Old 03-20-2019, 10:10 AM   #1
2018 27' Flying Cloud
Atlanta , Georgia
WeBoost using satellite connections
My Airstream has connections for both cable and satellite on the side. I do not have a satellite receiver.
I want to install an exterior antenna for a WeBoost system to boost cell signals.
Can I use the satellite connection on the side of the trailer for the RG6 cable from the exterior antenna and avoid making a hole in the trailer? I would then put the WeBoost amplifier next to the DVD player where the satellite cable appears inside the trailer.
Anyone see a problem with this?
jnm30327 is offline   Reply With Quote
Old 03-20-2019, 10:16 AM   #2
2007 22' International CCD
As long as the antenna cable is RG-6 itís worth a try. The only issue would be if the internal cable is badly shielded or not decent quality cable. Itís not going to damage the hardware, if thatís a concern...
Old 03-20-2019, 11:10 AM   #3
2020 Classic 33 on order
Box Elder , South Dakota
Works fine if you have a WeBoost that uses f connectors, like the RV 65.
Gary
2020 Classic 33 Twin on order
NōVPN
ghaynes755 is online now   Reply With Quote
Weboost install chaeha Electronics & Connectivity 221 09-12-2018 07:13 AM
How I installed my weBoost Drive 4G-X OTR on International 27FB tot2learn Electronics & Connectivity 18 07-10-2017 02:53 PM
Pepwave MAX BR1 / MobileMark / weBoost install Ohiobrits Computers, Internet & Satellite 17 09-27-2016 07:26 AM
Update: WeBoost Drive 4G-X BoldAdventure Computers, Internet & Satellite 8 10-22-2015 02:30 PM
Using Satellite tv ALANSD Electrical - Systems, Generators, Batteries & Solar 46 04-22-2006 08:22 PM
