Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Computers, Internet & Satellite
Old 03-31-2012, 08:55 AM   #41
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Thanks for the post Ranger. A wiring diagram specific to Airstreams would be a great help. I tried to explain the wiring I could see in my trailer and am unclear how I can attach the Sky in the system I have to ensure I could watch cable at the same time the Sky is operating. And, how does the Pro differ?
I appreciate the attempt to allow easy installation. Many of us are trying to figure out how to run (or not run) cable into the trailer, so a system using the TV coaxial cable certainly simplifies that issue, but how to connect a unit to the existing wiring is the question.
This gets a little bit easier to understand over time.
Gene
Old 03-31-2012, 02:54 PM   #42
Zigidachs's Avatar
2017 23' International
Ridgefield , Washington
Great response! Thank you Ranger. The Sky appears to be an easy and reliable solution for CG's.
Question: when watching TV "over the air" , one must activate the "booster" function on the inside panel in the AS ( to use my grandson's language: the little green light comes on, papa) . If that booster button is not activated, does power still reach the bat wing to activate the Sky? That is the point of confusion in my head!
We ran wiring into our AS from a roof mounted Weingard Direct TV dish...works wonderfully BTW, and used the refer vents into the interior as with the cabling for the solar panel. Not an easy feat.
Thanks again, Ranger....now I have to decide btwn the Sky and the "booster" antenna/Pro combo for longer ranges......?
Zigidachs is offline   Reply With Quote
Old 04-01-2012, 09:26 AM   #43
The RVers Internet Choice
Meridian , Idaho
To answer your question zigidachs, the batwing power must be energized in order to send power up the cable to the Sky. So yes, "green light must be on.." in order to use WiFi with the Sky, and thats been the issue with some cable hookups.
CrawfordGene, I'll build a schematic showing my cable switch, the injector, and how its ll hooked up and get posted....
Remember, depending upon your set-up, you may need to use the added amperage injector included with the Sky, but its an easy install. The goal is to keep people off ladders and not drilling holes...
WiFiRanger is offline   Reply With Quote
Old 04-01-2012, 11:28 AM   #44
Master of Universe
Gene's Avatar
I like your goal, but I will have to use a ladder to get to the batwing antenna unless you supply pogo sticks too.
Sounds like there is no way around the cable TV problem unless I can bypass the TV antenna booster. This is a big issue for many of us.
Thanks for the schematic in advance.
I have scheduled a call with "Brian" for Wed. and hope he sees this thread and my e-mails to "Evan". Are you all the same guy?
Gene
Old 04-01-2012, 12:07 PM   #45
tpi
Trabuco Canyon , California
I had a Cradlepoint wifi router and Verizon PCIE 3g aircard. I used it for years and it worked very well. The wifi router had great range, quite a few campsites away under ideal circumstances.
I recently updated to a Motorola Droid 4 smartphone with built in wifi router, 4g. I used it for a brief trip recently.
Wireless wifi output range is much less than Cradlepoint, but sufficient for in trailer use.
4g is crisper and faster than 3g, noticeable on even web page loads, and very noticeable on file transfer. 4g coverage is spotty and limited to mainly urban areas.
Phone itself shows occasional signs of instability. When used as router, was generally stable for hours, but did suffer one disconnect.
I used to locate Cradlepoint/aircard for best reception, not always possible with phone. Sometimes I located it outside.
I updated mainly for the fact the entire package was about $10. month cheaper than carrying a standard phone and an aircard. I do enjoy the positives of having a smartphone, and the 4g speed.
tpi is offline   Reply With Quote
Old 04-04-2012, 10:58 AM   #46
Master of Universe
Gene's Avatar
I just talked to Brian from WFR. He was very helpful.
I had the whole idea of the Sky backwards or inside out or something. The box that mounts on the Winegard antenna is a wireless router. It, therefore, sends a wireless wifi signal into the trailer and anywhere nearby that has the password. It does not send the wifi signal it picks up from a campground down the coaxial cable.
The coaxial cable is attached to it and the Winegard with a supplied splitter. The only reason for this is to get the 12 v. that the antenna booster switch sends up to the Winegard antenna. I assume the actual TV antenna booster is mounted on the Winegard antenna and when you push the button inside, it powers the booster which must be located on the antenna. That is the only reason to send 12 v. to the roof. I always thought the actual TV booster was behind the wall plate with the switch and green light.
