Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Computers, Internet & Satellite
Old 01-04-2008, 05:59 PM   #21
Zugbug's Avatar
Volcano , California
I just got DishTv and plan on taking the third receiver with me when traveling in the AS. The tech that installed the system said just get a dish and stand and I would be good to go. Question is how hard is it to hit the sat's I have never tried this before?
Zugbug
2006 23' Safari
2006 F-150
Zugbug is offline   Reply With Quote
Old 01-05-2008, 09:55 AM   #22
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
I was at a boat show in NYC this past weekend. I spoke to the KVH/TracVision rep. He refered me to their web site www.traccision.com for info on their RV package. I went there and found a unit that is pretty interesting, but pricey, 1300.00. It is a dome that is designed to attach to the top of the RV.
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 01-05-2008, 10:24 AM   #23
ScottW's Avatar
Hernando , Mississippi
Zugbug:
it is actually quite easy to set up the dish. Your receiver has a booklet containing the azimuth and elevations for the satellites. easy to align. After a few moves...you can pretty well get it first time. I've also looked at the 'align-a-site. Pricey, but looks like it may work well.
http://www.alignasite.com/
Worth a look, but as I said, it gets easier the more times you set up.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 01-05-2008, 10:45 AM   #24
Zugbug's Avatar
I don't see anything in the manual that came with the receiver that indicates the Sat settings. Having had the system set up by an installer from Dish TV I don't think I got the paper work that goes with the dish itself.
Zugbug
2006 23' Safari
2006 F-150
Old 01-05-2008, 11:12 AM   #25
ScottW's Avatar
You can actually do without the manual of settings. just point the dish in the general direction (sw) and turn on the receiver and tele. the setup page will guide you and give az/el after you input the local zip code.
I use the manual to preset the antenna before I leave the house just to minimize my set up time at the campground.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Old 01-05-2008, 11:12 AM   #26
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Dish in our Caravel
We have been using Dish in our Caravel for a couple of years. We use the "Dish Pro" dish, and a stand that I picked up in Quartzsite. Accu-Dish Stands The stand can be filled with water for weight. It also has provision for nailing to the ground. The top of the pole has a level and a "ball socket" adjustment to make it vertical. Entering the zip code will give you the settings for where you are located. Dish uses satelites 110 and 119. With the proper settings, they both come in just fine. Setting up is a 10 minute job. Having the portable stand allows you to avoid trees or other things in the line of sight to the satelites. A dish mounted on your RV means you have to change location if something is in your way.
Dish network can no longer provide "Local Networks" (the ones you will get at home) when you are more than a couple of hundred miles from home. You must sign up with All American Direct to get networks on the road. All American Direct uses satelite 119. The other stations to which you subscribe are available anywhere you travel in the US, and I think Canada too.
As far as the alignasight, it's handy, but not at all necessary. It merely shows you if there is anything obstructing the dish's view of the satelite. The satelite is, I would guess, about 30 degrees above where the dish is pointing. NOT where the center of the dish is pointing.
High definition with "Dish" comes from satelite 129 and requires a Hi Def box. Whole different ball game.
Old 01-07-2008, 10:05 AM   #27
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Tracvision is the one I was talking about. I'm waiting for the price to come down and then I want to get one for my truck so the kids will have live TV while we're on the road. We limit their TV watching at home, but face it, in the back seat there isn't much to do to keep from being board.
Family of Disney Fanatics
WBCCI# 4821
https://streaminacrossamerica.com/
Old 04-27-2008, 09:24 PM   #28
lsinclair's Avatar
2008 30' Classic
Pagosa Springs , Colorado
Motosat HD Universal or Motosat MD1000.2 ?
Seeking feedback on Motosat HD Universal and/or Motosat MD1000.2 satellite systems. Secondly, diferences between the Nomad 2 and the Dish 622 or 722 receiver. We had a Kingdome on our last AS. Taking the southern view into consideration, we didn't experience the inability to lock on satelittes. However, with 1 LNB, channel surfing was an inconvenience. As a result, we are looking at the above units for their convenience and automatic features.
If anyone has the Motosat system, I appreciate hearing your experiences and installation process. Thanks,
Larry & Sandy
08 Classic 30
05 GMC K2500 Duramax
Four Courners Unit
WBCCI # 2460 AIR # 17259
lsinclair is offline   Reply With Quote
Satellite Radio??? Rivetedude Electrical - Systems, Generators, Batteries & Solar 55 08-13-2008 02:26 PM
New satellite! 65 overlander Electrical - Systems, Generators, Batteries & Solar 7 02-14-2006 07:01 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
Next Motorhome Rally(s) ViewRVs Forum Rallies & Meet Ups 33 05-29-2002 11:36 AM
