Old 09-06-2016, 09:32 AM   #1
DarrellT's Avatar
Longview , Texas
Verizon Jetpack external antenna vs. Weboost?
For those using the Jetpack, shouldn't it be adequate to just add an external antenna to the Jetpack rather than the expense of the Weboost?
D
DarrellT is offline   Reply With Quote
Old 09-06-2016, 09:43 AM   #2
FCStreamer's Avatar
2014 30' Flying Cloud
Yes.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 09-06-2016, 09:43 AM   #3
1976 31' Sovereign
Oswego , Illinois
I use Verizon jet pack with out any signal booster, or external antenna every where as only internet source available to me, even inside AS, have always been able to get signal & no drop outs
Old 09-06-2016, 12:34 PM   #4
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Thumbs up
No. Not if you want to camp out in the boonies. The WeBoost is essential. If you are camping where your phone has signal, then an antenna will be fine.
Is it worth the expense. Yes, absolutely.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 09-06-2016, 12:43 PM   #5
2015 30' Classic
Pleasanton , California
Bold, have you tried using an external antenna with your JetPack? What's your personal experience in using a JetPack with an external antenna and the WeBoost? Inquiring minds want to know!
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 09-06-2016, 01:18 PM   #6
1976 31' Sovereign
Oswego , Illinois
In my previous post I did not clarify that I don't get to far in boonies. Bill
Old 09-06-2016, 02:02 PM   #7
1979 23' Safari
Wayland , New York
If you stick the jetpack near or on the inside of a window you should get a signal just fine. You may have to move it from window to window depending on where you're camped and where the best cell tower is.
Old 09-06-2016, 02:19 PM   #8
Nomadic , USA
Thumbs up
Quite extensively. Before we went full-time I used ours with an external antenna. I had the older Jetpack at the time too.
The antenna works well if you are in an area with coverage, 1 bar with the antenna can become 4 bars.
The WeBoost makes a significant improvement when you are in areas with almost no or little coverage. 3G on my phone, can be 4G boosted, or 1X can also turn into LTE.
We are at Diamond Lake Campground, in Oregon right now. This isn't the boonies per say. This is a popular area, but it's 1X on our phones. In the Airstream with the WeBoost we have 4G LTE and 5.7mbps down on my last test.
I no longer use an external antenna with the Jetpack. I'm almost always boosted now.
I posted two videos about my setup recently, you can watch below:
Antenna Setup:
https://www.instagram.com/p/BJrIH6BD...=boldadventure
Hardware Setup:
https://www.instagram.com/p/BJrKJOUD...=boldadventure
It can make a difference in areas that aren't quite in the boonies too.
Last thought, I forgot. If it's mission critical I would consider adding it to the toolkit. It's worth the cost.
If you want internet for email, social media, netflix and general browsing, save yourself the cash. The antenna is probably a better bet since not having the internet won't be as big a hassle.
As a full timer who works, no internet is a big hassle.
Old 09-06-2016, 02:19 PM   #9
DarrellT's Avatar
Longview , Texas
Thanks to all! We'll wait on the Weboost.
D
Old 09-07-2016, 11:28 AM   #10
Lexington , Kentucky
We have both roof cellular antenna and amp inside. The antenna by itself gives a better signal and the amp improves the signal even more; both together makes a BIG difference in the signal strength.
wlanford is online now   Reply With Quote
Old 09-07-2016, 12:46 PM   #11
1976 31' Sovereign
Oswego , Illinois
Smile
Antenna Setup:
Hardware Setup:
We have to have internet as wife works in legal field of spec. ed. and on 2 adv. boards for spec. ed. to atty. gen Illinois. plus doing advocate work and on other spec. ed. boards, to many to list that involled in, and teaching seminars to teachers. We won't pur. fancy wireless phs. basic ph. and plans, no pics no texting only talk or messages left. Like I stated before have not needed any help for verizon jet pack to get signal.
Old 09-07-2016, 04:02 PM   #12
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Got a Wilson Seek 4G for less than half the money of a WeBoost. Been using it for 4 years. Raises a 0 or 1 bar Jetpack signal to 4 bars.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 09-07-2016, 05:12 PM   #13
Nomadic , USA
Thumbs up
Wilson is now WeBoost (they rebranded). And they still make the Sleek. It's an excellent choice for part time use. However, they've also revised pricing.
We had one originally, but it failed after non-stop use after 6 months on the road. Worse, the heat it produced caused one of the batteries in our first Jetpak to expand.
Old 09-07-2016, 06:08 PM   #14
1958 22' Flying Cloud
portola valley , California
Exactly what model Weboost did you use and think is best. We are dealing with this same issue and will be boondocking often. thank you!!
Driftin Di is offline   Reply With Quote
Weboost install chaeha Electronics & Connectivity 211 01-24-2018 03:13 PM
Weboost 4G-X vs WiFi Ranger dhroberts Computers, Internet & Satellite 29 09-01-2017 03:28 PM
How I installed my weBoost Drive 4G-X OTR on International 27FB tot2learn Electronics & Connectivity 18 07-10-2017 02:53 PM
Pepwave MAX BR1 / MobileMark / weBoost install Ohiobrits Computers, Internet & Satellite 17 09-27-2016 07:26 AM
Update: WeBoost Drive 4G-X BoldAdventure Computers, Internet & Satellite 8 10-22-2015 02:30 PM
