Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Computers, Internet & Satellite
Old 03-30-2009, 05:33 PM   #1
Lumatic's Avatar
Profile:  1971 25' Tradewind
1967 24' Tradewind
Estancia , New Mexico
Satellite TV/Good bye sour grapes
After years of poo pooing those softies that can't leave their city creature comforts behind them I have decided to join them. Oh the shame of it. OK now that I'm all done with remorse.........
So what do need to set up Satellite TV in my stream. I plan on using one of my home recievers and get a tripod stand. I have an extra 2 eye dish. Would a single eye be less hassle. What other gizmos do I need to make it work?
Pay no attention to the man behind the curtain- WOZ
Old 03-30-2009, 05:41 PM   #2
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 12
You will need to install a connection for the Sat. on the outside of your trailer and a connection inside. I install mine just below the table that my tv sits on and ran the wire up through the cabinet and mounted the connection in the table top.
http://defendwally.org/
WBCCI 12156
AIR 3144 WDCU
TAC NJ6
2004 Excursion 4x4
1991 34 ft. Excella +150,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
My Kayak mysite.verizon.net/vze54tx9/kayak/
Old 03-30-2009, 05:52 PM   #3
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Airstream Registry
I'm assuming you have a dish which hits two satellites at once. Biggest issue for you will be aiming since you have vertical, horizontal, and a skew setting to deal with.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 03-30-2009, 06:09 PM   #4
Lumatic's Avatar
1967 24' Tradewind
Jack
Thanks. I've got the wiring part down. What I need to know about is the hardware.
Would I be better off with just a single eye? I can get a used one of those free.
What do I need to aim the sucker?
Old 03-30-2009, 06:14 PM   #5
Foiled Again's Avatar
Virginia Beach , Virginia
Originally Posted by Lumatic View Post
After years of poo pooing those softies....
for one horrible moment I thought this was a thread about laxatives
VA-6 yah!
HONK if you love Jesus,
TEXT if you want to meet him personally.
Foiled Again is online now   Reply With Quote
Old 03-30-2009, 07:41 PM   #6
Profile:  1986 31' Sovereign
Miami , Florida
Airstream Registry
If you have Direct TV, use your remote to go to the satellite aiming page -- type in the zip code of your camping location and you'll get azimuth and elevation. You should have an elevation gradient on the side of your antenna mount -- set this first. Then using your handy boy scout compass get the azimuth more or less dialed in.
On my satellite receiver there is a tone that rises in pitch as the signal strength increases so I just crank up the volume so I can hear it outside and then sweep the antenna in the general direction the compass indicated until I peak out.
Then twist off cap, sit, watch game.
mike
Old 03-30-2009, 08:44 PM   #7
jcanavera's Avatar
Fenton , Missouri
Images: 143
Airstream Registry
Dish Satellite also has an aiming page based on the zip code. As noted in the post above you will get the same information as Direct. Your receiver also has a tone which will change with strength as you aim for the best signal.
Aiming to a single satellite is easy, although the Dish screen if you have a two satellite dish, will also give you the skew setting also. Obviously if you have a single satellite dish, you will only get the programming that you have subscribed to that the specific satellite that you aim at supports.
Here is a link to a list of the different Dish network channels and the satellite locations that these channels reside on. EKB: Dish Network Channel Chart (Unofficial)
Typically you will find most of the standard channels on the 119 and 110 degree satellites.
Jack Canavera
STL Mo.
AIR #56
Old 03-30-2009, 08:54 PM   #8
overlander63's Avatar
Profile:  1974 31' Sovereign
Gone , North Carolina
A compass and a level. In your neighborhood, the dish should be pointing pretty close to South, and nearly vertical, and a skew about 75 degrees or so. There is an area of your receiver that says "point/aim dish". Enter the zip code you are in, and it will give you a bit closer angles. Point at 119 West first, and get the satellite to "Lock". It will say "locked" on the screen, then change the satellite to 110, and do the same.
After you've done this a few times, It'll only take a few minutes to dial it in.
Old 03-30-2009, 08:54 PM   #9
Tramp Streamer
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Images: 65
Airstream Registry
Wink
You're killin me here!
You're a sic individual and I love it
Click here Airstream Posters & Tee's
by Michael Joseph Depraida
Check out the video
ArtStream is offline   Reply With Quote
Old 04-01-2009, 05:36 AM   #10
Denis4x4's Avatar
Profile:  2006 Safari LS
Durango , Colorado
Both DishNetwork and Direct TV use a "spot beam" from the satellite so you will be unable to view network stations outside your viewing area. Check with your provider as there are some network packages available.
Denis4x4 is offline   Reply With Quote
Old 04-01-2009, 07:03 AM   #11
Lumatic's Avatar
1967 24' Tradewind
I have Dish Network and set local channels at home. Is this what you mean by "network stations". It is my understanding that even though I subscribe to the extra local channels at home I won't be able to pick up other local channels on the road. Is this what you mean by "network package"?
I also have a Winegard batwing to pick up stations of the air, and am wired for cable where it is available.
Old 04-01-2009, 08:17 AM   #12
HowieE's Avatar
Images: 12
Your "network Channels" will be available within about a 100 mile radius of your home. This assumes you live in the center of that "spot beam area", center of the city that the beam is directed to.
In order to receive LOCAL network channels broadcast in the area your are camping, say 400 miles from home, you will need a digital converter box after June 12th. With the converter box and your Winegard you will get what ever channels are available in the area you are camping.
You can hook up both the satellite and the winegard to your tv using a splitter installed backwards. However you may see interference on the lower channels, 2,3,&4. You are better off to install and A/B switch to isolate the 2 sources. You will need to install a cable from outside your trailer to the tv are for the satellite because the cable installed by Airstream goes to the tv amplifier and you will want to have access to both without removing wire when switching between sources.
The attached pictures shows my setup to receave local annolog network channels, campground cable, staellite, and local didigal channels.
WBCCI 12156
AIR 3144 WDCU
TAC NJ6
2004 Excursion 4x4
Old 04-01-2009, 08:18 AM   #13
HowieE's Avatar
Images: 12
The wiring picture did not upload.
WBCCI 12156
AIR 3144 WDCU
TAC NJ6
2004 Excursion 4x4
Old 04-01-2009, 09:02 AM   #14
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
The attached pictures shows my setup to receive local analog network channels, campground cable, satellite, and local digital channels.
The Dish Receivers have an excellent over the air HDTV tuner, I have one. Attach the Wineguard to the dish unit and you are set. No splitter or switch needed. In fact, the receiver on my Dish DuoDVR™ ViP® 722 will pickup a viewable signal when the internal tuner on my Mitsubishi HDTV will not.
Vaughan
A sixth sense (I lack the other five) tells me that I am in serious difficulties. Oscar Levant
with a screach and burning rubber, it's bye bye belt !!! kepko Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-06-2008 02:34 PM
Bye Bye Dinette? Foiled Again Off Topic Forum 13 02-04-2006 07:47 PM
Good-Bye To My Best Friend Chaplain Kent The Pet Forum 39 12-28-2005 05:14 PM
Good bye and thanks Ronnie..... Silvertwinkie Off Topic Forum 8 06-06-2004 05:46 PM
Bye bye Miss American Pie Rog0525 Our Community 4 04-13-2003 10:18 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Mustang Forums - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - RV Forum - Truck Conversion - U2 Music Forum - Campground Reviews - Forest River - Sunline Trailers - Fiat Forum - Retirement Calculator
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© copyright 2002-2010 Social Knowledge, LLC All Rights Reserved.
