04-07-2016, 04:20 PM
2017 25' International
Los Osos
VPN...Virtual Private Network..Worth It?
I'd like to be able to use my Mac laptop on the road and use RV Park/Public WiFi. I've been told that I should use a VPN, Virtual Private Network to ensure security.
Has anyone had experience with VPNs and if so could you recommend a particular one?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
04-07-2016, 04:29 PM
2016 25' Flying Cloud
Jupiter
I use a VPN every day to connect to my employers network. A VPN basically extends a private network across a public network like the Internet. What are you wanting to do with your network connection?
Unless you specifically want to connect to another network over the Internet, I don't think a VPN is what you want. You should only connect to secure networks if you plan to use your connection and do things like banking etc. A secure network could just be a SSL (HTTPS) connection to something like your banks website. I wouldn't do that over an open Wi-Fi network though.
04-07-2016, 04:46 PM
1972 31' Sovereign
Lexington
Did a google search and found this web site: http://www.thetop10bestvpn.com/
Info on it might help you make a decision.
Chris
04-07-2016, 04:50 PM
Los Osos
How would you assure security over an open WiFi network, such as in an RV park? Yes, private and financial communication.
I'd normally use my Verizon WiFi Jetpack but I'll be traveling in parts of North America where Verizon is not available or strong enough for a data connection.
04-07-2016, 05:09 PM
Jupiter
You can't. If the connection between your laptop and the Wi-Fi router is open, that means it's not encrypted in any way, and could easily be sniffed by anyone within range. You'd basically be passing your information for all to see. RV Parks should follow the lead of most hotels, where you need a password to connect to Wi-Fi, and encryption is being used. I would save the personal and financial traffic for when you can use your Verizon Mi-Fi device, which I hope you have setup with a strong password.
04-07-2016, 05:16 PM
I'm In
, Kentucky
A VPN is a secure connection over an unsecured network to a target network, like your home or office network. From there you can go back out to the Internet if you wish, but you need to have a target network at the other end of the VPN tunnel. I've read in here where some have set up a VPN to their home network to use that machine to access their bank accounts etc. My company has a VPN for me to log into and access their systems.
I use a Verizon Ellipses Jetpack for all things personal and for work if the park's wifi isn't strong enough. When you are on a public network, one that doesn't require you to log into an assigned account, you are vulnerable. Public wifi is good for hooking up your Roku or other media player to access online videos. There's nothing for someone to hack into on those devices. Except for one just recently, my experience has been that park wifi has been too weak to support even the most basic type of connection for surfing let alone streaming video.
Verizon has several pay as you go options, from 250 meg ($20) to 10 gb ($100). A VPN is a good way to go if you're going to try and use a park's wifi but I just don't think there's enough bandwidth to support your needs. A portable hot spot is your best bet, or share you smart phone's hotspot.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
04-07-2016, 05:26 PM
2021 25' Globetrotter
Somewhere
So it depends on what you want to use your connection for - the concern is a man-in-the-middle attack when the adversary is able to capture your traffic, and then gather required sensitive information from your network traffic.
As a previous poster mention https as a means to protect some traffic you should still not do anything sensitive over us trusted network access, wired or wireless. SSL traffic is only secure if you trust the public key infrastructure of the site you're connecting to. Always check the certificate authority providence.
Only you will be able to know your own requirements but take a look at the spreadsheet linked in the article to determine some needs.
http://www.lifehacker.com.au/2016/03...-best-for-you/
04-07-2016, 05:30 PM
Somewhere
Not just home or business networks have this - educational institutions often provide a vpn to provide online access to paid resources. More importantly in this case, there are vpn providers that provide the service for a fee.
04-07-2016, 05:42 PM
Los Osos
I guess I was under the impression that the VPN provided a secure network from your computer all the way along the line to the end of the tunnel and used their network to securely connect you to the web address that you desired, i.e.: bank.
04-07-2016, 05:47 PM
2015 30' Classic
Pleasanton
I use PIA at home and when travelling. www.privateinternetaccess.com. It's quite affordable and very solid. You can determine which exit point you prefer - even in other countries. This is quite convenient if you travel abroad and still would like to access Netflix/Hulu, etc.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
04-07-2016, 05:56 PM
2016 28' Flying Cloud
Brandenburg
, Kentucky
proXPN
I have been using proXPN for awhile now and am very happy with the performance and security. This software has a good number of VPN servers to connect to to ensure good service.
04-07-2016, 06:22 PM
Los Osos
Do you feel comfortable conducting financial transaction using the PIA VPN?
04-07-2016, 06:42 PM
2015 30' Classic
Pleasanton
I feel much more comfortable with it rather than without it. I also run it on a Synology file server and haven't lost a connection for months. Perhaps I'd feel differently if they were using a non-standard protocol, but they support the latest VPN protocols.
Al, K6IV
04-07-2016, 07:09 PM
Remember, Safety Third
Catfish Corners
, Georgia
Vpn 101
Check out this video. Leo is long-winded sometimes, but he's full of good info. We don't use public WiFi for "important stuff", but if we needed to (as in full timing, etc) we would have a VPN. Ya just never know what's going on in the background with WiFi Hot Spots.
I use VPN for work nearly every day (required to for most things). Very few problems with it. Setting it up can sometimes be a pain, just so you know.
http://techguylabs.com/episodes/1271/what-vpn
04-07-2016, 07:13 PM
Los Osos
I admit that some parts of the conversation are a little over my head.
My scenario again if you please. In my Airstream, on public WiFi using a VPN, for example PIA.
Given that there exists nothing else under my control in the pipeline that leads to my bank, will my connection be secure?
04-07-2016, 07:23 PM
2015 30' Classic
Pleasanton
As I understand it, if you're only using your browser to access your bank via public Wifi using https, the connection is already secure. The VPN adds an additional layer of encryption that will make it more difficult for other folks on your shared public WiFi to hack back into your computer. If I am mistaken I'm sure others will shine in to correct me
Al, K6IV
04-07-2016, 07:50 PM
Catfish Corners
, Georgia
Here's another Leo discussion on the topic: http://techguylabs.com/episodes/1268...hile-traveling
Good info. The internet is a really scary place these days. Not to deter anybody....just trying to through the information out there for thought.
04-07-2016, 08:14 PM
2020 Classic 33
Box Elder
, South Dakota
So I get the issue with public WiFi. But unless you are tethered (hardwired) to your MiFi device and simply connected via WiFi if someone really wanted to sniff your connection you are still exposed between your MiFi device and your laptop. VPN still isn't going to help unless you are hardwired to the device with your WiFi on the laptop preferably turned off.
Or did it get it wrong?
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
04-07-2016, 08:19 PM
Brandenburg
, Kentucky
Any device, either hard wired or WiFi, with a VPN software connection is secure. So if your laptop has VPN software connected and your passing data via MiFi to a public WiFi, your data packets are secure.
04-07-2016, 09:46 PM
2004 30' Classic
London
, Ontario
+1. I use PIA as well, more for anonymity than security, but it does a good job of both. I've used it for 2 or 3 years now on a daily basis with my home server without issue.
