevices.com/iantenna30...Data_Sheet.pdf
Bruce
Looks like the primary point of those is to provide you with an ethernet port. I think it'd work but it seems unnecessarily expensive for simply boosting the signal strength. And the lower models (100 and 200) don't even support 802.11g - they're just 802.11b. Finally the 300 model has features you almost certainly don't need - Power over Ethernet, for example.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 10-07-2007, 12:21 AM   #23
Phil/Edee's Avatar
1999 25' Excella
Bemidji , Minnesota
Has anyone ever tried the "RVAirport" that's advertised on the Web?? It's supposed to let you connect within two miles of a "hotspot".
Edee
Phil/Edee is offline   Reply With Quote
Old 10-07-2007, 12:33 AM   #24
_
hi edee
looks like a nifty device...
i'm sure the 2 miles is 'line of site'...
and how often is that gonna be available, without something in the way?
this might be best for someone with a known regular wifi signal that is weak.
i'm using a verizon broadband cell card right now, and pretty pleased with nearly a year of usage coast to coast.
this is what phil gobie suggested in post #6 and i took his advice.
i'm in a deep dark valley right now in the western rockies and getting a 4 bar broadband signal...
really amazing and so i seldom look for wifi signals anymore.
cheers
2air'
Old 10-07-2007, 06:17 AM   #25
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by 2airishuman
hi edee
cheers
2air'
2air Dlink makes a WIFI router which has a port for a aircard, the router then is a Gateway for a WIFI network. Handy if you want to throw up a Hotspot for an office or a Rally.
Here is a information link: This one is 3G I thinke they have others.
D-Link 3G Mobile Router - DIR-450, DIR-451
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 10-07-2007, 09:59 AM   #26
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
The only problem with most of these solutions is it only half of the equasion.
You computer is only putting out the same amount of power. An external antenna can increase the range but not the power. Once all that power is exhausted then you are out of luck. You may be able to get feet or yards but not miles.
Michelle TAC MT-0
Sarah, Snowball
Old 10-07-2007, 10:39 AM   #27
_
Originally Posted by Jim Clark
2air Dlink makes a WIFI router which has a port for a aircard, the router then is a Gateway for a WIFI network. Handy if you want to throw up a Hotspot for an office or a Rally...
hi jim
yep, i've seen those, richL had one at topsail last year but a different brand. it is great for a rally!
the card i'm using is a skinny express 34 model and models that accept this card have been slow to appear.
the link below has an assortment of these routers...
Originally Posted by thecatsandi
...You computer is only putting out the same amount of power. An external antenna can increase the range but not the power...
cats...
i think the device edee referenced has a signal amplifier as well as antenna...
i'm using one from wilson technologies that boosts the signal (to 3 amps?) like the old bag phones...
so a weak or marginal signal or camping on the fringe of coverage...
will often get boosted significantly...as in miles.
artstream showed me this set up, he's been using with satisfaction.
we camped together where i had no cellular signal and he was registering 3-4 bars on the same provider...
that sold me.
i purchased here...
https://3gstore.com/
but wilson products are available at many big truck stops and other vendors...
cheers
2air'
Old 10-07-2007, 11:23 AM   #28
flint , Michigan
If you want to try a simple solution this is THE best usb card out there. It is amplified and you can attach an external antenna if you need to. All the hackers are using it. It's the lastest and greatest. ( don't ask me how I know ). I have one and it's unbelievable how many AP's show up. Having said that, If I was going to spend more time in my airstream I'd look at an external antenna.
The price is crazy on this site. I got mine for $ 60.
Amazon.com: USB 500mW WiFI Adapter for Wardriving & Range Extension *Strongest on the Market*: Electronics
flashbackk is offline   Reply With Quote
Old 10-07-2007, 11:59 AM   #29
Phil/Edee's Avatar
1999 25' Excella
Bemidji , Minnesota
The USB 500mW .... looks the best I guess.... The specs state Mac OS X Tiger. Wonder if OS X 10.3.9 will work ... or do we have to get moving and upgrade???? *)*
Old 10-07-2007, 01:27 PM   #30
2002 19' Bambi
Lafayette , California
On another thread (http://www.airforums.com/forums/f452/cell-phone-reception-34617-2.html#post423753 ), I cover the RadioLabs WaveRV antenna we have installed. As I reported there, it worked great on our recent trip and it does work with Mac OS X Tiger. If I recall correctly, however, OS X Tiger is not necessary. A quick check of the RadioLabs website should clarify that.
Tim A. is online now   Reply With Quote
Old 10-07-2007, 02:04 PM   #31
flint , Michigan
I know the Alfa works with Ubuntu and WinXP. I don't know why it work with any operating system. It uses Realtek rt8187 drivers. With my luck I'd check though.
Old 10-07-2007, 09:50 PM   #32
I have a wilson mobile amp for my truck with external antenna. Actually found it for about $5 more locally than online and walked home with it.
If we are talking about a wifi Amp then yeah range is better but it is only as good as the weakest link. Unless you set up both sides then one will be weaker and thereby limiting.
Michelle TAC MT-0
Sarah, Snowball
Old 10-07-2007, 09:58 PM   #33
Rich has/had a Kyocera. At the time he bought his it was the only one on the market.
I bought a D-link Mobile router. PCMCIA Slot, 4 port router and Wi-FI.
I have a Verizon Data Card. At the time it fit both my computer and the router. I bought a new Mac and it has the smaller slot. Now I have to use the Router to get online.
THe WI-FI works ok with the Mac. Something about being in a metal can disturbes the WI-FI.
Michelle TAC MT-0
Sarah, Snowball
Old 10-07-2007, 11:28 PM   #34
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Have you seen this???
ThinkGeek :: Wi-Fi Detector Shirt
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 10-08-2007, 08:56 AM   #35
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
That's too off-the-chain.
What will they think up next.
Family of Disney Fanatics
WBCCI# 4821
WiFi Question Steve Heywood On The Road... 11 05-27-2006 01:10 PM
WBCCI family/children/pet friendly? ViewRVs WBCCI Forum 66 01-08-2006 08:34 PM
Poor TV cable reception B&J 2002 - 2005 International 7 10-17-2005 10:58 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
Wireless Web Reception niftypkg General Interior Topics 1 11-08-2002 09:03 PM
