10-05-2012, 09:20 AM
#21
Warrenton
, Virginia
Great info here. I agree with the last few posters though. With today's smart phones and data plans/speeds 3g/4g you don't need to add equipment to get connectivity on the road.
For instance I can use my Verizon iPhone 4 to make it a mobile hot spot for any laptops that need connectivity... Hotel/campground Wi-Fi coverage and spped can be spotty to non-existent.
Unless you need to boost signal in remote locations, I wouldn't get crazy on buying expensive add-on's that will be obsolete in just a few years.
Security note! Lock down your wireless network connections. You never know who could be sniffing you!
Trailer: 1948 Spartan Mansion 30'
Tow Rig 1: Hers 2010 Cadillac Escalade ESV
Tow Rig 2: His 2010 Porsche Cayenne S
Others: 1971 Chevy C-10 with 5.3 LS and T5 conversion, 1983 Jeep Cherokee Pioneer (FSJ) with 5.3 LS and SM465 conversion, 1979 Porsche 911SC
10-05-2012, 05:33 PM
#22
1995 30' Excella
Bowie
, Maryland
Originally Posted by Freedomrider
We have not decided on a system yet. Still trying to educate myself so that we will get the equipment that fit our needs and buy right the first time. Thanks for you advice.
Yeah. The issue is that it's basically impossible to fish wires through the skin. Ideally you'd get them to run a piece of conduit or something so it'd be easy to fish wires through. That's probably not really feasible, either. But if it were me, I'd run some cat 5 or 6 cable and one of the wires that cellular antennas use, and have them run the ends to somewhere convenient in the camper, like near the radio. Cat 6 can carry data + power (low power, but enough to run an antenna; this is how campgrounds do it).
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
10-05-2012, 06:06 PM
#23
Port Orchard
I would first try to route any wires I needed though places where other things already go in or out of the skin. M first attempt would be to try to get a cable snake or perhaps some other thin strong wire to route alongside the umbilical cord. Our trailer has three small compartments with doors in the rear of the side belly wrap. The city water and TV cable are already in those compartments, so I would look there also for places to get access to the inside. Our battery compartments have drain openings under the doors. Those could provide access to the inside. Another option is to use the top refer vent to feed wires to the refer compartment and then through the walls to inside. I am sure if I was trying to do this, I would discover other access as well. I know right know I could get a wire into the bottom of our closet by drilling a small hole in the pan that covers the bottom of the holding and fresh water tanks. Just some ideas.
Ken
10-06-2012, 07:12 AM
#24
1995 30' Excella
Bowie
, Maryland
Ken
I know. But he's having a new Airstream built. Much better to do it then. :-)
10-06-2012, 08:19 AM
#25
Port Orchard
It may be easier to do then perhaps. Better is open to debate, because it will be very expensive to do it then. On a new Airstream order, any customizations not listed as an available option are priced at $500 each plus parts and labor. If it were me, I would wait until I got it.
Ken
10-07-2012, 02:09 PM
#26
2009 23' FB Flying Cloud
Toronto
, Ontario
A few comments:
Internet via Smartphone:
The monthly data limits with smartphone accounts are generally low.
Verizon is, I believe, no longer offering any plans with unlimited data and has instituted a surcharge ($20/month) for existing users if multiple devices are connected through their smartphone and existing users who upgrade their phones lose their unlimited data.
I am not familiar with other carriers.
Verizon is still offering "mobile hotspot" devices - a newer model than the 4510L is available.
Signal Strength:
We found Verizon WiFi connections in 3 Florida state parks of the 10 we stayed in last winter to be poor (slow) or non-existent - this was corrected with a Wide Band Directional Antenna (304411/304475) ($70 at Radio Shack) WITHOUT an amplifier even though at that time our newly acquired antenna was INSIDE our AS. Wilson ( Antennas | Store | Wilson Electronics) also sells a small amplified indoor antenna that could be used with a mobile WiFi access point - I have no experience with these.
Verizon is reputed to have the best coverage (in Florida) and is installing more access points (towers) all the time but we found that even high population areas reception could be poor without the antenna perhaps in part due to the metal shell of our AS.