I was told WFR includes a work around kit if you have problems with cable reception and it sends a separate 12 v. up the cable without, apparently, activating the Winegard booster.
The WFR Pro is no longer sold, but it appears the features of it have been absorbed into the Sky. There is a Mobile product, but that one has to be hard wired into the RV. A metal box which is the antenna attaches to something outside and a cable has to be brought into the RV somewhere. I believe the router is inside and is not wireless.
I asked whether they could build a unit that does both cell and wifi. The answer was they are different technologies and incompatible. I figured that, but if they can get the technology into a phone, it has to be small and should be able to use some of the same box and antenna and wireless booster. This seems like an opportunity for an entrepreneur—get WFR and a cell booster company to work together and blow away the competition.
The WFR Sky is innovative. I assume they used the coax for the wifi signal, but they use it for power only. I doubt I could have thought of that. Usually an external antenna is nothing more. Maybe it helps that Kelly, the guy who posts as WifiRanger, owns an Airstream and none of us want to drill a hole in an Airstream roof.
This is a small company in Idaho (I think it is near Boise) and they seem very involved and willing to help customers.
I am inclined to buy this, but my wife has to approve a $250 expenditure.
Brian sent me a video and some other information and I'll have to look those over too.
I hope this helps. I may find out how the work-around works in looking at the info sent to me. I can kind of imagine how the work-around operates, but really am not very clear on that.
Gene
Old 04-04-2012, 12:44 PM   #47
2005 19' Safari
GLENDALE , AZ
I am also trying to decide which WiFi and cellular mobile broadband device(s) to purchase. So far, I am leaning toward the Pepwave Surf OTG (On-the-Go). For those interested, 3gGtore.com has the following videos on YouTube, which demonstrate the device:
3gStore comparison of CTR35, Pepwave Surf Mini and WiFiRanger:
3gStore review of Pepwave Surf OTG (On-the-Go)
Is anyone currently using the Pepwave OTG, or seen one actually in use?
Note: I have a Verizon/Novatel 727 cellular modem (a USB device that has never been used), which I intend to plug into the PepWave OTG when we do not have access to campground WiFi.
Old 04-04-2012, 01:01 PM   #48
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
The mud is starting to settle.
This is beginning to sound so simple we should have understood how it worked right from the start.
I would like to try the SKY but I also find the cost a bit on the high side. Maybe they could give us Airstream Owners the President's Day discount that was offered recently, and I would order one today.
The PepWave is also of interest and I will have to do more research on that. The link on their site will not show price.
Dave
Gene
Old 04-04-2012, 01:32 PM   #49
Master of Universe
Gene's Avatar
Yes, cost is a factor. The "Presidents' Day" sale extended until a week or two ago. The WFR Sky was $200 and they included a 2nd router (I guess it is the original router) for use at home. It is hard to forget that. Now it is $250 for the Sky alone.
If I knew then what I know now, maybe I would have jumped on it. But it has taken a while to get all this straightened out in my mind and I guess others too.
So perhaps Kelly, fellow Airstream owner and WFR inventor, should give us a special price. Maybe a Pre-Presidents' Day 2013 for Airstreamers Sale starting now. What do you say Kelly?
Gene
Old 04-04-2012, 06:34 PM   #50
Skater's Avatar
1995 30' Excella
Bowie , Maryland
One point of clarification: The Sky requires the batwing TV antenna, right? (We have the older "crank up and forget it when you leave the campsite" antenna style.)
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 04-04-2012, 06:54 PM   #51
Master of Universe
Gene's Avatar
It might be adaptable to other ones so long as you can get 12 v. to the Sky router. Check with WFR.
Gene
Old 04-04-2012, 07:08 PM   #52
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Or I could be an idiot - I'm not sure what the "batwing antenna" is. If it's this, then that's exactly what we have.
Old 04-04-2012, 07:49 PM   #53
Master of Universe
Gene's Avatar
Skater, I hate to tell you this, but I believe "this" to be the batwing.
Gene
Old 04-04-2012, 11:33 PM   #54
Meridian , Idaho
Gene
I say that sounds like a good idea! Of course there's all those sales and marketing suits that I have to deal with.
