With DISH you can get local network channels while traveling. You need to call them and give them the address where you 'staying'. Also in the setup menu change the zip code to your new locale. Would be nice to do this through the internet but that isn't an option. The phone call is a PITA. I don't have the Tailgater and use the Winegard X1 system.
And in most trailers you will be able to switch between the sat input and the installed over the air antenna.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
