Old 03-09-2019, 04:30 PM   #1
2014 30' FB FC Bunk
Golden , Colorado
New LTE/4G antenna installed
Hi all - thought I would share my latest project. This is a dual LPDA (aka Yagi) arrangement polarized at 135 and 45 along with a central omni directional antenna. I used two antennas for MIMO capability - required to get full performance out of LTE-A, and they are polarized because that is how the tower sends out the signals. Imagine two RF waves traveling in an X formation.
The structure that actually holds the antennas is made with aluminum angle that is stuck together with double sided ultra high bond tape, and of course, rivets! The original winegard aluminum tubes (1x1 inch..) are quite flimsy. I may order some square 1x1 carbon tubes depending on how they hold up. As is, the weight is under 5lbs and cranking it up is no problem.
The Yagi antennas connect with LMR-400 cable to 36" pigtails that feed into the trailer. This avoids having to deal with the really thick cables, and not having to bend them too much, which is not good for performance.
Inside the trailer I have a Peplink Pepwave Max BR1 MK2, as well as a Wilson booster for the omni if and when needed.
Performance of the Yagi's is incredible. At my house I don't have line of sight to any towers, yet I was still able to pull a 50Mbps download! Signal would be considered 'fair'.
A/B testing with the amplified omni was interesting but not surprising. The omni was able to download at around 2Mbps and upload at around the same rate.
Happy to answer any questions. I hope this helps someone!
Here I am building the structure to hold the antennas:
ID:	335243Click image for larger version
ID:	335244Click image for larger version
And here is the thing fully installed:
ID:	335246Click image for larger version
ID:	335247Click image for larger version
ID:	335248Click image for larger version
bbdo is offline   Reply With Quote
Old 03-09-2019, 05:54 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I feel highly inadequate with my omni surecall antenna. That is the dog’s bollocks of mimo antennas.
wulfraat is online now   Reply With Quote
Old 03-22-2019, 12:26 PM   #3
Houston , Texas
Thanks so much for posting this, I'm in the beginning stages to design a cel road system and this is super helpful!
Sol_Elf is offline   Reply With Quote
New “Airstream Connected” LTE-WiFi Dealer Installed jeffmc306 Computers, Internet & Satellite 313 Today 10:16 AM
Looking for LTE N-Female Switch - DC-5Ghz bci Phone, CB & Ham Radio 1 03-29-2018 10:45 AM
Anyone using Verizon Home LTE (T1114)? joshjack Computers, Internet & Satellite 0 09-24-2017 06:56 PM
LTE and WiFi connectivity - router options Ohiobrits Computers, Internet & Satellite 24 07-07-2015 09:21 PM
Lengthing the Winegard Elevator Tubes LTE/Wifi Omni & Directional antennas BoldAdventure Computers, Internet & Satellite 4 04-17-2015 11:25 AM