Let me get an "AIRSTREAM" coupon code up this week for a great discount. I'll get it valid on Friday for an Sky, and an included WFR Pro indoor unit as well. I'll post here the deal.
Also, on the 3Gstore "shootout" there are some real issues with what they did. The PepWave OTG is a good product, but the problem they made was that they tested the WFR in the middle of the other units, without powering down the outer units. Imagine stnding in the middle of two people talking to each other, and trying to listen to someone 10 feet away. We plan to do our own shootout soon, and with The Sky mounted outside, we anticipate a significant different result.
If others have questions, let me know. I'll jump on getting them answered.
PS. Evan, Brian, David, and Kelly are not the same human. (Thank Goodness!) None of us would want to be any of the others!
Old 04-05-2012, 05:23 AM   #55
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Gene
No, it's fine! For some reason I didn't think of that being a batwing antenna - I thought "batwing" referred to one of those fixed antennas kind of like you see on limos sometimes. Since your trailers were newer, I just assumed they were using a different antenna. Anyway, this is one case where I'm happy to be wrong.
Now my wife is very interested, too. Unfortunately, we're trying to save up for some things, and we recently had to replace a car well before we planned, so I'm not sure if we can talk ourselves into it. Still, it would be nice...
Another question: Does it need another router inside? Or does the router on the roof do everything? (Edit: Ooops, I think I see that answer now: Broadcasts 1x Private / 1x Public. So, yes, it can work solo.)
Old 04-05-2012, 11:23 AM   #56
Master of Universe
Gene's Avatar
My understanding is that all you need is the router on the Winegard antenna. You will have to use a password to keep that guy in the MH next to you from latching onto it. If you get the
Mobile, you will get better range because it is not transmitting through the roof, but is hard wired and has the router inside. But the Sky claims about .47 mile—how much do you need?
When you use your computer or other device, I believe you will get a box on the screen showing you which wifi signals are available, their strength, whether they need passwords and such. I think you can pick the one you want. Apple products give you some of this info from their antennas, but this should be more thorough.
There is the law of diminishing returns. CG's only have so much bandwidth and it seems those closest to the CG antenna get the best reception. The guys with the best boosters are going to get a bigger piece of the bandwidth until everyone has a booster and everyone is back where they were. Some companies that supply the equipment to CG's (Tengo for ex.) restrict bandwidth a lot and no amount of booster may help that much. Tengo is all over the west coast now and I always make a point to express my disappointment to a CG when they have that. Usually I can't upload photos until late at night or before dawn or maybe in the middle of the day; sometimes at Tengo wifi places I can't even get a weather map, map to somewhere I am going and many other websites. It works fairly well for e-mail and not much more if a lot of people are using it at once.
A booster will help and not everyone will get one. The future should have a system of universal wifi, but we are far from getting that. Efforts to bring that to some cities failed several years ago. The best we are getting are expensive cell data plans.
Gene
Old 04-05-2012, 11:54 AM   #57
1974 Argosy 20
Kooskia , Idaho
Originally Posted by Nuvite-F View Post
I second your advice--one of the big advantages of the old USB-720 is that it does have a connector for an external antenna. I use a Wilson Trucker with good results. Product Details
Are you confusing Megabytes (Mb) with Gigabytes (Gb)? 1 Gb = 1000 Mb
Nowadays to email one snapshot commonly takes 4 or 5 Mb. At frequent intervals Microsoft wants us to download 10 -20 Mb of software upgrades.
Yes, and I know better. GB, GB.... grin.
Old 04-05-2012, 12:12 PM   #58
Master of Universe
Gene's Avatar
And TB isn't a disease anymore. Damn names and acronyms change too often.
Vaguely connected to nomenclature, the very young guy I talked to at WFR had never heard of kilocycles or megacycles. He didn't know Hertz was a guy and he didn't rent cars. He did know about the WFR products though. I guess he didn't know "applications" used to be "programs", but we didn't get that far.
Gene
Old 04-05-2012, 12:26 PM   #59
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Okay, we may be in for one Sky... waiting to see what the Airstream deal is.
Old 04-05-2012, 03:31 PM   #60
Zigidachs's Avatar
Wi Fi Ranger: Can you provide more detail please on the "work around" for the Sky and the booster setting ( "green light") which interferes with cable TV reception? e.g. cost, installation, location, etc..... If you can provide me with that info, I " am on board"! Thank you....Zigi
