09-14-2015, 12:50 PM
2007 28' Safari SE
Springdale
, Arkansas
USB Wall Charger, Has anyone successfully installed one?
I have this at home and love it. Was wondering if anyone else has tried to retrofit into an airstream outlet?
09-14-2015, 01:03 PM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
I have something very similar/could the the same, that was supplied and installed by Airstream NE. It wasn't a retrofit, it was an install in a new location. They are pretty deep compared to normal outlets.
09-14-2015, 01:05 PM
1987 25' Sovereign
Oregon
, Ohio
Have never seen an outlet like that. Where can they be bought. It might be something Airstream could start using at the factory.
09-14-2015, 01:09 PM
2008 25' Classic
Full Time
Here is my install
http://www.airforums.com/forums/f366...ts-127043.html
These receptacles are too deep to put into the exterior walls so I just put two in, one on the fridge wall by the TV and the other in the nightstand next to the queen bed.
If you charge iPads, make sure the USB ports are rated to charge larger devices.
If I were to do it again I might look into this easier solution
http://www.thingcharger.com/
Kelvin
09-14-2015, 01:26 PM
2008 20' Safari SE
Bangor
, Maine
I've tried installing one of those outlets but as has been discussed they are too deep to go into one of the exterior walls. Plus most outlets are lower to the ground making it not very ideal for connecting and disconnecting the USB cords.
What I use is this: Maker Aluminum 3 USB Car Charger With Smart Sharing IC I have a couple of these in the airstream on the 12v outlets. These outlets are generally more accessible and have power if you have shore power or not, making it deal to charge your devices no matter where you are.
-J
09-14-2015, 01:30 PM
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach
, British Columbia
Last time I was in Costco ( BC)they sold them by the pair for about $27.
George
09-14-2015, 01:38 PM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
I guess I am lucky as everywhere I had mine installed was into cabinetry so being deeper wasn't an issue.
09-14-2015, 01:39 PM
2007 28' Safari SE
Springdale
, Arkansas
I agree, Thingcharger looks easier to install and cleaner looking. Thank you.
09-15-2015, 12:57 PM
2013 27' FB International
San Luis Obispo
DC USB Charger
I mounted 2 panel mount USB charging ports in the side of each nightstand by the bed (See attached picture). The nice thing about these is they are hooked directly into DC power so when not hooked up there is no need to run the inverter to charge.
The only downside is all of these have LED lights inside of them. BUT, when there is a cable plugged in or small piece of electrical tape over the port the light goes away
Here's the one I bought but you can find these all over the place: Amazon.com: Poly-Planar USB-PM Panel Mount USB Charge Port - 12V: Sports & Outdoors
09-15-2015, 01:28 PM
San Luis Obispo
Apparently I don't know how to add a photo  Hopefully this works...
09-15-2015, 01:36 PM
1987 Avion 34W owner
Good Ol'
, USA
I really like the thingCharger! What a simple solution. Thank you.
thingCharger
Kelvin
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
09-15-2015, 02:17 PM
2013 25' Flying Cloud
Wheaton
In my 2013 FC, I installed a cigarette lighter outlet in each corner, next to the LED spotlight. Tapped into the LED light for 12V power. Used a common hole saw to drill the cabinet for the outlet and removed the speaker to gain access to the LED spotlight wiring.
Gives me 12V and with an inexpensive USB car charger adapter, I can have 5V as well. And not dependent on being connected to shore power. The stock wiring leading up to the LED lights is very substantial, so no worry about overheating the circuit wire.
Greg
09-15-2015, 03:49 PM
1982 31' Excella
Hemingford
, Nebraska
Our '81 Excella has four or five cigarette lighters, so we just used the USB adapters for cars. Did find some cig lighters didn't work as well with certain adapter as others, but many adapters have two or three outlets available coming off the adapter, including regular outlets for lamps, etc.
09-15-2015, 04:14 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Reports of the failure of the built in dual USB port fittings in Airstreams may imply a 1.0 amp rating on each port. Thus a newer iPad that draws 2.1 amp could toast the fitting.
09-15-2015, 04:20 PM
2014 31' Classic
Apache Junction
The outlet in post #1 is also available at Home Depot
09-15-2015, 05:12 PM
1987 25' Sovereign
Oregon
, Ohio
Here is my install
thingCharger
Kelvin
The thing charger looks like the best way to go. Thanks.
09-15-2015, 08:50 PM
1964 26' Overlander
Milton
, ON
09-15-2015, 09:50 PM
1998 31' Excella 1000
Clear Lake
I have found there are so many small devices that plug into the cigarette lighter outlet that are handy and easy to use: Why go to all the trouble of installing an outlet?
09-16-2015, 11:47 AM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
I just installed one yesterday. Planning on installing two more. The key is install them onto things. In this case, the end of the bed or the end of the couch. Things other than the aluminum walls.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
09-17-2015, 09:59 AM
2014 31' Classic
Apache Junction
Make sure you read the fine print on the power being generated at the USB ports. Some device will generate only 5 Vdc @ 1.0 amp (5 watts) which is okay for a phone but not enough for any recent iPad that requires 5 Vdc @ 2.1 amp (10.5 watts). Those fixtures with two or more USB sockets may be limited to one high power device or two low power devices. I have seen a few products rated 5 VDC @ 3 amp which could fail with a device at 5 VDC @ 1.0 amp and a device requiring 5 VDC @ 2.1 amp.
