Old 07-09-2015, 04:17 PM   #15
2016 30' International
Scottsdale , Arizona
Originally Posted by ghaynes755 View Post
DHart I'm probably stating the obvious but the amount of space the Travl'r takes up on an AS roof may limit the amount of solar you can install. See the postings from BAB on his 2015 Classic at 30ft. He moved some stuff around and still has plenty of room for solar. Smaller trailers start to be challenging.
ghaynes... yes, I can imagine that on the smaller Airstreams, rooftop real estate would be quite limited.
I think on the 30' Serenity that will be coming in next week, we can should be able to make it all work out up there. We're not planning on a lot of solar.
DHart is offline   Reply With Quote
Old 07-10-2015, 01:16 PM   #16
2014 27' FB International
Nebo , North Carolina
To clarify I have the g2 dome covered dish and it does not have high def. you speak of a different dish entirely.
JimGaskill is offline   Reply With Quote
Old 07-10-2015, 01:59 PM   #17
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The factory solar package is an overpriced trickle charger (no offense, Doug Kottum ) Even Airstream admitted to some of us at this year's Alumapalooza that they "need to get serious" about solar.
We ripped our factory solar system out after a year and added 540 watts of solar panels, a Magnum hybrid inverter and the AM solar charger/controller; and will be getting a 400 AH Lithium Phosphate battery bank in about two months when we get to Oregon. We couldn't be more pleased. Having said this, I fully acknowledge that our setup is way more expensive and capable than what most sane people would do.
Contact Lew Farber (screen name Lewster) on this Forum. He is the most knowledgeable person on this forum about solar.
Bob Martel
WBCCI# 5766
Old 07-10-2015, 10:45 PM   #18
Jim, yes, the particular antenna (dish) that you selected is what prevents you from receiving High Definition with DirecTV.
I was responding to your statement "Note with directtv you can only have standard def." which might lead an uninformed person to think that DirecTV doesn't offer high definition on mobile set-ups, which isn't true. It just depends on what antenna (dish) one buys.
It's all clear now, though.
Old 07-10-2015, 11:26 PM   #19
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Bob, that's kind of what we have our eye on as well. Too expensive and probably much more than we would ever need, but I like the idea.
Meanwhile four years in with our factory system and it serves us well. Don't regret the original purchase at all, a battery storage capacity (need larger AGMs) is our weakness at this time. The original panels have them recharged by noon as long as we have sun (solar requirement).
We would regret not having any solar system.
Doug and Cheryl
Old 07-10-2015, 11:52 PM   #20
lewster's Avatar
Naples, FL , Hood River, OR
Doug,
Actually, with the proper solar panels, solar charge controller and system design, you don't even need full sun for a solar charging system to charge the batteries.
Yes, you read that right! Many of the systems that I install show significant charging amperage to the batteries in minimal daylight conditions. If there is sufficient sunlight (enough to cast a shadow on the ground) many of our systems will work. I have clients that have sent me screen shots of their systems producing charge amperage even in the rain!!!!
Old 07-11-2015, 04:39 AM   #21
Chelsea , Michigan
Images: 12
Doug, if you have a front bedroom, adding more batteries is very easy, just put them under the bed. Our $10,000+ project began with the idea of simply adding two new batteries under the bed.
Bob Martel
WBCCI# 5766
Old 07-11-2015, 07:29 AM   #22
dkottum's Avatar
Overcast sky is the limitation we see of the factory solar system. If sunny, the two AGM's are recharged well before noon. Some overcast sky, maybe 3 pm. Lots of overcast, full recharge may not happen. Time for the generator, or seeing we don't carry one any more, conserve the battery power you have.
So that's why I would first choose to increase battery capacity before solar if pinching pennies, to carry us through those intermittent overcast days. Then when we win the lottery (have never bought a ticket) we could get the total system we really want.
Have to admit, I really dislike generators. (Maybe I should buy a ticket.)
Doug and Cheryl
Old 07-11-2015, 12:32 PM   #23
Chelsea , Michigan
Images: 12
It's my understanding that buying a lottery ticket does not materially increase your odds of winning.
Bob Martel
WBCCI# 5766
Old 07-11-2015, 01:02 PM   #24
When installing panels on the roof, I assume one must select one side or the other. So, do you need to park with the chosen side facing south, so you can tilt the panels to the south? Is curbside or roadside generally a preferred side for installation?
I ask because I'm beginning planning for installing two large panels (for perhaps 500w?) and the Winegard Trav'ler dish antenna.
Coach is a 2016 30' Serenity.
Old 07-11-2015, 01:58 PM   #25
dkottum's Avatar
The sun moves east to west, highest in summer (northern hemisphere). I wouldn't want to be limited by solar panel orientation when choosing parking. Perhaps just follow the top of the roof? I would think moveable tilt would have you chasing the sun all day. The idea of solar to me is just let it quietly do what it can, and manage the juice it gives you each day.
Doug and Cheryl
Old 07-11-2015, 03:41 PM   #26
lewster's Avatar
You'll find that using more panels of a narrow profile ( our 100 watt panels measure 21 X 47) will allow for placement on both sides of your roof. We also use proprietary mounting feet that allow the panels to be tilted 45 degrees for better solar radiance in low solar azimuth situations.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-11-2015, 04:26 PM   #27
That makes good sense.
Hadn't thought of that. Sounds good.
Lew... can a 2016 30' Serenity with two AC units accommodate a Winegard Trav'ler and four of your 100w panels on the roof?
Old 07-11-2015, 06:44 PM   #28
lewster's Avatar
I haven't seen the new 30 yet, but I put 4 of the now discontinued 135 watt panels on a '15 30 Bunk (these panels are 57" long) and I believe that a sat. receiver would still have space available in the center of the roof between the A/C units.
Lew Farber
541-490-6357
Factory Installed Solar Charging System SilverGate Generators & Solar Power 423 04-08-2018 08:57 PM
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
Satellite installation -A factory installed option? lsinclair Computers, Internet & Satellite 9 11-04-2007 07:23 PM
