Old 08-29-2016, 06:34 AM   #1
2016 30' Classic
Houston , Texas
Weboost 4G-X vs WiFi Ranger
I believe I know correctly that the 4G-X is a cellular booster and the Wifi Ranger is a wifi booster. That is, each is designed for a very different purpose. I am interested in the 4G-X (with SureCall Omni antenna) to boost the signal my ATT iPhone receives - I have been thinking that I could use the iPhone as a wifi hotspot for my iPad, etc.
I have several questions:
1) Does it make sense to consider using both devices? Foe wifi purposes, will the Wifi Ranger work significantly more effectively than the 4G-X / hotspot technique?
2) If using both devices at the same time, do the devices interfere with one another? Do the two devices' antennae need to be kept apart on the AS's roof?
Any other advice most welcomed.
Thank you.
dhroberts is offline   Reply With Quote
Old 08-29-2016, 10:39 AM   #2
2016 30' Classic
Erie , Colorado
You are correct, two different requirements. Phone as a hotspot works but depends on carrier. With my Verizon, voice shuts off data so if you are on a call data is not working.
The WiFi Ranger would help with distribution of a WiFi signal either from your phone or using a data MiFi device. 4GX boosts cellular. WiFi Ranger (by itself) is the same as any other wireless router but has the ability to interface to a MiFi Device. So do some other routers.
WiFi Ranger with an external antenna (Elite) will pull in weaker WiFi signals and make them usable.
No they do not interfere with each other.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 08-29-2016, 10:48 AM   #3
2017 27' Flying Cloud
London , Ontario
Is there no device available that will boost both 3G/4G AND WiFi signals? It would be nice not to have to buy/install two things if one would suffice! Thanks for any advice.
Philip Jones is offline   Reply With Quote
Old 08-29-2016, 10:49 AM   #4
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
....following
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 08-29-2016, 11:16 AM   #5
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
You need both a wifi ranger and a weeboost if you want to boost both wifi and 3G/4G/LTE cellular.
I have both - they are both great products.
I have a very "connected" trailer with 2 IP TVs, multiple devices, etc all requiring internet access.
When public wifi is not available (boondocking etc) I use the we boost unit with antenna cable connected directly to my Verizon jetpack to pull in LTE data/internet from the cellular network. I then tether into my wifi range via USB to supply it with Internet.
All my devices, regardless of the source of Internet (wifi or cellular) connect to my wifi ranger for LAN and Internet gateway.
AT&T allow you to call over wifi now (at least on an iPhone) so I only worry about pulling in a reasonable fast Internet signal... also - the nice thing about the wifi range is that it can combine both public wifi from a campground and LTE internet from a verizon jetpack/ipohne/etc.. for the faster speeds by leveraging both internet sources ...
wulfraat is offline   Reply With Quote
Old 08-29-2016, 11:42 AM   #6
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Me too
Old 08-29-2016, 12:19 PM   #7
369goose's Avatar
2014 25' Flying Cloud
1987 29' Sovereign
1977 31' Sovereign
Tampa Bay , Florida
Also following...thx
☘ 369goose
"The world is a book and those who do not travel read only one page. St. Augustine
369goose is offline   Reply With Quote
Old 08-29-2016, 12:44 PM   #8
Parker , williamdcrockett
I have the weboost and the wifi ranger. I have not noticed any interference when using both but I seldom use both. If I have a WiFi signal I typically do not need to boost a cell signal and when I have to boost a cell signal I typically have no external Wifi for the Ranger to pickup and amplify. I use an AT&T hotspot with my weboost. I have pasted my Amazon review of the Weboost below:
"I installed this 1st in my RAM pickup truck. It seemed to work okay but I did not do use an accurate test method because I was continuously moving at speeds of 70 mph. I do think it helps the signal but not sure how much. Then I installed it in my 27' Airstream while parked in the mountains in Montana. I had no service or occasionally one signal bar on my iPhone 6 and Netgear AT&T hotspot without it. With it plugged in and the phone or hotspot sitting right by the inside antenna I got 4 bars with good cell service and internet access. But if I moved the phone a few feet away from the antenna the signal dropped to 2 cells, 1 cell or no service at all. This was not expected because it literally was less than 3 feet from the antenna. The best way to use this product is to sit the phone or hotspot on the inside antenna if you have poor service. My AT&T Netgear hotspot worked better that my iPhone 6. It maintained 1 or two bars while a few feet from the antenna but upload and download speeds were very slow. Putting the hotspot right on or a few inches from the antenna gave me 4 bars and acceptable upload and download speeds. I bought a 20 gauge 12"x18" steel sheet from Lowes for $5 to place the outdoor antenna on the roof of my airstream. The Airstream is made with aluminium so the magnetic outdoor antenna would stay on the roof. Tech support also says the antenna needs at least 5"x7" steel surface for best reception. It takes only a few minutes to setup up the booster so I am not going to permanently mount it. I will move it from the tow vehicle to the airstream as needed. Because the phone has to be so close to the antenna a bluetooth connection is the best way to use it to make phone calls."