Installation:
The Wilson antenna is compact (longest dimension is 11.5") and can be mounted almost anywhere on the roof thus avoiding the need to snake cables any distance - we snaked our co-ax 2' to pop out beside an inner wall (stay away from those rivet lines!). If you don't mind a small co-ax cable running along the ceiling installation can be done with no snaking.This antenna is easily retrofitted to the Winegard mast.
Do not use RJ45 cable in place of co-ax with an antenna as this would degrade the signal - we required a 50 ohm antenna (and co-ax) for our MiFi.
A rotating mast is needed with this directional antenna.
Once inside the RV cable can be routed alongside the water supply lines quite easily but as our MiFi connects wirelessly to laptops and tablets this was not necessary.
Hope this is useful information.
10-10-2012, 08:19 PM
#27
2005 19' Safari
GLENDALE
, AZ
Correction -- No one probably noticed, but I left out the MiFi 4510L in my previous post:
Verizon Cell Tower => External Cellular Antenna => Cyfre Cell Amplifier => MiFi 4510L => PepWave SOTG => Laptop/Kindle Fire/Other WiFi-connected devices (e.g., iPhone, iPad, etc.)
11-04-2012, 07:58 PM
#28
1987 32' Excella
Nepean
, Ontario
Internet access is a priority item with me inasmuch as I have a small commercial web server and I need to monitor it. At home it's not an issue, as I have cable extreme, but when I travel south for the winter, I need wide coverage and access. What works for me is Verizon's 5Gb plan using a small USB dongle or air-card - Verizon's coverage is, as far as I can tell, wider than any of the others I've used (I had been with AT&T - poor coverage in the western states, and Virgin - cheap, but congested in Arizona). However, the dongle or air-card by itself doesn't cut it in fringe areas, so I had a cellular antenna mounted on the roof, and I have the Wilson amplifier with the inside pickup antenna. I also use a Cradlepoint router. The Cradlepoint is a very small wireless router into which the air-card is plugged (it has a USB port for this purpose). The Cradlepoint does all the negotiating for ISP connectivity. Thus the inside of the trailer is a wireless network. My printer (a Brother laser printer with a wireless nic), my laptop, my iPod are all connected wirelessly together and to the internet via the Cradlepoint. Since most of the places I visit are in the boonies, 4th generation cell service is not a consideration; hence my older Cradlepoint serves my needs just fine. As far as costs are concerned, the Verizon plan is $59/month and the Cradlepoint router was purchased on eBay for $25.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
11-06-2012, 08:37 AM
#29
2013 30' Classic
Lakeland
We decided on our WiFi system. Phoenix, thanks for the info, it was very helpful. The system is the "WiFi Ranger Connect-RV Pack. It includes the 4620i MiFi, MiFi Ranger Mobile, Wifi Ranger Go and all installation hardware. Our Airstream dealership will do the install. We wanted this system to take advantage of the 20GB. With the extreme range, it should keep the wife happy. She lives on the internet.
Now, we just hope all this arrives before picking up the Airstream. We pick-up our Airstream on Monday, finally.
Thanks again.
11-06-2012, 09:38 AM
#30
2005 19' Safari
GLENDALE
, AZ
Freedomrider, just reread this thread from the beginning to end and noticed your comment about traveling in Canada. See FAQ response from the Millenicom site:
"Can I use this out of the country? -- Never use your Millenicom mobile broadband service outside the United States. Whenever near an International border (within 20 miles) please turn off “roaming” so that it does not pick up neighboring towers. Failure to do so may generate enormous usage fees. Seriously, the fees are enormous."
Sorry for not noticing this before. You may wish to purchase a separate Canadian prepaid hotspot device or service plan when traveling in Canada.
11-06-2012, 06:07 PM
#31
1987 32' Excella
Nepean
, Ontario
Canadian service is considerably more expensive that US service. Your choices are limited: Bell (CDMA) or Rogers (GSM).
Depending on where you travel, such as in northern Ontario (the 807 area code), you may find that Rogers does not have coverage. For example, we were in Sioux Lookout, which is 90 km north of Dryden. The only cell service there is T-Bay Tel (who just happens to own all of the 807 area code), and it is CDMA only up there.
VE3JDZ
AIR 12148
WBCCI 8080
