Old 03-30-2012, 03:06 PM   #1
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
USB Modem using Verizon or AT&T networks
I've pretty much settled on getting a Millenicom USB modem, which uses the Sprint network, for their PAYG $70 50GB monthly plan. (I spoke to one of their agents this morning, and they said their unlimited plan starts choking at 50GB.)
I'd like to do something similar with the Verizon network and one for the AT&T network. (My aim is to have a PAYG modem on each of the major networks.) Does anyone have any recc's for a company that does the sort of thing Millenicom does only on the Verizon or AT&T networks?
I'm looking for lots of GB, mainly, as connectivity has to be there for work and I will sometimes be moving across network coverages. (I use a Cradlepoint CTR35 to broadcast to my devices using the modems, if that makes any difference.)
"If you can't be a good example, then you'll just have to be a horrible warning." - Catherine Aird
Blog: 300 Miles or 3:00
zlee is offline   Reply With Quote
Old 03-30-2012, 03:32 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I seem to recall friends who had millenicom on the Verizon network. What they sell you may be based on your home location. Wouldn't hurt to ask their rep.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 03-30-2012, 03:56 PM   #3
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
A good thought, thanks, Rick, I'll check with them on that. Maybe their hotspot is Verizon or something?
Old 03-31-2012, 04:15 PM   #4
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Talked to an online rep this morning: the USB modem is on Sprint. The Hotspot is on Verizon. There's also an "advanced" plan with a USB modem on Verizon that's not currently on their website, which is 20GB but I think it's not 4G/3G, just 3G.
Old 03-31-2012, 04:28 PM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
That is what my friend had on verizon. 20 gig 3g.
4 G would be nice but I suspect it will be a few years before the coverage expands out of the major metropolitan areas. We are still encountering a lot of 1x coverage where 3 g hasn't made it into the more remote areas we frequent.
It does seem coverage improves each passing year
13 Ram 2500 TD
Old 04-04-2012, 10:56 PM   #6
JFScheck's Avatar
Rockville , Maryland
Images: 33
I would log with a Hot Spot - just picked up one via Verizon - 5gb for 50 a month with 1 gb per 10.00 - my iPad3 is AT&T so I feel like I'm well covered!
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-04-2012, 11:13 PM   #7
2005 22' International CCD
Aliso Viejo , California
I have the 4g mifi from Verizon. When I first got it, i preferred the older 3g hotspot as it didn't drop as frequently and I rarely got 4g. However, it has been getting better as they have built out the network and send a couple of firmware updates. We usually have a laptop or two on it as well as an iPad.
Davern1 is offline   Reply With Quote
Old 04-04-2012, 11:26 PM   #8
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
I need GBs, as many as I can without paying an arm and leg, so the "unlimited" plans that go up higher than 15 or 20 are particularly good. I don't and won't be using them all the time, but when I need them, I need them!
Virgin has an "unlimited" for $50 on the Sprint network that I think chokes at 10GB, but I think Millennium tops them at a 50GB choke for $70 on the Sprint network. Nevertheless, i will end up with both, and will try to find the best deal on Verizon and AT&T I can. Mainly what I need is to be able to find the best signal in the area.
Old 04-04-2012, 11:41 PM   #9
Southwestern , Ohio
What kind of things do you want to do that will require all this data? Reason I ask is that a lot of high-data applications also need a high data rate, which is seldom realized with a wireless connection. Yes, Verizon 4G (or so I hear), if you happen to be in a place where it's available.
Nuvite-F is offline   Reply With Quote
Old 04-05-2012, 12:03 AM   #10
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Photos, PDFs, documents, website work, sales info and reports, etc. Even more so when J is Stateside. I have a fair amount that needs to flow back and forth too, but his needs have more to do with dependability. (So we'll probably stay in reach of 4G when he's here.)
Old 04-05-2012, 12:04 AM   #11
zlee's Avatar
2008 19' Safari SE
Erie , Colorado
Oh, and sales calls. Lots and lots of client calls.
Using Kool Seal on the Inside of the Outside? aluminitus Roof 44 06-18-2013 09:00 AM
Need help, replace rivets or try to seal? timzog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 04-25-2012 12:40 PM
Has anyone here actually cracked or broke a front wrap around window?? VonLuck All Argosy Trailers 30 04-01-2012 10:31 AM
Airstream Exterior Badging & Emblems DGJackson Exterior Restoration Forum 4 03-31-2012 05:57 AM
Restore or replace leaf spring axle? silverwoman Axles 7 03-29-2012 09:33 PM