wcrockett is offline   Reply With Quote
Old 08-29-2016, 02:21 PM   #9
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Subcribed
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 08-30-2016, 06:37 AM   #10
2016 30' Classic
Houston , Texas
Thanks for the comments. OK, I have decided to go with both the Weboost 4G-X (with the SureCall Omni external antenna) and the WifiRanger Elite Pack FM.
2 questions:
1) Regarding internal antennae: Do I need both a Weboost internal antenna and the WifiRanger GO2?
2) Regarding the WifiRanger: Do you have to be careful regarding the separation of the external and internal antennae as you do with the Weboost external/internal antennae?
Any advice is appreciated. Thanks.
Old 08-30-2016, 10:06 AM   #11
2016 30' Classic
Erie , Colorado
Philip I don't think I have seen anything that does both. I've seen WiFi routers that have embedded cell data capability, you put the sim card in the router, but nothing that also boosts the cell signal. Cell Boosters are tightly regulated by the FCC and carriers. WiFi devices are also regulated but no where near the extent of a cell booster.
Gary
2015 Classic
ProPride
NVPN
Old 08-30-2016, 11:25 AM   #12
lewster's Avatar
Naples, FL , Hood River, OR
I did a solar upgrade for a client about a year ago who was using a Cradlepoint (I think that's the name) device that I believe did both thru a multi port dome roof antenna that had 4 separate cables coming from it to the device.
Lew Farber
Old 08-30-2016, 02:59 PM   #13
2016 30' Classic
Erie , Colorado
The Cradlepoint does have cellular built in but is not a booster like the WeBoost products. It would have the benefit, if using a roof mounted antenna, of pulling in a better signal for the cell side.
Gary
2015 Classic
ProPride
NVPN
Old 08-30-2016, 03:21 PM   #14
wulfraat's Avatar
2 questions:
Good call...
"Do I need both a Weboost internal antenna and the WifiRanger GO2?"
Short answer is yes. 2 different products - one has a wi-fi antenna (wifi ranger) and one has a 3/4G/LTE antenna (weboost). Different products and different radios. Regarding the weboost internal (inside the trailer) antenna to receive the signal from your mobile device for "boosting" - you actually have 2 options - (1) use the internal antenna supplied with weboost - I believe you need to have your device within 18" (eighteen inches) of the internal antenna for best reception / boost or (2) if your mobile device that you are "boosting" has the ability for a hardware antenna you can physically connect the device to the weboost via a simple 3rd party coax cable. I use method "2" for hardwiring my verizon jetpack into the weboost for maximum performance. The cable to physical antenna coax cable required to connect the jetpack to the weboost costed about $10 from easy. obviously if you are boosting an iPhone or what have you these devices require the internal antenna because they do not have the option to connect an external antenna via coax.
" Do you have to be careful regarding the separation of the external and internal antennae as you do with the Weboost external/internal antennae?"
Yes. You will want to position the external wi-fi ranger external antenna far from the internal WIFI GO router unit with it's built-in antenna for maximum performance. same for the external weboost antenna - position it as far away from the weboost base/core for best performance.
....that being said my small little weboost and wifi-ranger external antennas are probably only 2-3' linear separation from my internal antenna and it has worked fine, but technically I should have positioned the external antennas farther away.
Weboost install chaeha Electronics & Connectivity 211 01-24-2018 03:13 PM
Wifi Ranger Installation Whelan Computers, Internet & Satellite 8 09-30-2016 12:32 PM
WiFi Ranger master thread Gene Computers, Internet & Satellite 174 08-14-2015 11:42 PM
WiFi Ranger on 12 volt power or 110 AirstreamBee Electrical - Systems, Generators, Batteries & Solar 8 05-30-2015 04:12 AM
Need Assistance With WiFi Ranger Sky Hibby Computers, Internet & Satellite 8 09-06-2012 08:11 PM
