02-10-2008, 05:29 PM
2003 22' International CCD
Mandeville
, Louisiana
Portable satellite dishes
Am new to portable satellites -- have box hooked up, and wiring with stationary dish previously used. Am concerned about type of portable dish to buy and being electronically challenged am also concerned regarding the on site hookup with the tv zip codes set ups -- how does all that work? Is is tough for the neophyte?
02-10-2008, 05:35 PM
Hernando
, Mississippi
m.vidos,
commo se va, mon ami!
No the hookup is easy. I bought a dish network antenna and tri-pod from the local camper supply place. The paper work from your particular carrier has charts, by zip code that tell you the azimuth ( left/right in degrees) and the elevation to set on the antenna - dish network also has a 'skew' to set (the tilt, left or right of the antenna dish). I carry a 200' coax cable so I can find a line of site that avoids trees. It takes once or twice to get the hang of it, but then it is pretty simple, even for a cajun.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
02-10-2008, 05:43 PM
1986 31' Sovereign
Miami
Not a simple question. The actual dish set up at a campsite varies from fairly easy to not so easy depending on your company. I have a simple Directv package so when I aim my dish I only have to worry about azimuth (compass direction) and elevation. From walking around many a campground it seems the DISH Network folks also have to dial in a degree of rotation so I am guessing it is a mite more troublesome.
There are several gadgets to help. Winegard (among others) sells a little black box that is wired inline between the receiver and the antenna that beeps more urgently as you close in on the satellite. There is also a rather pricey and seemingly complex device that purported makes aiming very easy.
As for antennas and mounts -- a quick stop by any satellite retailer will probably net you an antenna, maybe even cheaply if all you need is a single horn basic unit. Lots of folks make their own mounts out of PVC ppe. I bought the basic Winegard tripod (I already had an antenna).
Whatever you buy -- set it up at home so you can use your household antennas orientation to get you in the ballpark.
After a while, it's all pretty easy....
02-10-2008, 05:57 PM
Cyclist
2007 28' International CCD
Windermere
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
02-10-2008, 06:20 PM
More than one rivet loose
Los Alamos
, New Mexico
Standard def is easy. Like anything, It takes some practice. High def is a little harder. For standard it is just one satellite you are try to capture. for high def it can be up to five.
A tripod and small dish will work for std def. make sure you can stake it or teather it in case the winds come up. I uilt my own dish base for my high def dish.
Michelle TAC MT-0
Sarah, Snowball
02-10-2008, 06:42 PM
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley
i have a dumb question, because i also don't know a thing about sat's.
can you get the internet w/ an up and down link, as well as tv?
thanks,
k.
02-10-2008, 06:46 PM
Mandeville
, Louisiana
zip
What is that stuff about plugging in the zip code depending upon where you perch your vehicle? So aside from correctly positioning the dish outside, what is necessary to do inside?
mv
02-10-2008, 06:49 PM
Cyclist
Windermere
Yes you can get satellite internet. Satellite Internet - Hughesnet - Hughes net - Satellite-Internet.cc.
Requires a separate dish from TV.
2007 28' Int CCD.
Two big screens
Centramatics.
02-10-2008, 07:51 PM
2007 27' Safari FB SE
Full Timers just passing through
, Arizona for a couple of weeks and then on to Utah!
Easy as 123..456
I just went through the setup for the first time and found it to be pretty simple, if a little more time consuming than I thought would be necessary. We are getting ready for a 6 month trip and I decided to try it out at home before we begin the trip.
Basically, get a dish and a receiver. Follow the setup directions (especially the part that says be sure that your dish is on a vertical mast). If the dish is not plumb, the setup is pretty worthless. A level and a compass is all that is necessary, although a meter (available at radio Shack) is helpful.
Go for it. I am watching the Discovery Channel tonight and am already spoiled with my dish setup in the AS.
02-10-2008, 08:28 PM
Los Alamos
, New Mexico
mv
The zip code gives the reciever the information needed to tell you where to point the dish. Running satellite setup should take it through al the necessary steps. It is not that hard...
