Old 01-29-2012, 03:00 PM   #1
1994 34' Limited
Troy , Ohio
Unique Problem with DishN in 94' Excella
I have a single output coax recepticle with amplifier and 12V socket under the credenza between the dinette and the LR. There are three internal cable connections coming in/out of the recepticle inside the wall (antennae in, cable in, and output to a splitter for the bedroom and front TV). I tried to connect my Dish through the cable connection then staight off the external port on the recepticle but it didn't work. I pulled the recepticle out and connected directly to the cable wire and it worked. Is there some way to get through the amplifier connection to make this work? Can I split the cable input before the amplified recepticle and go into the amp with one and a new single plate recepticle with the other side? What kind of splitter should I use? This is a real pickle. Leaving for FL soon and would appreciate your inputs. DH>
Emh142 is offline   Reply With Quote
Old 01-31-2012, 07:54 PM   #2
1994 34' Limited
Troy , Ohio
Didn't hear from anyone so I pressed on. Had to diplex the cable wire and run a separate wire to the SAT box. Then the TV2 output from the SAT box had to go directly to a splitter and combine with the bedroom run. Had to keep the antennae AMP out of the SAT configuration. Had to make three 1foot RG6 cables, buy one duplexer, and a double wall connector. Took a long time to figure this out. Getting all the extra wires back in the wall was hard but was doable.
Old 02-01-2012, 09:54 AM   #3
1994 25' Excella
Redwood City , California
Did you do all this without pulling the interior skins? How did you manage it?
airfun is offline   Reply With Quote
Excella problem years? MJBear 1994 - 1996 Excella 20 02-10-2012 02:00 PM
Potential Problem? Pictures included palmtreegirl 1990 - 1993 Excella 50 09-02-2011 08:50 AM
What makes an Excella an Excella? MaraLindstro 1990 - 1993 Excella 0 09-01-2011 03:15 PM
1988 Excella AC Drain Problem 68Glbtrotter Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-04-2011 06:01 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
