Old 03-25-2010, 09:42 AM   #1
Elkhart , Indiana
WiFi inside Airstream
Need help with feedback for a marketing presentation regarding WiFi inside your Airstream. New features of electronics are wi-fi enabled or wi-fi ready so customers can download music and movies, my question is "do you have any trouble with wifi working inside your Airstream?" Your feedback is greatly appreciate!!
abecknell is offline   Reply With Quote
Old 03-25-2010, 09:56 AM   #2
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
We use a Verizon card in our Mac computers. It works extremely well anywhere we can get a decent Verizon signal. However, we do seem to notice a significant signal loss inside the AS.
hhendrix is offline   Reply With Quote
Old 03-25-2010, 09:59 AM   #3
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
If you want reliable reception, you are going to need an external (to the trailer) antenna. The Airstream's all aluminum body is a very effective shield. Therefore reception inside is highly dependent on your location within the trailer and the direction of the wireless access point. It is not very predicable and signals coming in through the windows will reflect off the interior walls and combine at the receiving antenna to either enhance or derogate the signal received at the wireless device. At times movement of the wireless device by inches will make the difference between good and no reception. My previous trailer had a fiberglass body that the signal could travel through, and my laptop would operate with wifi signals equally well anywhere in the trailer.
hope this helps some.
Ken
Old 03-25-2010, 10:02 AM   #4
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Welcome to the forums!
Hi abecknell, If you take a look at this section Computers, Internet & Satellite - Airstream Forums you will find a few threads discussing the interference that the aluminum tube provides. Nomally you will get better reception on the outside of the Airstream.
This is a good section to review too. Airstream Forums - Airstream Owners Community- Community Rules
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-25-2010, 12:13 PM   #5
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
I think the primary determining factor on Wi-Fi in the Airstream will be proximity to the Wi-Fi antennae and signal strength. I have used my laptop inside my Airstream parked in the driveway using my original wireless router inside the house with no problems. I recently replaced the router with the same brand and sometimes have trouble with signal strength inside the house!
Family of Disney Fanatics
WBCCI# 4821
Old 03-25-2010, 12:17 PM   #6
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
As noted by w7ts, the signal strength will improve by getting an antenna outside the trailer. Realizing that most of the newer devices have built in wifi antennas, my solution for my first laptop was to buy a PCMCIA wifi card with an external antenna jack. (This card interface has pretty much been replaced by the ExpressCard slot). This enabled me to add either an omni-directional, or a directional antenna (such as a Cantenna). The external antenna helped a great deal.
I found that Cantenna also sells a device that enables it to be hooked up to a USB port.
Cantenna | Connect to Your Laptop
Hope this helps.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 03-25-2010, 12:39 PM   #7
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
My MacBook works great without externals. In some RV parks, I've had to move the coach to avoid "bounce back" reflections.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 03-25-2010, 02:16 PM   #8
memgrove2000's Avatar
Elkhart , Indiana
Send a message via AIM to memgrove2000
Are you looking to due some testing? I am in Elkhart, if the timing is right I may even bring the unit over to your place.
Mike
Have a great day!
TAC # IN 1 Air#27922
memgrove2000 is offline   Reply With Quote
Old 03-25-2010, 03:17 PM   #9
Mike Leary's Avatar
Images: 11
This would be a option if one really had wi-fi problems.
Old 03-25-2010, 03:54 PM   #10
can't finish anyth
GolfStream's Avatar
2006 19' International CCD
2010 28' International
Dallas , Texas
This is what you need:
SOHO All-in-One Wireless Repeater Kit for RV [SOHO-KIT-RVPANEL] - $641.84 : 3Gstore.com, Mobile Broadband Made Easy. CradlePoint Routers, MiFi, Antennas, Amplifiers and Verizon & Sprint EVDO Modems.
Javier
Dallas, TX
2010 28' International CCD
(tricked-out techie twinkie)
2007 Ford F-150 SuperCab.
2010 Touareg TDI
GolfStream is offline   Reply With Quote
Old 03-25-2010, 05:40 PM   #11
1980 31' Excella II
Drummond Island , Michigan
I am the WiFi guru at our RV park. We have an excellent wifi system after fiddling with the antenna and replacing just about everything from the incoming DSL line to all the hardware. The wifi signal is pretty much uniform through out the park except one area where we will have to install a repeater. The signal inside our A/S is spotty. The problem is the double wall aluminum construction. I installed an outside antenna and solved the problem. After much research looking at bridges, cantenna's, sophisticated and expensive amplifiers. We went with a JefaTech repeater www.jefatech.com. It uses a reprogrammed Linksys router with an omnidirectional 8.5db antenna. You can build one yourself and the software can be downloaded at www.dd-wrt.com. However we bought the whole setup from from JefaTech for about $150.00 which included the router, antenna cable, antenna and mount with the software already installed. If you bought those items separately it would cost about the same and you would have the hassle of finding the pieces and modifying it. Whats nice is you get a very strong signal and with the router in the A/S and both my wife and I can use our laptops anywhere in and around the trailer with out wires. Two other people in our park saw our setup and have also gotten the Jefatech units. Whatever you do I would recommend having an external antenna that is omnidirectional rather than directional like a cantenna because the directional antenna's are limited by direct line of sight which can be problematic. 8.5db is more than enough. Your wifi signal is a two way street, often times you can find and sign on to a wifi source but will be unable to download anything. The problem is the incoming signal and download speed is strong and fast from the source because of a powerful antenna but the upload is weak coming from your laptop because it has a small transmitter and the emitting antenna is small enough to be buried in your machine. You can hear them but they can't hear you. An external antenna mitigates this problem.
Ahzmyrah is offline   Reply With Quote
Old 03-25-2010, 05:46 PM   #12
We use Verizon prepaid wireless at $50 per month without a contract, so we can discontinue when we return home to the U.K. Remarkably, we have never had a failure to connect in the 4 months we have used the system, at about 20 different locations in FL, all inside the trailer. If we put our heat reflecting metallic sunshields over all the windows, the system slows down, but it has never failed.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 03-26-2010, 08:12 AM   #13
CanoeStream's Avatar
St. Cloud , Minnesota
Ahzmyrah, good comments!
WiFi at marinas shares similar distance issues. This is a huge discussion thread over at our sister site, CruisersForum -- Long-Distance WiFi Device - Cruisers & Sailing Forums
5 meter Langford Nahanni
Old 03-26-2010, 08:21 AM   #14
Aha -- I knew Terry had enhanced the location of his cantenna. Other good posts from experience. http://www.airforums.com/forums/f451...-go-54832.html
Locking airstream door from the inside Lothlorian Doors & Locks 6 01-10-2010 06:35 PM
Reclining inside the Airstream cbgenrich Full-Timing 37 03-14-2009 07:05 AM
Motorcycle inside Airstream? Foureagles Towing, Tow Vehicles & Hitches 25 01-08-2008 03:19 PM
No Electric Inside Airstream LetsRollAZ Electrical - Systems, Generators, Batteries & Solar 12 12-26-2007 08:59 AM
Using an Airstream inside a restaurant SilverCottage On The Road... 9 06-04-2007 09:36 PM