Michelle TAC MT-0
Sarah, Snowball
02-10-2008, 08:31 PM
Los Alamos
, New Mexico
I found the radio shack meters pretty useless. I own a acutracc 22 that got replaced with a accutrac III pro. If the mast is vertical pointing the dish is quick.
Michelle TAC MT-0
Sarah, Snowball
02-10-2008, 09:55 PM
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
Has anyone used the automatic rooftop units? I am referring to the ones that look like a small bubble on the roof. Seems like such a clean system, no wires or tripods needed.
02-11-2008, 03:59 AM
Cyclist
Windermere
Right now the state of the art automatic units are not the bubble ones. For full HD on DISH or DTV you need one of these: Winegard TRAV'LER Automatic Multi-Satellite TV Antennas - Camping World.
The 3 lnb for DISH. 5 lnb for DTV. Personally I would wait on any roof unit as the technology is evolving quickly.
Tom
2007 28' Int CCD.
Two big screens
Centramatics.
02-11-2008, 05:53 AM
Los Alamos
, New Mexico
The only problem , ok two that i se with the roof top versions are you have to park in the open so the dish can get signal. I prefer to park in the shade of a tree. Flexability. Second it takes up room for solar panels!
Michelle TAC MT-0
Sarah, Snowball
02-11-2008, 06:12 AM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
I have Winegard meter and found it to be of little value. I suppose it may make a nice night light. Along with a sturdy tripod, the most useful tools I have are a small digital compass and a bubble level. As Michelle said, once the mast is vertical, it only takes a few minutes to set up a standard definition dish.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
02-11-2008, 08:07 AM
Michelle Mamzelle, I checked the acutrac III Pro and also saw the Channel Master model 10081FD at this site SATELLITE METERS, LOCATORS AND FINDERS
If you were interested only in Dish Network HD and Free2Air HD, Which one would you prefer? Comments from anyone else are also very welcome.
Live and LET live
02-11-2008, 06:09 PM
Los Alamos
, New Mexico
THe accutrac III does the same things as the channel master. It has a digital bar read out and I peak three sats at the same time. I love mine. some of the pro prefer the bird dog.
Michelle TAC MT-0
Sarah, Snowball
02-11-2008, 07:08 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
Dish network
I use Dish network, which uses Sats 110 and 119. They also use 129 for High Definition, but we don't use that option yet.
I use an Accudish base and a dual LNB dish. The base has a ball joint mounting with a level so that the post may be set properly.
Using the zip code, I can find the three settings needed for whatever location I wish.
I set up the base, slide the dish onto the base, hook up the meter, aim toward the compass setting indicated and watch the meter to find the sat.
It usually takes about five minutes, start to finish.
I like this set-up better than one mounted on the roof because, being portable, I don't get cought behind trees etc.
Accudish is located at:
13143 Carolyn St
Cerritos, CA 90703
Phone: (562) 926-6100
02-11-2008, 08:11 PM
Retired.
, At Large
Ours is similar, but with less "features". It took me about 15 minutes to find satellite 119, but I was using the "look at the other dishes and see where they are pointed" method. I now have a small compass that will help a lot next time.
04-10-2008, 12:12 AM
1978 28' Ambassador
Morada
Have you looked at the new VuQube antenna...
...It's portable and really easy to set up.
You just set it on a level surface, hook up the co-ax antenna lead to your Sat TV receiver. You then use the included wireless remote control to tune into the req'd sat's. You just use the setup screen on your TV as you use the remote to move the antenna around to the correct position.
We have Dish TV, and you can put two Sat locations into the remote control when tuned so you can switch between Sat's as needed.
The VeQube only has one LNB inside, so you can only tune to one Sat at a time. For Dish, most of the programing is on th the 119 Sat, but you can switch to the 110 Sat with the push of one button, and back again when needed.
When switching between Sat's, you get the 'lost signal' message on the Dish receiver, and have to wait for about a minute to reaquire the signal on the new sat...kind of a pain, but it does work easy, and is very easy to set up, compared with the old tripod setup.
